Tips for Pulling a Uhaul transport trailer?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Xtrapops, Nov 3, 2023.
  1. Nov 4, 2023 at 9:21 AM
    Xtrapops
    Xtrapops [OP] New Member
    2022 Lunar Rock TRD Offroad
    Sure will be. It will be mid December so definitely gonna be glued to weather apps for the trip.
  2. Nov 4, 2023 at 10:34 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I should mention; This price was for enclosed transport (It is a classic car with perfect paint :tumbleweed:). - It is still crazy high... so I'll give it a few.
    Also I am going from MA to CA. (3,150 miles). - Can't get much further apart in the cont USA without getting wet...
  3. Nov 4, 2023 at 10:37 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Shipping costs are tied to the price of die$$$el.
    Trucks coming into California need to meet all sorts of emissions regulations, so shippers upcharge for that too.
    Is NY like CA?
  4. Nov 4, 2023 at 10:39 AM
    OZ TRD
    Central Coast CA
    Maybe I should price for a dropoff in NV or AZ... :D
  5. Nov 4, 2023 at 10:44 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    This time of year, you’re going to need to do enclosed transport unless you want salt all over your car.
    OZ TRD[QUOTED] likes this.
  6. Nov 4, 2023 at 10:57 AM
    OZ TRD
    Central Coast CA
    Agreed...
    I may wait until spring at this rate...
  7. Nov 4, 2023 at 1:58 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Thought the exact same thing. That was right after thinking it would be cheaper to sell the car and buy another at the destination. . . . . I mean, its a Fiesta.
    soundman98 and Chew like this.
  8. Nov 4, 2023 at 2:15 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    5000 lbs is near the realistic max you can tow with a Tacoma. You should be able to handle it as long as you don't overload the truck. That 5000 lbs assumes basically an empty tow vehicle with not much more than a driver. If you are planning on hauling 2-3 passengers and/or several hundred pounds in the bed you're going to go over your payload.
    You also lose about 3% of your engines power for every 1000' above sea level. If you're going to have to cross some of the high passes in Colorado your engine is going to be working HARD. A lot of those passes are 10,000'+. That's a 30% reduction in power while towing near max. You're going to be running in 3rd and even 2nd gear and running near 4000-4500 rpm to get over those mountains.
    Doing it in cooler weather will help. During the summer you have a greater risk of overheating.
  9. Nov 4, 2023 at 2:26 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Salt X
    Salt Terminator
    These are only two of the mini brands I know that wash with the salt and neutralize the corrosive properties
  10. Nov 4, 2023 at 3:16 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I'd rent a Ford V8 to haul that Ford
  11. Nov 4, 2023 at 3:36 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Contrary to popular opinion, I know of no scientific reason to use s-mode for anything other than engine braking.
    I’ve never rented a trailer from u-haul, but my experience with trailers kept in backyards leads me to think the lights are the most common thing to fail. Check them.
    Make sure the trailer has functioning brakes and be aware that your stopping distance is likely much longer.
    Check the tie downs at each stop. The payload might shift around and cause them to loosen.
    Be very aware of the trailer’s arc when turning. It’s really easy to cut a corner too sharp and have the trailer hit a curb or other hazard.
    Drive conservatively and be extra aware of the cars around you. Always use your turn signals.
    Backing up a trailer takes practice. If you are not proficient, avoid situations where it is required and if you cannot have someone spot you. Truck stops are the best places to get gas. Avoid small urban gas stations.
  12. Nov 4, 2023 at 6:56 PM
    Waterloo Wonder
    Waterloo Wonder Waterloo Wonder -
    Forrest
    New Hampshire
    21 Access Cab - Army Green,
    Are you picking up the trailer in CO and driving it one way? If so check out the cost of towing the trailer empty from NY and returning it to where you rented it. I had to move items from California to New Hampshire 4 years ago and the trailer was one-third the cost round trip from home than the one-way from California.
    soundman98 likes this.
  13. Nov 5, 2023 at 5:50 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Contrary to popular opinion, you know very little about automatic, transmissions, overdrive, and towing trailers. And you clearly don’t read the Toyota owners manual; it clearly states to tow in 4th gear with ECT on.
    A fried overdrive can an easy to diagnose with a transmission failure. The dealer will know the truck was used to tow with the overdrive and they will refuse your warranty claim upon a trans failure.
    The overdraft packs on these transmissions are very small. Using the sport mode of the transmission allows the driver to put the transmission in fourth gear, keeping it out of overdrive. Thus helping to allow the transmission to survive.
    Please don’t give out extremely poor advice.
  14. Nov 5, 2023 at 7:38 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Those canvas tarps, going down the road will destroy the paint on that drive.
    Who gives a shit about salt spray. Thousands of vehicles are driven and salts spray, and washed off.
    It’s not like he’s pulling a Ferrari
  15. Nov 5, 2023 at 7:40 AM
    #35
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Didn’t think of that - any flapping that did happen would damage it…. Never mind the suggestion OP! I have seen RV tow vehicle shields but they are solid. I’ve use those tarps on a utility trailer and on my bike carrier and they do well, but you are right about not using one on a car. I’d be worried about the exposed edges, they completely cover my bike so there is no issue. Thanks.
  16. Nov 5, 2023 at 7:47 AM
    #36
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Sorry, that actually came out a little harsh, I edited it.
    my point being, he really doesn’t need any kind of protection for that car whatsoever. There are products that wash Salisbury off and leave no corrosive residue.
    0xDEADBEEF likes this.
  17. Nov 5, 2023 at 7:59 AM
    #37
    twtaco$
    twtaco$ Well-Known Member
    If you’re worried about the weight get the tow dolly.
  18. Nov 5, 2023 at 9:10 AM
    #38
    gudujarlson
    Minnesota
    Read the owners manual more carefully. It says to use s-mode when engine braking, not all the time. You are free to do so, but it is not recommended by the owners manual. If you’ve only read an older version, read a newer one as they have clarified the statement.
    I don’t understand why there is this almost religious believe that you shouldn’t use gears above 1-1 when towing.
  19. Nov 5, 2023 at 9:14 AM
    #39
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Agreed. My dad and I tried so many different configurations of tarp and it’s so difficult to find one that doesn’t billow out or flap all over and beat the paint up.
    We landed on no tarp for the vehicle and then a rock guard on the front of the trailer, then just wash it when you get there.
  20. Nov 5, 2023 at 9:23 AM
    #40
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Get a trailer brake controller. Don't plan on going over 60-65 MPH. You might even have to go slower if the trailer tires aren't rated for higher speeds. Find that out before you tow it. Take a couple gas cans with you, as you're fuel economy is going to be complete crap due to the added wind resistance. Put some extra air in the rear tires to support the tongue weight. The lower speeds and fuel economy mean you will likely need to set aside about twice as much time for the trip as you are thinking.
    Fuel up in smaller towns and truck stops outside of big cities along the route. It's much less stressful when you can just stick to the right lane on the interstate through the cities and let everyone pass you.
    Stop and check your straps on the car in the first 50 miles and at every fuel stop.
