Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Jan 6, 2017 at 7:06 PM
    #1921
    17tacosport
    17tacosport Well-Known Member
    Hasmeet
    Buffalo,NY
    2017 MGM Tacoma DCLB 4x4
    Yeah I saw atleast one of those bolts that was completely flat on the outside and smaller then the rest but I'm going to the dealer to get my ATF checked tomorrow you think they'll take it out for me and put regular lugs in?
  2. Jan 6, 2017 at 7:09 PM
    #1922
    Cable
    Cable Well-Known Member
    California
    2017 TRD Off Road 4x4 Quicksand
    Its attached to your lug nut wrench where your jack is.
  3. Jan 6, 2017 at 7:15 PM
    #1923
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Locking nuts from Toyota look like little flower designs on the top.
  4. Jan 8, 2017 at 2:59 PM
    #1924
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Lifting your truck...
    This is not meant as a discouragement to lifting your vehicle. Please note: this is just to inform you.
    If you are not willing to spend thousands of dollars, don't mess with your suspension's ride height.
    Here is the scoop. If you change your ride height, you need to fix all of the suspension and driveline geometry you just threw out of whack. Non-negotiable.
    Let's start with the front... Raising the front requires you to correct the roll center, camber gain, bump steer, Ackerman steering, and then an front end alignment. The first 4 cost a lot of money. Don't forget: if you have a 4wd, then you need to correct the driveline geometry you just messed up. Again, money.
    Now for the rear... Raising the rear cause less trouble than the front, but you need to be diligent none the less. The most important thing you need to correct is driveline geometry. With a 2 piece driveshaft, there are a lot of angles to be mindful off. These must be corrected when lifting a vehicle. Roll center needs to be considered as well, but this is very minor. Last, a front end alignment to correct the faster you just through out. Finally, you need to test for vibrations in the driveline and correct as needed.
    Failing to correct the geometry after a lift results in a realization that you paid money to make your vehicle worse. Though, to be fair, it may look a little nicer.
    Sprouty115 and 17tacosport like this.
  5. Jan 8, 2017 at 5:34 PM
    #1925
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    I noticed this yesterday. If you have a door open and hit the key fob button to lock the doors, the truck will chirp as soon as the last door closes.
  6. Jan 8, 2017 at 10:26 PM
    #1926
    madmanxing
    madmanxing Well-Known Member
    2017 Cement Tacoma Trd Pro
    is there a way to lock the truck with it running with the smart key outside? ( i know it wont lock while its inside) but when my girl is in the car and i keep the truck running to run in somewhere she cant lock it.....
    does she have to wait till i walk far away and test it again? i honestly didnt try that
  7. Jan 9, 2017 at 2:36 AM
    #1927
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Lock the doors with the metal key from inside the smart key. Or leave the smartkey with her.
  8. Jan 9, 2017 at 3:36 AM
    #1928
    jmdwifi
    jmdwifi My Inferno
    Fredericksburg, Virginia
    See profile
    Is this an update for the maps? My map dates are 2015 and the entune says I have to go to the dealer to update. Bought this truck in October. Seems like bullshit to have to pay that much to update maps that should have been updated.
  9. Jan 9, 2017 at 8:28 AM
    #1929
    Cuffs
    You buy a micro SD card of the maps from the dealer
    69TACO16 likes this.
  10. Jan 9, 2017 at 8:33 AM
    #1930
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I would go to the dealer and ask them for a free update considering you just bought the truck. If they give you a hassle tell them that you will take your truck elsewhere for service. Dealers make a lot of money on service.
  11. Jan 9, 2017 at 8:53 AM
    #1931
    DodgeORama
    DodgeORama Well-Known Member
    Dodge
    Squamish, BC
    2017 MGM TRD Off Road DCSB
    I think the light goes on when you're next to the truck, when it senses the fob is close.
    To open it, just pull the handle (don't touch the lines)... there's a sensor behind the handle.
    The lines on the front of handle only lock the door.
  12. Jan 9, 2017 at 8:59 AM
    #1932
    madmanxing
    Ahhh, should have thought of that myself... Lol thanks! I'll get in the habit of leaving it in the truck when she's in there.
  13. Jan 9, 2017 at 9:57 AM
    #1933
    DJ TonyT
    DJ TonyT 2017 TRD 4x4 Off Road DCSB - Sunroof and JBL
    TonyT
    Jacksonville, FL
    I agree since the update was released in November - you might could talk them into a free one......worth a try!
  14. Jan 9, 2017 at 10:04 AM
    #1934
    Cowpoke
    Cowpoke Active Member
    Owasso, OK
    '17 TRD OR (Inferno)
    Yup, this is correct, I was making it harder than it had to be.
  15. Jan 9, 2017 at 10:04 AM
    #1935
    gpb
    Atlanta
    Just don't leave the key with her if she's pissed off at you...
    zackdippolito likes this.
  16. Jan 9, 2017 at 10:29 AM
    #1936
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Leave the fob with her, so she has the panic button. Take the key from the FOB with you, so you can get back in!
  17. Jan 9, 2017 at 10:45 AM
    #1937
    jmdwifi
    jmdwifi My Inferno
    See profile
    has anyone bought the updated SD card from eBay. I'm only asking because I will ask if they will update it at the dealer. They are pretty stupid and I would rather not argue with them or driver very far as opposed to 65.00. If the only other option is over 200.00, then I may fight harder.
  18. Jan 10, 2017 at 12:56 PM
    #1938
    DJChrisLee
    DJChrisLee Well-Known Member
    I put my vape bottle there :)
  19. Jan 10, 2017 at 5:44 PM
    #1939
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    Have you seen the latest SD card (86271-OE184) offered for sale on Ebay? The only ones I see are older versions. There seem to be many Toyota dealers that offer it for sale online for ~$160.
  20. Jan 17, 2017 at 9:18 PM
    #1940
    Krismassie15
    Krismassie15 Member
    Kris
    Southern california
    Fox 2.5" coilovers w/reservoirs in the front with Icon 1.25" Uniball UCA's. Fox 2.0 non-resi shocks in the rear. Method NV 17" wheels, 285/70/17 BFG AT KO2 tires
    Leave the truck in D,N, or R and push the button to turn the truck off. Radio will stay on then put it in park
