Tips for Driving Ice/Slush/snow or snow dusting
Discussion in 'Florida' started by 2013TacoDCLB, Jan 21, 2025.
  1. Jan 21, 2025 at 3:33 PM
    2013TacoDCLB
    2013TacoDCLB [OP] Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    Hey All,
    Need advice driving tomorrow in ice/snowmegedon in Gainesville. Any tips or tricks for using or not using 4wd if there is snow or slush. I’m from S Florida, so it’s a new day.
    thanks Mark
  2. Jan 21, 2025 at 3:40 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Lane changes can get right hairy so be careful with those. :)
    Black97v6MT likes this.
  3. Jan 21, 2025 at 3:45 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    - have good tires
    - leave the 4wd on full time
    - don't drive faster than you can brake
    - watch out for idiots
    Tires are the biggest make it or break it in snow driving. What tires do you have? How much tread is left?
    As long as there is snow on the ground leave the 4wd on, I routinely drive on the freeway 70+mph in 4hi. The only way you can hurt the 4wd system is full lock turning on dry pavement.
    Braking distance is going to be drastically further than on dry pavement so start braking very early.
    Be extra vigilant around intersections, lane changes, and on curved roads. That's where idiots will end up sliding all over.
    Black97v6MT and TS4x4 like this.
  4. Jan 21, 2025 at 4:07 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The key is to slow down. Up in our Sierras the number one cause of spin outs and accidents in snow/ice is speed. Going the speed limit may be too fast for conditions. I don’t know how much snow you got but if you’re in Florida I doubt it’s going to amount to much or much affect driving. Ice is the worst hazard and I doubt there’s much if any of that.
    Take turns and lane changes slow and easy.
    Black97v6MT, TS4x4 and Tatts521 like this.
  5. Jan 21, 2025 at 4:09 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Put some weight in the back of your truck.
  6. Jan 21, 2025 at 4:12 PM
    Bishop84
    Bishop84 Well-Known Member
    Use the 4x4, it makes a massive difference and its meant to be used.
  7. Jan 21, 2025 at 4:25 PM
    545 Well-Known Member
    2015 Access Cab
    Use 4x4 as long as the roads are snow covered
    When it gets patchy, be cautious but it’s ok to stay in 4wd, be aware of stiff steering and drop out of 4wd as needed
  8. Jan 21, 2025 at 4:41 PM
    Harp1
    Harp1 Well-Known Member
    Masshole for now
    2022 Toyota Tacoma DCSB
    purely stock
    What everybody said plus remember this. Just because the speed limit sign says a certain number that doesn't mean you need to maintain that certain number. Speed reasonable for conditions applies here. If you are slipping and sliding and you see vehicles off the road just please slow down.
  9. Jan 21, 2025 at 4:51 PM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    Eastern WA. Here, I was taught to drive like you have no brakes. Because that might just how they respond. Counter steering is a life saver, if you are trying to swap ends. Be safe...
  10. Jan 21, 2025 at 4:59 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I'm from Georgia, so I have very little snow driving experience. I just stay home unless it's an emergency. Most everything closes when it snows in the south anyways.
  11. Jan 21, 2025 at 5:23 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you have ice stay home until it thaws which should be shortly after sunup.
    Some weight in the bed would help. You only need 4X4 to get up hills. Not many of those in Jacksonville. If you have a front wheel drive car you'll be a lot better off in it than you would in the Tacoma.
    There is a HUGE difference in driving in the snow we get in the Southeast than in northern and mountain states. It's a LOT easier to drive in 8-10" of snow in Colorado when temps never get above freezing than in 1" of mixed snow, rain and ice in the south where you go through freeze/thaw cycles every few hours.
  12. Jan 21, 2025 at 5:27 PM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    It’s not about the amount, but how it sticks. Any amount of ice is enough to make the most prepared truck spin out. Best advice is to simply stay home.
  13. Jan 21, 2025 at 5:28 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    There will be snow on top of ice. Nobody has winter tires or winter driving experience. Even if your vehicle is 100% prepared and you have experience, some idiot on bald summer tires or mud tires will crash into you.
    TS4x4 and Black97v6MT like this.
  14. Jan 21, 2025 at 5:33 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Drive slow and steady. Don't hammer the throttle, throw the wheel around, or slam the brakes. Give yourself extra following space - aim to be at least 4 seconds behind the car in front of you at all times. Make sure when you stop your tires are on bare asphalt if at all possible - as long as you're moving slow and steady and maintain speed, you'd be astonished how much control you'll maintain.
    Assuming you must drive, of course. If you can, stay home unless the roads were actually prepared, because the snow is not your enemy - it's the ice that you are unlikely to see,and if you're not on winter tires or (for the light snow I'm guessing Gainesville is getting) 3-peak rated four-seasons with sufficient tread, you are not going to have traction at all on ice. And even if you have traction, a lot of other drivers aren't going to be ready for it. Drive safe.
  15. Jan 21, 2025 at 6:29 PM
    2013TacoDCLB
    Mark
    2013DCLB4x4
    I have All Terrains. Good Tread life. I’m definitely going to take my time to get to work. I thought you could not drive in 4HI on ice. Thanks for the tips.
  16. Jan 21, 2025 at 6:35 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Learn to properly countersteer when that back end gets groovy
  17. Jan 21, 2025 at 6:54 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I would suspect that there isn't ice at the bottom but slush, as their ground isn't likely anywhere near freezing.
    I read elsewhere that P'cola has over 5" on the ground.
    @2013TacoDCLB, as others have said: Slow is the key. Leave a lot of room, and be very gentle and precise with all throttle/brake/steering inputs.
  18. Jan 21, 2025 at 6:57 PM
    Black97v6MT
    iMA0
    tacoLand USA
    That slush can definitely turn icy if the surface air temp gets below freezing ?
  19. Jan 21, 2025 at 7:02 PM
    Bishop84
    Tacoma has legendary drive train. Up here in Canada many leave it in 4x4 during the bad months. I'll go days in 4x4 with 20 minute drives to work. Snow, ice whatever.
    I'll turn it off once I hit drive pavement or if parking is tight.
  20. Jan 21, 2025 at 7:02 PM
    OldSchlPunk
    Rich
    East Central Wisco
    The air has to be below freezing to snow. The ground being warm tends to keep it from freezing. I would bet the ground temp in FL is close to 50*, it hasn't been cold that long.
    Black97v6MT[QUOTED] likes this.
