Tips on towing 6x12 Uhaul 980miles...Relocating
Discussion in 'Towing' started by 1L2L, Jul 29, 2014.
  1. Jul 29, 2014 at 3:44 PM
    1L2L
    1L2L [OP] Member
    AJ
    St. Louis, MO
    13 Tacoma TRD Off-Road
    None as of yet, just purchased.
    Hoping anyone can provide some tips for me. I am relocating to Orlando, FL real soon and want to tow a trailer with all my belongings. Moving 2 bedrooms, living room couch/chairs, kitchen table/chairs. The total items should be under the 6500lbs. I have a 2013 dbl cab, short bed, 4x4. Moving thru relatively flat terrain from S. Illinois to Orlando, FL.
    I am sure the Tacome can handle this no problem, but I have never towed across long distances, only city limits. Is this a problem? What should I check on? Do I need a weight distributing system, or transmission cooler? Towing approximately 980 miles but will be stopping overnight along way, about a 2 day trip, in no hurry. Any information will be appreciated. I know the uhaul guys discriminate against Tacoma as if they can't pull crap for a trailer.
    Thanks!
  2. Jul 29, 2014 at 3:48 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    transmission cooler-yes
    6500lbs-really at the edge for towing safely
    weight distribution hitch setup-yes
    electric brake setup so you can use the trailers braking system activated by truck brakes when applied-yes...
    depending on height and width of trailer, mirror extensions....
    I am sure others will chime in with more suggestions...
  3. Jul 29, 2014 at 6:10 PM
    1L2L
    1L2L [OP] Member
    AJ
    St. Louis, MO
    Thanks. Weight should be well under 6500lbs. Not moving too much to be that heavy.
  4. Aug 6, 2014 at 10:25 AM
    1L2L
    1L2L [OP] Member
    AJ
    St. Louis, MO
    Should I get the weight distribution system AND the TRAILER SWAY KIT both? Or, do just need the WDS????
