Tips for buying a used bed cap?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tenzing, Mar 20, 2011.
  1. Mar 20, 2011 at 12:31 PM
    Tenzing
    Tenzing [OP] Active Member
    The Northeast
    95 Manual Xtracab 4x4 Taco
    Awesome Skull Cigarette Lighter
    Hey guys,
    I'm looking at a used bed cap tomorrow, a Leer 122 if the pictures are accurate. Any tips on what to look for so I know I'm picking up a good cap? I've never had one before, but I need it.
    Thanks!
  2. Mar 20, 2011 at 12:42 PM
    turtletaco
    turtletaco Active Member
    VA
    01 SR5 XCab 4x4 Manual
    x2. I found one today that came off of an xcab and is painted my color already for $450. SnugTop is the brand listed. I am waiting for a response but if not that one I am going to get one at some point. Don't know what will ensure I get one that will last and keep things dry.
  3. Mar 20, 2011 at 8:20 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    buy mine. it fits an extended cab !!!!
  4. Mar 20, 2011 at 10:31 PM
    nwfjarhead
    nwfjarhead Member
    nick
    fort walton beach florida
    How much?
  5. Mar 21, 2011 at 1:03 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    i would do $350 for it. its an are zx camper top. brand new costs around $1900. lemme know.
  6. Mar 21, 2011 at 7:49 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    -Check for spider cracks around the corners and chips on the edges.
    -Insure there is a proper seal along the bottom.
    -Check the seals along the window for dry rot, etc...
    -Look down the length for bumps (un-flat surface) that would imply there was a hole/crack that was repaired.
    -If possible, insure the wood frame inside the fiberglass isnt rotting.
    -Look at the screens if you plan on using the windows.
    -And of course, always measure for fit.
    When you find a blemish, over-exaggerate and make a big deal in order to drive the cost down :rolleyes:.
    Tucker771 likes this.
  7. Mar 21, 2011 at 11:07 AM
    Tenzing
    The Northeast
    Thanks for the info! FWIW, does anyone know the cost to replace T-Grip locks? Maybe Leer still has the keys, but this would help me set a more realistic price.
  8. Mar 21, 2011 at 8:39 PM
    turtletaco
    VA
    Well I picked one up today. Test fit it & color was dead on. There was no lock and I will need to find some weather stripping as it doesn't have the railing system included. Figured I would just clamp it to the rails of the bed. Also the mfg wants $40 for a new lock assembly. Anyone know if they are universal or where else to look?
    Couple of issues but it was in great shape & the price was right.
  9. Mar 21, 2011 at 9:26 PM
    nwfjarhead
    nwfjarhead Member
    nick
    its a bit far for me but the price is good.
  10. Mar 21, 2011 at 10:43 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    well lemme know cause i might be able to meet ya half way or something.
  11. Mar 22, 2011 at 4:06 PM
    turtletaco
    VA
    I'm trying to hook up the lights on it and I need to know which one of the green wires to tap into for the break, since it is a dual filiment.
    Also there is a dome light I would love to hook up but I assume I need to run a new wire down to get constant power?
    Who else has done this and may be able to give me some help?
    Thanks in advance
  12. Mar 22, 2011 at 7:48 PM
    pickuptruckguy
    pickuptruckguy Well-Known Member
    SoCal
    04 Doublecab 4x4
    x2
  13. Mar 23, 2011 at 7:20 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Nice buy! But damn that roof rack sits high! lol
  14. Mar 23, 2011 at 10:24 AM
    turtletaco
    VA
    Man I am luck I'm under $300 but mine was already matched to my color. It has a few scratches here and there but nothing too bad or worse than the truck. I will certainly get racks for mine.
    What wire did you tap for the break light? Solid green or green-red? I have to get that done before I get pulled over.
  15. Mar 23, 2011 at 11:00 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Do you legally need the third brake light? I always thought you just needed the primary 2.
    Joshua.Wolff likes this.
  16. Mar 23, 2011 at 11:10 AM
    bamma
    bamma Well-Known Member
    Current: 2011 Land Cruiser
    You can wire your dome light to your taillight (the con being you can only turn it on when your headlights are on.)
    I'm not sure if I understand your question regarding the wire correctly, but you should only hook up the brake wire to the the third brake light. I just stripped both wires and tested them with my headlights on to see which was the brakelight. Sorry if I didn't understand your question...
  17. Mar 23, 2011 at 11:21 AM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    You just bought this topper a little over a month ago, spray painted it black and added your "custom" touch to it but on top of all of that, you only paid $75 for it. Now you're trying to sell the exact same topper for $350...?
  18. Mar 23, 2011 at 2:05 PM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    They make low profile towers. I would just trade or sell those towers and get a low profile version, only if you use the rack tho. That just my .02 still looks good!
    http://yakima.com/shop/racksystems/factory-tracks-or-rails
  19. Mar 23, 2011 at 2:18 PM
    turtletaco
    VA
    I didn't want to strip any wires if I could hook them into the plug. The break light socket has two pos. wires running one for breaks one for driving lights. One solid green and one green-red striped.
    And I think I may as a temporary fix wire the dome to the driving light. I will get on it this weekend. We'll see if I have time to run a wire front the front or not.
  20. Mar 23, 2011 at 2:56 PM
    bamma
    The third brake lights I have seen do not have a wire for the driving light/taillight. It should be for the brake light only. In some states it is illegal for the third brakelight to light up like a taillight. Are you sure one of the wires is not for the dome light?
