Tips on removing old hardened decals?
Discussion in 'Detailing' started by Tacoma13_NC, Nov 5, 2020.
  1. Nov 5, 2020 at 2:28 AM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    The TRD decals on the backsides of my truck are old, brittle, and peeling. The problem is what is still there is on there like it's clinging for life. I've tried using a hairdryer to warm them up, but they still barely come off at all. It's not the usual peal large pieces off or the whole thing like newer decals/stickers. Do I need to step it up to a heat gun? I know it's going to take some elbow grease, but damn I don't have a whole week to pick at these things either. Any tips on getting these decals off without damaging the paint? Thanks.
  2. Nov 5, 2020 at 7:59 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yes, I would step it up to a heat gun. You want it hot enough to melt the label and adhesive, but not hot enough to damage the paint. It's a fine line so take your time. If all else fails, use a blow torch and melt it off. Then go back and repaint your panel.
  3. Nov 5, 2020 at 8:05 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Goo Gone
    MGMDesertTaco likes this.
  4. Nov 5, 2020 at 5:45 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    Give a steamer a try. Not sure a heat gun can do any more than a hair dryer except generate heat faster or ultimately hit heat levels that far exceed damaging the underlying paint.
    I've used a rubber wheel to remove the business lettering decals on our old van when we sold it. It worked very well but it is is very easy to mar or straight up damage the underlying paint if you try to rush the job. Take your time if you go that route. Rubber wheel or heat gun be sure not to heat any given surface for an extended period of time.
    Tacoma13_NC[OP] likes this.
  5. Nov 5, 2020 at 5:52 PM
    gorram
    2016 Limited
  6. Nov 5, 2020 at 5:54 PM
    Tacoma13_NC
    Thanks! You got me thinking about the steamer. It makes sense in terms of softening the adhesive. I'm going to try some things this weekend and I'll check back with you.
    gorram[QUOTED] likes this.
  7. Nov 5, 2020 at 5:57 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
  8. Nov 18, 2020 at 2:19 PM
    Sandusky
    Sandusky New Member
    2017 Tacoma TRD Sport
    I saturated mine with baby oil on a warm day and used microfiber to rub gentle
  9. Dec 25, 2020 at 6:39 PM
    crbr
    crbr Well-Known Member
    east TN
    18 Sport / 93 Mastercraft Prostar 190
    3M Stripe Wheel is the bomb.
