Tips on removing seat backs
Discussion in 'Audio & Video' started by dangerbird, Aug 7, 2010.
  1. Aug 7, 2010 at 3:24 PM
    dangerbird
    dangerbird [OP] Well-Known Member
    Tacoma SR5
    I have a 2010 Tacoma that I need a little clearance for my sub. I know some people have removed the seat back, does it just pull off? Thanks
  2. Aug 9, 2010 at 8:18 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you are talking about the black plastic cover on the back of the seats, no, can't just pull it off. At the corner of each cover is a small cover that needs to be pryed off, then there is a screw under each cover. Remove both screws at the bottom, then the cover lifts off. Note that there are two "catches" at the top, lift the bottom up a bit, and pull the cover back. Done...
  3. Aug 9, 2010 at 10:23 AM
    dangerbird
    Tacoma SR5
    Thank you very much!
