Tips for Getting off Front Differential Drain Plug?
Discussion in '1st Gen. Tacomas (1995-2004)' started by GW1995Tacoma4WD, Mar 1, 2011.
  1. Mar 1, 2011 at 3:02 PM
    GW1995Tacoma4WD
    GW1995Tacoma4WD [OP] New Member
    Colorado Springs
    1995 2.4L 4WD
    I got the 12mm Hex Key and that drain plug just won't budge. I have used a pipe as an extension and still can't get enough leverage. Any tips?
    Also, what type of gear oil/fluid would your recommend for 1995 4WD Tacoma?
  2. Mar 1, 2011 at 3:03 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    was gonna say use something for an extension to get more leverage
  3. Mar 1, 2011 at 4:33 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    when i changed mine last year i remember it was a PITA to get off to and what i ended up doing was takin a hammer and smacking the drain plug a few times without the hexkey in it and then when i put the key back in i was able to turn it out lefty loosy with only a small extension. smacking it a few times must have freeed it up some how. also for the fluid i used 80w-90 royal purple.
  4. Mar 1, 2011 at 5:04 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I have the same problem and I gave up on gettin it off last time. But I usually get the box end of a long wrench and put the allen wrench through that. But you are basically doing the samething.
    Hittin it with a hammer may help loosen it up some. If you can't get it off with your Allen wrench I would say get a bit that size and put it in a socket and try that.
  5. Mar 1, 2011 at 5:43 PM
    humtaco
    humtaco Well-Known Member
    Be sure to loosen or remove the filler plug first. You don't want to drain the oil only to find you can't get the filler plug out to replace the oil.
  6. Mar 1, 2011 at 5:45 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Hammer and gently but firmly give it some solid taps.
    Remember, fill plug first.
  7. Apr 5, 2012 at 6:20 PM
    drmax
    drmax Well-Known Member
    IND
    95 DLX 4WD
    Hello, anyone have a cheat sheet on the qty's for front diff, rear diff, xfer case and man. xmission? Also, is it all the same type gear oil? Thank you, DM
  8. Apr 5, 2012 at 6:54 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
  9. Apr 5, 2012 at 6:56 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Use a propain torch to heat it up. Helps alot. Also makes sure you can fill it first before you drain it.
  10. Apr 5, 2012 at 7:01 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Cool Post Bro, Tell TJ Hunt To Update The Vlog!
    Manual Trans 3RZ 2.6 QTS 75W90
    5RZ 2.3 QTS 75W90
    Xfer Case 1.1 QTS 75-W90
    Front Diff 1.2 QTS 75W90
    Rear Diff 2.8 QTS With Locker 90W, or 80W90
    2.7 QTS Without Locker 90W, or 80W90
  11. Apr 5, 2012 at 7:07 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Ha beat you to it:D
  12. Apr 5, 2012 at 7:16 PM
    drmax
    IND
    95 DLX 4WD
  13. Apr 5, 2012 at 7:17 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    i just ran into the same problem. it just wouldn't budge. i ended up welding a bolt to the old plug and using an impact gun to it. i installed a new drain plug afterward. the fill plug and rear diff. plugs gave me no hassle.
  14. Apr 5, 2012 at 8:36 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Alot of people dont say anything about on here.
  15. Apr 6, 2012 at 7:21 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Mine was a bitch to get loose with out a cheater bar.
  16. May 2, 2012 at 3:16 PM
    drmax
    IND
    95 DLX 4WD
    hello. gonna replace all my gear oils within the next couple weeks. have not done them (never have did the front diff.) for nearly 100K. uh, so having 190K miles, i priced the synthetic and gulped...guess i'm gonna stick with the reg. oil a keep on truckin. i'm manual shift, 4wd without locking hubs.
    other than making sure i can get the filler plug loose 1st on the front diff., if you all have any other suggestions, i'm just gonna replentish, with what the Haynes book calls out. Thx, DM
  17. May 2, 2012 at 4:32 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Just use lucas gear oil.
  18. May 2, 2012 at 5:58 PM
    drmax
    IND
    95 DLX 4WD
    I see you're still online. While you're here, I read somewhere that I could use the same weight everywhere in my truck. Uh, true? Or do I gotta use the heavier in the rear as the book points out 80-90? I don't change this stuff very often. Plz advise
  19. May 2, 2012 at 7:56 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    I also used Lucas synthetic 80-90, in everything, and she runs sooooo much better now, and the 4x4 shifts so much better.
    i am sure its the right weight, but for me I looked at the BLACK mess that came out of all the holes, so it had to be a improvement.
  20. May 2, 2012 at 8:09 PM
    drmax
    IND
    95 DLX 4WD
    no effect in the shifting? manual i take it. i may just do that
