tips for restoring headlights
Discussion in 'Lighting' started by speedaddiktion, Jul 30, 2010.
  1. Jul 30, 2010 at 6:15 PM
    speedaddiktion
    speedaddiktion [OP] Well-Known Member
    Jaime
    Los Angeles
    08 Trd Sport 4x4
    Just wondering what techniques you guys use to get light scratches and oxidation/haze off your headlight lenses.
  2. Jul 31, 2010 at 11:54 AM
    speedaddiktion
    Jaime
    Los Angeles
    08 Trd Sport 4x4
    actually ended up using mothers headlight restore kit, came with the polish and a buffer pad which you attach to a drill. worked very well if anyone else is thinking of cleaning up their headlights i'd recommend it.
  3. Jul 31, 2010 at 12:11 PM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    nice! what is the cost of this treatment?
  4. Jul 31, 2010 at 12:24 PM
    speedaddiktion
    Jaime
    Los Angeles
    08 Trd Sport 4x4
    They had it on sale at kragen for 17.99 it usually runs about 25.
  5. Jul 31, 2010 at 1:09 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
  6. Jul 31, 2010 at 4:53 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ^ x2
    i used the 3m headlight restore kit...excellent. took out rock pics from my fogs! it comes w/ an attachment for a drill. you then use 600 grit, 1000 grit, 3000 grit, and finally a polish...take your time and it will come out just as new!
  7. Jul 31, 2010 at 4:59 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    That's good to know. Last weekend I was driving down the highway and a piece of tire debris got kicked up by the car in front of me and scuffed my right headlight a bit. It's not that noticeable but to me it sticks out like a sore thumb. I'm gonna give one of these kits a try.
  8. Jul 31, 2010 at 5:03 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    FYI, if you have a scuff, the 3m kit will be the only one that works because it has sandpaper attachments. like i said, it complete restored my fogs that had a ton of rock pitting on them. the mothers kit is only a light polish, which will most likely not get the scuffs out.
  9. Jul 31, 2010 at 5:07 PM
    iSTIZO99
    Jax, FL
    Thanks for the heads up...I'll look for that 3M kit.
  10. Jul 31, 2010 at 5:12 PM
    TheOtherGuy
    TheOtherGuy Well-Known Member
    Cajun Country
    05 Access 4x4
    I just did the headlights on my sisters 1998 lexus by using 2000 grit wet sand paper and mothers plastic polish and they turned out great. I wish I would have taken before and after pics because I amazed myself with the difference.
  11. Jul 31, 2010 at 5:15 PM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Nope, the Mothers headlight restore kit has 4 different grades of wet/dry sanding sponges in it.
  12. Jul 31, 2010 at 6:30 PM
    speedaddiktion
    Jaime
    Los Angeles
    08 Trd Sport 4x4
    x2
  13. Jul 31, 2010 at 6:34 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    [​IMG]BG headlight restoration kit
  14. Jul 31, 2010 at 7:10 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    correct, but you have to use those by hand no? w/ the 3m kit, every grade of sandpaper attached to the drill mount(there is velcro on the backside of every grade), so you sand w/ the drill...MUCH better then by hand IMO.
  15. Dec 15, 2010 at 1:14 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    The 3M kit, can you get that at a walmart? Or is it a pepboys kinda thing?
  16. Dec 15, 2010 at 1:34 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    I've always used 1000, 1500, then 2000 grit sand paper. Wet sand the plastic, then use some 3M rubbing compound.
  17. Dec 15, 2010 at 1:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if lights arent too bad......ialways use my mothers powerball mini and some plast-x...then go over with some normal polish. keeps them good and clean. any worse than normal...one of the actual kits is needed.....and its best to use a corded drill. i tried once with one of the kits and my cordless, but the rpms werent exactly right. still did ok tho.
  18. Dec 15, 2010 at 2:19 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    I think I just posted this in another thread, but after using numerous different techniques, the best I've found so far is from uglyheadlights.com
    Uses a wetsanding process like others, but the final coating is what sets it apart. A lot of kits, the yellowing/hazing will return, but the lights I've done w/ this kit have lasted over a year (as of now) w/o out any sign of the problems returning.
