Tips for installing front struts?
Discussion in 'Suspension' started by x2468, May 13, 2011.
  1. May 13, 2011 at 11:37 AM
    x2468
    x2468 [OP] Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    Hoping to FINALLY install my OME 90004 struts and OME 881 coils. Im gonna run out to advance and pick up one of these.
    http://shop.advanceautoparts.com/we...s-2-Ton-Torin_10014620-P_N3399_T|GRP2042_____
    I already rented one of these:
    http://www.tundrasolutions.com/foru...87149620-coil-spring-compressor-bilstein2.jpg
    and im using these instructions:
    http://www.ncttora.com/fsm/2003/Repair_Manual/03tacoma/sa/fsa4wdpr/remo.pdf
    http://www.ncttora.com/fsm/2003/Repair_Manual/03tacoma/sa/fsa4wdpr/reas.pdf
    Is there anything im missing? any tips or advice from those who have performed this already? Thanks in advance! I've done minor jobs on dirt bikes and atvs like top end replacement, countershaft seal change, etc. But I wouldn't rate my overall mechanical confidence very high.
  2. May 13, 2011 at 3:33 PM
    x2468
    Vermont
    alright. well guess im good to go
  3. May 13, 2011 at 3:35 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    just make sure the spring is compressed good and you should be fine man
  4. May 13, 2011 at 4:21 PM
    TRDSPORTtaco
    TRDSPORTtaco Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Umm here is a tip.
    1. Put truck on jack stands
    2. Remove wheel
    3. Remove brush guard
    4. Unbolt sway bar (loosen on opposite side of what you are working on)
    5. Loosen top strut nuts (not the center)
    6. I find it easier to separate the upper ball joint to allow more down travel of lower control arm)
    7. One strut is no longer compressed loosen and remove lower strut bolt
    8. Remove top 3 strut nuts
    9. Remove strut from truck
    10. Replace strut with new one or newly modified one
    11. Reverse steps starting at 8 and go back to 1.
    It's kinda tricky if you don't undo the upper control arm. Anyhow those are the exact same steps I follow. Except I have TC upper control arms so undoing the UCA's is a piece of cake.
    Good luck! Be safe!
    TheTacoma likes this.
  5. May 13, 2011 at 5:39 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    An easy way to get the ball joint's taper fitting off is to hit the side of the knuckle with a hammer. Do this with the nut slightly loosened. Make sure you only hit the part where the ball joint goes into, the knuckle, and not the top of the bolt.
    Don't use a pickle fork, they are a waste of time.
    There is still spring pressure on the strut with the nut holding the ball joint. Jack under the knuckle to relieve the pressure and remove the nut.
    Be sure to have the spring compressors evenly mounted and compress the spring evenly, alternating from one compressor to the other. Keep loved ones and body parts away from the compressors in line with the strut.
  6. May 13, 2011 at 5:49 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You forgot to mention paid up life insurance policies & reading of the will if something goes batshit on him....:eek::eek::eek:
  7. May 13, 2011 at 5:54 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I will pay a shop to swap them out, since I dont have the nice wall mounted(much safer) spring compressor. I will not pay them to remove the coilover from the truck. That is easy to do safely.
  8. May 13, 2011 at 7:04 PM
    x2468
    Vermont
    Says the crazy old man....
    is this really that dangerous?
  9. May 13, 2011 at 7:06 PM
    x2468
    Vermont
    you guys seem to be mentioning ball joints and sway bars, but the service manual pdf doesn't seem to show that i need to do any of that? is that extra stuff i can do to make it easier?
  10. May 13, 2011 at 9:30 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ok bro' physics lesson one: Consider this, a 650 lb coil spring means it takes 650lbs of pressure to compress that coil 1", ok, the struts are under a preload (compressed spring) of about 2" sometimes a little more. So if you take off the center nut without using a spring compressor (or not having it compressed correctly) You are launching a 20 lb chunk of coiled steel , with more than half a ton of energy behind it all at once with a range of about 2ft.
    Pretty sure you can do the rest of the math..........:eek::eek::eek:
  11. May 13, 2011 at 10:23 PM
    x2468
    Vermont
    SHIT.... the center nut won't come off the stock strut.... it got to the last 2 threads and now its as if the threads are messed up because i can turn it either which way as much as i want and it won't go anywhere...
    wtf i hate this man... what now. i either grind the nut off or buy new retainers and wait for them to come in the mail...
  12. May 13, 2011 at 10:47 PM
    x2468
    Vermont
    AH! nvm.... i posted to soon. i switched from a socket wrench to a regular one and realized that instead of the nut turning, the entire shaft the nut was on was turning in the shock without me realizing it. so i clamped it down and got the nut off.
