Tips removing seized bed bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coffeeholic, Sep 20, 2019.
  1. Sep 20, 2019 at 10:19 AM
    Coffeeholic
    Coffeeholic [OP] Well-Known Member
    2005 Tacoma TRD
    Does anyone have tips for removing seized bed bolts, other than the usual spraying PB Blaster and letting it soak? I've only managed to loosen 1 of the 6 bolts so far. I've tried, a battery impact, a pneumatic impact, socket wrench with a steel pipe for extra leverage, but they don't seem to want to budge. Trying to avoid drilling them out if possible
    1997TacomaSR5 likes this.
  2. Sep 20, 2019 at 10:20 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Drill and tap.
  3. Sep 20, 2019 at 10:21 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    this is where I fear I'll end up be when I return to my rear diff bolt again. The one fukin thing annoys me more than anything is seized bolts. I remember grinder wheeling shock bolts off my old dodge after completing what you've had to do above.
  4. Sep 20, 2019 at 10:25 AM
    Coffeeholic
    2005 Tacoma TRD
    The heads aren't stripped or anything, so what advantage would drilling and tapping have if the hex head is intact?
  5. Sep 20, 2019 at 10:30 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Soak them really good. Maybe some heat from a propane torch.
    GQ7227 likes this.
  6. Sep 20, 2019 at 10:32 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    BIGGER cheater pipe or impact.
    Hunt/Taco, underaroof and DrZ like this.
  7. Sep 20, 2019 at 10:32 AM
    Coffeeholic
    2005 Tacoma TRD
    I'm trying to avoid the propane torch, as one of the reasons to remove my bed is to replace my leaking gas tank, but they've been soaking already for quite some time
    1997TacomaSR5, GQ7227 and cosmicfires like this.
  8. Sep 20, 2019 at 10:35 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  9. Sep 20, 2019 at 10:35 AM
    Coffeeholic
    2005 Tacoma TRD
    My impact is 650 ft/lbs of torque, and my cheater bar is a 6 ft long steel pipe, so pretty big/powerful already
  10. Sep 20, 2019 at 11:09 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    If the rest soak hasn’t worked in 72 hours, it removes the fused material formerly known as a bolt without burnishing the surrounding surface like a torch.
  11. Sep 20, 2019 at 8:00 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Rent a 1450 ft-lb impact gun. :D
    I have a 650 ft-lb gun and it struggles to take the lug nuts off.
  12. Sep 20, 2019 at 8:06 PM
    1997tacomav6
    Denver
    I think the bolts on the bottom are welded on so you will not get those ones off.
    Hopefully your not trying to remove the weld bolts?
  13. Sep 20, 2019 at 9:42 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    we get them off with a 1/2" impact after soaking for a we bit. Loosen a little, tighten, loosen, tighten, loosen, tighten, etc till it comes out.
    no broken bed bolts yet after loads of frame swaps
    GQ7227 likes this.
  14. Sep 21, 2019 at 1:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Depends on how bad your fuel leak is a Electric anything can arc enough to ignite fumes .
    Speaking from experience !!
    You are going the correct direction I still get messed up being upside down not knowing left from right does not help me though
    JPinFL likes this.
  15. Sep 21, 2019 at 3:10 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Yup. Upside down and reaching from the back at a weird angle with your less dominant hand.
  16. Sep 21, 2019 at 5:08 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Just drop the tank.
    Rachelsdaddy and 1997tacomav6 like this.
  17. Sep 21, 2019 at 5:14 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I got mine off with an impact wrench set to low torque. It just kept pounding at them and they finally let go.
  18. Sep 21, 2019 at 6:27 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Clockwise is always going away from you, so if you're reaching under for a bolt that needs to go toward the ground but you're looking from above then you want clockwise. If you were laying on the ground looking up you'd want counterclockwise. Counterclockwise always brings the nut/bolt toward you. That's how I think about it when working at odd angles. (This applies to normal right-handed threads.)
  19. Sep 21, 2019 at 7:41 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Like this guy said, or put the pipe back on it with a six point socket. Put some ass into it.
    mechanicjon[QUOTED] likes this.
  20. Sep 21, 2019 at 10:25 PM
    Coffeeholic
    2005 Tacoma TRD
    Finally gave up trying to take the bed off after the welded nuts above snapped loose, leaving my bed bolts spinning. Rust is a b*tch. Going ahead with my frame repair without taking the bed off, and so far so good
    Chadley22 and DPTacomaGuy like this.
