Tips on how to improve gas mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota4life, Aug 6, 2010.
  1. Aug 6, 2010 at 10:52 PM
    Yota4life
    Yota4life [OP] Member
    Caleb
    Mississippi
    04 Prerunner TRD SR5
    Just wondering all of the small-big things i can do to improve gas mileage with my 03 tacoma. I am mostly wondering at what speed do these trucks get the best fuel efficiency, but ANY other advice would be great. I am getting about 17 mpg and I am all stock except 2 inch lift and 265 75 16 goodyear td tires which are beautiful so they are not going anywhere lol:D. Thanks for the help.
  2. Aug 6, 2010 at 10:58 PM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    Deck plate mod adds a little horsepower but nothing really proven for gas mileage. Just keep a light foot on the gas and you will be fine. I'd be happy with 17 mpg.. I have a heavy foot so i average 14-15mpgs
  3. Aug 6, 2010 at 11:09 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Dont drive unless you have to lol
  4. Aug 6, 2010 at 11:23 PM
    YotaComa
    YotaComa Well-Known Member
    NorCal
    2004 Tacoma Double Cab
    Purchase a completely custom carbon fiber body.
    Stop eating cheeseburgers.
    smaller tires would help too.
  5. Aug 6, 2010 at 11:50 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    drive slower on the freeway, dont do jackrabbit starts, use CC on the freeway, dont use A/C, dont carry around stuff in your truck if you dont have to, blah blah
    Also IDK what gears you have with those tires but maybe upping the gear ratio in your diff will help the engine not work as hard
  6. Aug 6, 2010 at 11:53 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    deck plate mod and a reaaallly light foot i also threw on a bed cover and got nearly 22 mpg on my 3.4
  7. Aug 6, 2010 at 11:58 PM
    RPain
    Chandler, Arizona
    I have no idea how ppl get more than 16 mpgs... even all highway driving with cc on I can't get more than 17 with my 3.4. wonder if something is messed up.....
  8. Aug 7, 2010 at 12:01 AM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    when you're going 75mph in the freeway are your RPM passed 2k?
  9. Aug 7, 2010 at 12:01 AM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    O2sensor ?
  10. Aug 7, 2010 at 12:07 AM
    RPain
    Chandler, Arizona
    ill check it out..
  11. Aug 7, 2010 at 12:07 AM
    RPain
    Chandler, Arizona
    and yeah they are past 2k
  12. Aug 7, 2010 at 12:15 AM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    how much passed it? mines is about 2200 at 75
  13. Aug 7, 2010 at 12:17 AM
    RPain
    Chandler, Arizona
    I'd say it's around 2400 but ill check for sure tomorrow.
  14. Aug 7, 2010 at 12:29 AM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    And where is this fuel filter you talking about?
  15. Aug 7, 2010 at 12:30 AM
    RPain
    Chandler, Arizona
    hmm so replace fuel filter and stop being retarded.. i can easily do one of those
  16. Aug 7, 2010 at 8:39 AM
    malander
    max
    01 limited trd 4x4
    22 mpg was driving like a grandma just to see how high i could get it that means 60 mph tops and trying to never break 2k rpms besides off of stops i find that on roads where the speed limit is 40-45 its better to just go 50 so it shifts into 4th and only hits 1600 rpm rather than 1900
  17. Aug 7, 2010 at 9:02 AM
    josh..
    josh.. Well-Known Member
    Sarasota, Florida
    '02 SR5 V6 4x4 Double Cab
    K&N drop-in air filter, body lift.
    Look on the inside part of the frame, about where the drivers side door is. Can't miss it.
  18. Aug 7, 2010 at 9:42 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    Well, I have a 2003 DC pre runner.. and i posted before that the best mileage I got was about 19... I just got back from a road trip from Los Angeles to Las Vegas... all highway, no traffic. I made a conscious effort to keep the speed between 60 and 65, which put the rpm's right about at 2000. I averaged 22.3 mpg on this trip. This was the best mileage I have ever recorded since owning this truck. Obviously the lack of stop n go was a huge factor, but I really do believe that keeping the speed down below 65 helped too.
    So, if you can help it, go a little slower on the highway, it should help, if just a little.
  19. Aug 7, 2010 at 9:51 AM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    When I'm doing 70MPH my rpms are by 3-3500, I have a 5spd manual tranny, should the rps be lower than that at that speed?
  20. Aug 7, 2010 at 11:47 AM
    Barnone
    Barnone Guest
    Sounds about 1K high to me. You must have regeared to be turning that high. MPG must be real bad?