  13. May 14, 2011 at 12:35 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I tried to warn you of the dreaded "stud spin". That's why you break the nut before you break the taper joint.
    wait ... don't take off the strut nut before it's compressed. It gets really ugly if you do.
  14. May 14, 2011 at 3:58 AM
    x2468
    Vermont
    Alright i think i see why you said to disconnect the sway bar and loosen the upper ball joint, even though the idiot who wrote the service manual didn't suggest that. my buddy got home from a night of clubbin at 5:30 and him and I spent the last hour trying to force the lower strut knuckle in to place so that the bolt would line up. I didn't try the sway bar, but i took out the pin and nut for the upper ball joint that connects the two a-arms, but it didn't do anything. it was as if some phantom force was still holding it connected. is there something besides the large nut that holds it togethor? I really need to know before i try the next side.
    My friend and I finally managed to force the bolt in. However, we put the bolt in backwards. the service manual shows the bolt head facing the cv boot, and the nut facing forward.... Do you think it's a big deal that we put it in backwards?
    man i cant beleive it's 7am already... im gonna have to wake up at 10 to do the next side. I have work in the evening.
  15. May 14, 2011 at 4:06 AM
    x2468
    Vermont
    this might explain the phantom force holding the ball joint even after the nut was removed. I had no idea what you were talking about the first time i read this because i was going by the service manual. but now i think i know what you're talking about. so just hit the side with a hammer. what does that do? im looking at the microfiche for the upper ball joint and i cant see how a dust boot and circlip can hold that thing on there so well
  16. May 14, 2011 at 1:12 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The ball joint is held in by a taper on the bolt. Hitting the knuckle causes it to deform/vibrate slightly, this releasing its grip on the bolt.
    Make sure you have the nut on the bolt to keep it from launching. Jack stand stays on the frame with no jack on the knuckle.
    A 2-5lbs hammer will do the job. It takes a good, hard blow for it to work.
  17. May 14, 2011 at 6:41 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Skytower speaks the truth about it needing a good whack. It might take a few good whacks. Eventually it will break free and pop out. Have you finished the install yet? Oh and I wouldn't worry too much about the bolt being backwards. But if you can flip it without hassle you should.
  18. May 14, 2011 at 9:30 PM
    x2468
    Vermont
    I got the right side done yesterday with great difficulty. then had to go to work (took a different vehicle). just got home and im starting on the left side. im hoping to do the left side much quicker and easier now that i've learned more about the spring compressing tool. The tool was not designed with a coil and strut of this width in mind, which make it very hard to install and uninstall. But after wrestling with it all day yesterday i learned some tricks. really scratched the yellow and black paint up on the strut and coil in the process of learning. (the yellow paint on these OME struts looks really cheap btw. kind of a put off...)
    I wish the service manual pdf was more detailed. it didn't mention anything about disconnecting the sway bar or the ball joint. actually it didn't even have a removal page. it just said "repeat installation instructions in reverse".... ya right. putting the shock in was 10 times harder than taking it out.
    I took the bottom bolt out and turned it around because i had two friends to help me put it back in. I decided to turn it around because it looked like the longer side of the screw might hit the CV boot and puncture it. didn't want to take the chance. But the bolt required so much force to get out it almost ruined the threads!. i cleaned them up with a flat head screw driver and the nut twisted on all right with wd 40 after i swapped it around. didn't seem natural for it to be so difficult to put a bolt in. hope it functions correctly.
    its half past midnight. really hoping to have this done by 4 am because the GF wants to go to leave for the Keys at 7 and im pretty sure we're taking the truck because he AC is broken.
    im using my Dads torque wrench and it only goes to 80 ft/lb -110nwt/m. Some of the bolts require more torque, like the bottom knuckle of the shock, which require 135nwt/m. i twisted it to the highest my wrench would go, then a few more 1/4 turns. hopefully that'll be alright for a while until i can test it later.
    however the top three nuts on the strut tower i just cant seem to reach with the torque wrench. they require like 60 something newton meters. not sure how nervous i should be about them
  19. May 14, 2011 at 11:14 PM
    x2468
    Vermont
    but wait. after u use a hammer to disconnect it, does it require some special technique to reconnect?
  20. May 14, 2011 at 11:23 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I've taken my coils out lots of time but instead of taking the upper ball joint out I just remove the 4 bolts on the lower ball joint. I just keep my bottle jack under the LCA which is no biggy since it's the way I lift the front anyhow and just swing the whole spindle assembly back and you are good to go. Never had a problem doing it this way. It's easier than taking the top ball joint apart I think.
