Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Jul 9, 2016 at 8:19 PM
    #1561
    kjp4575
    kjp4575 Well-Known Member
    Portland OR
    2016 TRD Sport DCSB Prem Tech Package
    Any suggestions on aftermarket nerf bars? Photo's are greatly appreciated.
  2. Jul 9, 2016 at 8:25 PM
    #1562
    jeff_taco_4x4
    jeff_taco_4x4 Well-Known Member
    jeff
    16' 4x4 Sport DCSB w JBL, MGM
    I got these N-Fab "wheel to wheel" nerf bars at runningboardwarehouse.com Great price n free shipping. It comes in flat black or gloss black. It also has a 3rd step for the bed option if you want.
    SOSHeloPilot, WestGa42 and SilverII like this.
  3. Jul 10, 2016 at 1:32 PM
    #1563
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    A couple of things to keep in mind:
    1. Usable capacity is not the same (=less) than tank capacity.
    2. Running a tank nearly dry can reduce cooling to your fuel pump. I have no idea if it's really an issue on the Tacoma, but I doubt it's helping longevity.
    Based on my experience comparing fill-up vs. Distance To Empty, my rule of thumb is 25 miles past 0 DTE. That might give me a few miles of margin, but I don't count on it. I don't typically run past 0 DTE because my commute is about 40 miles and I just fill up at the next opportunity after the low-fuel indicator comes on.
  4. Jul 10, 2016 at 3:44 PM
    #1564
    splizaat
    splizaat Well-Known Member
    Beaverton, Oregon
    2020 TACOMA, CEMENT, TRD OFF-ROAD, Auto, 4dr Shortbed, Advanced Tech + Premium + LED Heads/Fogs
    Went to dealership to turn off door chime if door is opened before truck is turned off -- We could not, for the life of us, find this option in the toyota software / laptop. Not sure this feature can truly be turned off.
  5. Jul 10, 2016 at 3:52 PM
    #1565
    opentang
    opentang you're doing a good job
    Brandon
    2020 T4R TRD PRO
    Funny thing is I spent my morning using my Carista/Veepeak to do the same. No option or menu available to disable damn
  6. Jul 10, 2016 at 3:55 PM
    #1566
    splizaat
    Beaverton, Oregon
    Driving me INSANE!
  7. Jul 10, 2016 at 8:51 PM
    #1567
    Schriner13
    Schriner13 Well-Known Member
    Austin
    Perry county, OH
    2016 Quicksand Tacoma TRD 6-Speed Manual
    Hmm I don't think my 6 speed manual has it?
  8. Jul 10, 2016 at 8:55 PM
    #1568
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    If it's the driver's door, I just reach back and bump the door switch once and it stops. Not saying that makes it OK, but at least I can kill it easily if needed.
    poppy510 likes this.
  9. Jul 11, 2016 at 12:10 PM
    #1569
    jeff_taco_4x4
    jeff
    just noticed this today: The posted speed limit in the multi-media dash compass screen gets a red box around it if your driving over the speed limit, and the red box goes away when your under the speed limit. Now, there is no red box for the Navigation screen's posted speed limit logo (at the bottom) if your speeding.
    under speed limit, so no red box:
    speeding...note the red box ! :
    no red box in Navi head unit:
    ExtraExtra likes this.
  10. Jul 11, 2016 at 12:21 PM
    #1570
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    That only shows in the compass screen, is that right..?? That screen is something I would not use at all....too bad it doesn't pop up on whatever screen you choose.. Maybe, just maybe, when you customize that center screen you might be able to put that onto the one of your choice... I'm going out there and check that out......
    Thanx... will let U know..
    69TACO16 likes this.
  11. Jul 11, 2016 at 12:37 PM
    #1571
    over60
    Muskoka, Ontario
    OK, I do not see any option to put that speed limit feature on any of the other screens.....I'll have to check to see if I have it on the compass screen as well...
    jeff_taco_4x4 likes this.
  12. Jul 11, 2016 at 12:38 PM
    #1572
    69TACO16
    69TACO16 Well-Known Member
    Rick
    Caledon, Ontario
    16 MGM DCSB TRD 4x4 SPORT
    de-badged, tint front windows, led interior lights, door sill protectors, led b/up lights, 5" factory step rails, yellow turn signal bulbs, added 4 D ring tie downs. Took off the black vinyl stripes between the doors. Changed the grill - from Custom Car Grills, Finally got a tonneau cover put on. 31" light bar ( white & amber ), tailgate light bar, sunvisor covers ( to hide warning labels ), new bedside decals - still too cold to put them on tho. Flag decals to go on too, again too cold still. Got a 2 switch, switch plate to replace that useless cubby hole to the left of the steering wheel.. still to be installed ( hopefully this weekend ). Upgraded the tires to G/Y Duratracs... loving them, no plowing the driveway !!
    I believe it comes on while driving using the nav system.... I could be wrong...
  13. Jul 11, 2016 at 1:13 PM
    #1573
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    You can turn that red box feature off too
  14. Jul 11, 2016 at 1:55 PM
    #1574
    jeff_taco_4x4
    jeff
    really? interesting.
  15. Jul 11, 2016 at 2:09 PM
    #1575
    jeff_taco_4x4
    jeff
    I have a feeling you could use voice command to say "Pause Route Guidance"...could save messing with a lot of buttons/menus. Anyone verify this? I will try later and report.
    UPDATE: It works! By using the voice command "PAUSE GUIDANCE" and "RESUME GUIDANCE" I could easily control my destination. Next, I used the voice command "DELETE DESTINATION" and it stopped my destination, but did not eliminate it from my library of address for previously used destinations :) I wish they would have named it "stop destination" instead of "delete destination", that would clear up some confusion.
    note: I also tried the commands "pause navigation" and "resume navigation" and found out they do not work.
    Tharris242, vuTron and ExtraExtra like this.
  16. Jul 11, 2016 at 2:30 PM
    #1576
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... I like that color and finish ... your nerf bars are gloss finish, I am guessing ?? ...... I went to the web-site that you mentioned and found many options there. ... was there a reason that you picked that brand ?? ..... thanks
    PS .... Nerf bars are on my short list
  17. Jul 11, 2016 at 2:38 PM
    #1577
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    You can get it back by pushing the circle with the i in it at the bottom right of the nav screen.
  18. Jul 11, 2016 at 2:42 PM
    #1578
    jeff_taco_4x4
    jeff
    looks and price. Made in Texas too (usa) :)
  19. Jul 11, 2016 at 3:44 PM
    #1579
    jeff_taco_4x4
    jeff
    your right! I just tested it out on the road. The "i" toggles between "final destination arrival time/miles" and the "posted speed limit logo/current road name". Thanks for this great tip:thumbsup:
    axisofoil[QUOTED] likes this.
  20. Jul 11, 2016 at 8:58 PM
    #1580
    Bisley4525
    Bisley4525 Well-Known Member
    Cliff
    Inferno DCSBOR 6MT
    The Entune premium audio system has this thing called Cache Radio. It will store up to 20 minutes of whatever station you are listening to, and allow you to rewind to repeat the broadcast. You access the feature from the little arrow on the right side of the display. Memory resets if you switch stations.
    20160711_182120.jpg 20160711_182125.jpg 20160711_182132.jpg 20160711_182147.jpg
    HighonFirewood and JoeyDel like this.
