Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. May 8, 2016 at 5:55 PM
    #1281
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    I did and Carista just said they don't support older Tacoma's. Bummer!
  2. May 8, 2016 at 5:59 PM
    #1282
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    OK... Sorry Rock... I think I am finally getting what you want.... "you do not know what the settings do"...?? Is this correct..??..
    OK... the "sensitivity setting" is the vehicle's sensor's sensitivity to light.....IE: the higher the setting... the MORE sensitive it is... the lower the #... the LESS sensitive it is... if it is changing under short bridges, etc, then it's too sensitive.....LOWER the #....
    Hope this helps man...
    Over.
    PS... You do not need Carista... the settings are in the Head unit under "settings"
  3. May 9, 2016 at 10:29 AM
    #1283
    Boges
    Boges Member
    Is it possible to change the settings so the radio stays on after shutting off the truck, until the doors are opened or for a certain amount of time. My radio shuts off when the truck is shut off...it drives me nuts!
  4. May 9, 2016 at 11:02 AM
    #1284
    R.Shaw
    R.Shaw Well-Known Member
    2016 Tacoma 4X4 TRD
    Taking my truck in for its 5,000. Any suggestions on what to have them review. Trans fluid I will for sure, and I know it needs to sit for a couple of hours prior to testing. Also going to just pay for a oil change since it's not covered for free in this one.
  5. May 9, 2016 at 11:23 AM
    #1285
    JoCoQS
    JoCoQS This until I can afford a REAL truck
    Kelly
    Kansas
    2016 Jeep Cherokee
    Suggestion. Take in your "Warranty and Maintenance Guide" booklet and when they refuse to check the ATF level point out page 38 of the booklet
    pg38.jpg ,
    which clearly states "Inspect and adjust all fluid levels." Checking a fluid level is not done by hooking a Techstream to the truck's computer to see if a code was thrown for the transmission, it is done by manually inspecting the fluid level.
    Tell them to manually check the ATF level or they are in violation of ToyotaCare, which comes with all new Toyota sales.
    That's what "I" would do.
    rhines likes this.
  6. May 9, 2016 at 12:47 PM
    #1286
    R.Shaw
    2016 Tacoma 4X4 TRD
    Thank you, I''' wait to throw that in their face until after they give me the run a round.
  7. May 9, 2016 at 12:59 PM
    #1287
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
    The work-around for this is to put the truck in neutral and cut it off, this keeps the truck in accessory mode for me (push button start), shift into park, the radio stays on until I turn off accessory mode, I think there's a timeout but I've never waited to see.
    Cuffs and killthehippies like this.
  8. May 9, 2016 at 1:06 PM
    #1288
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    it's about a 15 minute timeout.
    sadmrhappy[QUOTED] likes this.
  9. May 9, 2016 at 2:25 PM
    #1289
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Is anyone else getting a vibration in the steering wheel and gas pedal? It seems engine related.
  10. May 9, 2016 at 2:29 PM
    #1290
    sadmrhappy
  11. May 9, 2016 at 5:57 PM
    #1291
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
  12. May 9, 2016 at 6:03 PM
    #1292
    GPatriot
    Cincinnati, Ohio
  13. May 9, 2016 at 6:11 PM
    #1293
    senayski
    senayski Well-Known Member
    Pittsburgh, PA
    Me: "directions to south hills village mall"
    Entune: "calling emergency services"
    Me: wtf is this shit
    So inaccurate and i suck when searching for a place to navigate to. Any tips or videos on it? I skimmed through the manual with no luck
    FireRoadFan likes this.
  14. May 9, 2016 at 7:06 PM
    #1294
    LericiCro
    LericiCro Member
    2016 Double Cab Long Bed 4x4 SR5
    Thanks for this post. Very informative. Exactly what this forum should be used for. Gracias!
  15. May 9, 2016 at 7:20 PM
    #1295
    64strings
    64strings Member
    James
    2016 Red Tacoma TRD Sport
    DOn't know if it's been addressed...pressing the volume knob on the entune will also mute audio
  16. May 9, 2016 at 7:22 PM
    #1296
    64strings
    64strings Member
    James
    I'm pretty pleased with it. Case was $15 on Amazon...phone is always charged up nice.
    jeff_taco_4x4 and ky13cummins like this.
  17. May 9, 2016 at 9:43 PM
    #1297
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Something as simple as pushing the knob isn't listed since it's a fairly common thing to do. I'm trying to keep the list to things that might not be so obvious, such as the whole thing about the camera working while it being in reverse at 45 mph. Not something I would test but still a nice thing to know that reverse locks out and is essentially neutral at that speed.
  18. May 10, 2016 at 5:18 AM
    #1298
    Rock_Diamond
    Rock_Diamond Well-Known Member
    Pro tip: don't use it. Sorry. It works great for "call this person" but that's about it.
  19. May 10, 2016 at 7:30 AM
    #1299
    Texasbrons
    Texasbrons Well-Known Member
    Pleasant Hill, MO
    2016 Tacoma Off Road TRD Quicksand
    Changed my DisplayOff image ---Twice!!
    I'll take this clarification one step further. It's good for calling contacts that have been synced from your phone. "Call wife mobile", "Call wife at work", etc... (Wife will be replaced by the persons name more than likely unless you have your people in there by their nicknames). But if you want to call someone or a business it sucks. "Call O'Reilly's Auto Parts in Hoboken, NJ". Forget about it. And telling it to give you directions to a place has only worked ONE time. It never gets the place right. And yes, I've done the "learn my speech" program on there at least 3 times. Entune SUCKS!!
  20. May 10, 2016 at 8:25 AM
    #1300
    joeshmo
    joeshmo Member
    Joe
    Does anyone else's truck with the v6 idle rough? I have my phone mounted to the windshield and it is vibrating at red lights and stops annoyingly! It feels like I have an aggressive cam in it but I know that is not the case. Thank you!
