Tips for Driving in the Snow
Discussion in '3rd Gen. Tacomas (2016-2023)' started by leeeyumm, Dec 4, 2023.
  1. Dec 4, 2023 at 10:03 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    When I was a kid, dad always had 2wd
    He had a piece of plywood and two 2x8 that would sit between the wheel wells of the Ford. Would place eight 50# sandbags there, really worked well.
  2. Dec 4, 2023 at 10:07 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I have been driving mud/snow/wet tires in the midwest for 30 years on a FWD passenger vehicle. I will have to practice first in this light-in-the-tail truck. Down in "Sun Valley" there is only a remote possibility of a few blowing flakes. I need to drive 60 miles north or east to get to elevation to practice ... some sandbags in the bed as deadweight.
  3. Dec 4, 2023 at 12:36 PM
    ZMan1971
    ZMan1971 Active Member
    2019 Tacoma
    Carry a shovel
    EL Taco Verde likes this.
  4. Dec 4, 2023 at 12:36 PM
    junkyardyote
    junkyardyote Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    I use sand bags 100#. Most of the time I use autoLSD from a stop and 2wd on surface streets.
  5. Dec 4, 2023 at 12:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m in my 13th winter with the same set of BFG commercial ta traction tires. They love me long time.
    Junkhead and BC Hunter like this.
  6. Dec 4, 2023 at 12:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Four Dedicated Winter Tires! Put them on from Nov-Apr and be safer for everyone on the roads.
    I live at 7000' and travel over 12,000' and with four dedicated winter tires, I barely need to use 4WD. I use Toyo Observe GSi6 and have used their winter tires for 22+ years on different vehicles. https://www.autotrader.ca/editorial...after-trying-winter-tires-for-the-first-time/
    https://www.outsideonline.com/2408499/snow-tires-people-who-dont-live-winter
    jasonvt, Coyote501, SH10151 and 4 others like this.
  7. Dec 4, 2023 at 12:46 PM
    EL DUDE
    EL DUDE Well-Known Member
    Limit wheel slippage, have good tires, try and stay on the fresh stuff.
    I grew up with 2wd s10s and Nissan d21s that were lowered. Never had much issue in the snow. 4x4 only makes it easier to get going and get out of bad spots
    also, prep for braking. Stay off of peoples butts, be prepared to go into the shoulder
    MannyS likes this.
  8. Dec 4, 2023 at 12:48 PM
    TacoTuesday1
    FL
    that's the point
    why would that happen
    Trucks and truck-based SUV's are predominately 4x4. 4x4 is better than AWD and offers more.
    You also get a locked center diff in 4HI.
    Certain AWD cars do not have the space in their design to allow room for the added capability of a transfer case that offers low range, that also adds cost (more parts) so they do not put one.
    Cars stopped offering this when they switched from performance, to making them worse.
    For example, 1980's performance Audi with 3 selectable locking diffs (button and vacuum-controlled) winning rally championships. They stopped doing this.
    4x4 lets you turn it off on dry pavement. An Audi (fulltime mechanical AWD) does not let you turn it off. As a result, the parasitic draw losing MPG is fulltime, and nose heavy pig FWD understeer bias behavior is fulltime.
    Change a vehicle open diff to limited slip or locker is $1000+ per diff. Yours already came with locking center stock, not including locking rear if it's an OR.
    Drivetrain puts power down, not turns or stops. That is done by the driver and tires.
  9. Dec 4, 2023 at 12:53 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I live in an area where we get 80+” of snow a year. I’m not very old and have had 6 different trucks so far with 4wd. In winter anytime the roads are crappy I’ll drive around with it on. Even in dry roads sometimes. Never damaged any of my vehicles. You won’t do any damage to your vehicle unless you’re pulling into parking spots or taking tight turns.
  10. Dec 4, 2023 at 1:07 PM
    Admiral Snackbar
    Admiral Snackbar Well-Known Member
    Like others have said, on slippery and snow covered roads you're not going to burn anything up. Thats 100% what it's for, and you won't hurt by driving through snow covered roads for months on end. Tires will also make a difference, but seriously you paid for 4wd why have it if you're afraid to use it. Also as stated earlier, AWD is just like 4wd but with an non locked center diff. The non locked helps it on dry roads etc. So just don't use 4wd on dry roads and you'll be fine
    BC Hunter likes this.
  11. Dec 4, 2023 at 1:15 PM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    yes weight in back & good tires & 4x4.
    also:
    - use a higher gear to have more gradual acceleration.
    - keep in mind your tire temperature, if you air down there will be more ground contact and the sidewalls heat up a bit more and that can keep rubber more sticky.
    - you need good lighting, and a clean windshield on the inside for glare. turn off your inside lights (and touchscreen) at night, turn your dash brightness down all the way using the stick odometer.
    - test your brakes constantly, make sure you are aware of your stopping distance, and give yourself extra room for the other idiots on the road.
    - buy some little steel tracks to help you if you get stuck, or someone else. I have used mine so many times.
    - Don't be afraid to be late, pullover if you feel unsafe, or if there are too many other idiots on the road. Especially early days of snowfall in your area when people are re-learning to drive. Please chose a good place to pullover, keep lights on, flashers, away from traffic.
    - Help others in distress, look for tire tracks going off the road, sometimes simple slides can be deadly if no one knows a person is stuck without their phone.
    DrRansom and leeeyumm[OP] like this.
  12. Dec 4, 2023 at 1:26 PM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    And also tires, tires, as well as TIRES!
    You won't believe the difference new tires/tires made for those conditions will make.
  13. Dec 4, 2023 at 1:30 PM
    RichochetRabbit
    Years ago in Seattle people put stud tires on for the few short winter months to handle black ice. I think they do not anymore because they like the roads to not be chewed up. Not exactly the same as you intend, but shows that the right equipment makes a difference.
    Out2gtcha[QUOTED] likes this.
  14. Dec 4, 2023 at 1:31 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
  15. Dec 4, 2023 at 1:34 PM
    #35
    RichochetRabbit
    In Indiana years ago in college (college kids are poor) a friend was driving on a freeway with old/bald tires. Hit an ice patch and did 3-4 360-degree spins before settling sideways across 2 lanes. He got new tires immediately.
  16. Dec 4, 2023 at 1:37 PM
    #36
    Little Lion
    thats kinda funny to imagine a water bag in winter. thing would be an ice brick within half an hour at least where i live :anonymous:
  17. Dec 4, 2023 at 1:37 PM
    #37
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    That's still the norm in Portland. I saw a car with studs on back in October. I have no idea why.
  18. Dec 4, 2023 at 1:43 PM
    #38
    6MTPro
    HI -> CA
    It claims to be rated to -40F. I haven't had it in that cold but its surprising how it did. You could add antifreeze to it as well if someone really wanted to. Hard as a brick would still be similar to sand bags or something similar.
  19. Dec 4, 2023 at 1:45 PM
    #39
    6MTPro
    HI -> CA
    I'm debating doing the drive from the bay to Salida at the end of the month. would turnaround that same week through
  20. Dec 4, 2023 at 1:48 PM
    #40
    Little Lion
    think maybe the bag can withstand that temp, but the water would be frozen still. and no way to drain / move it around at that weight. with sand you can still pour in / out as much as you need. not saying its a bad product but i dont see it working as well as the cheap option in the severe cold.
