Tire advice for stock TRD Sport 07
Discussion in 'Wheels & Tires' started by jedvf114, Mar 29, 2009.
  1. Mar 29, 2009 at 11:36 PM
    jedvf114
    jedvf114 [OP] New Member
    San Diego
    TRD Sport 2WD Speedway Blue
    I want a little bigger tire without rubbing and I am not looking to get a lift yet. I have been considering 1st Nitto Terra Grappler, 2nd Yokohama Geolander AT-S, 3rd Mickey Thompson Baja ATZ. My current tire is 265 65R 17 I have been told 275 65 17 would be good with out rubbing and if I go to a 285 they might rub. Any advice would be greatly appreciated. Also I like Evans tire but not sure they carry these tire brands any info on place to get them in north San Diego. Thanks.
  2. Mar 30, 2009 at 5:10 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    I'm running 265/70/17's on my '07 TRD with no lift(yet).This is 1/2 an inch higher on the sidewall for an inch taller tire overall.It looks great,fills out the wells nicely and there are no rubbing issues whatsoever.
  3. Mar 30, 2009 at 5:23 AM
    Joe B
    Joe B Well-Known Member
    Any difference in the ride with the 265/70/17s?
  4. Mar 30, 2009 at 7:12 AM
    squad314
    Marc
    Seems smoother Joe....Taller sidewall=more compliency perhaps?
  5. Mar 30, 2009 at 7:40 AM
    Joe B
    Sounds good Squad,thanks..:)
    I may be going for that 1/2 an inch higher on the sidewall and inch taller tire overall look with the .85 little lift from Billies and the spring TSB..
    Maybe with a Michelin LTX A/T2 this time.
  6. Mar 30, 2009 at 7:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I hate metric sizes.... but isn't that width?
    265/70 r17 would be wider than 265/65 r17?
  7. Mar 30, 2009 at 8:02 AM
    Joe B
  8. Mar 30, 2009 at 9:05 AM
    squad314
    Marc
    Jan,my understanding is that the 70 represents the % of the width......So the tread width is the same,but the increase comes from going from 65% to 70% of that width in sidewall height......The 265/70/17 equals a 31.5.
    Joe,that lift will look great.I'm awaiting delivery of my Billies set at 2.5 and 1.5 blocks for the rear.My Canadian truck has a stock 4 leaf pack so I'll be about 2.5 all around.
    Edited to add:Found this:
    Several numbers and letters on the tire sidewall indicate the tire size. For example, on a P215/65R17 tire designation, the P indicates Passenger Vehicle use. The letters LT would indicate Light Truck, which typically has a higher load carrying capability. The next group of numbers, 215, are the width of the tire in millimetres, while the 65 is the aspect ratio of the tire. This means the tire sidewall height is 65% of the width of the tread
  9. Mar 30, 2009 at 7:11 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    The 265\70 would be the bigger tire in height wise. if im not mistaken
  10. Mar 30, 2009 at 7:25 PM
    collin99
    collin99 New Member
    You are correct. Someone asked earlier about any difference noted from stock. I find the steering slightly less positive. Truck reacts a little more to road surface and wind, I believe, because the taller sidewalls flex a little more than stock.
  11. Mar 31, 2009 at 6:14 AM
    Joe B
    A Tire Rack rep told me the tires would flex more on turns so you would lose a bit of handling going up to a 70 series.
    He said he didn't recommend the 70 series and stay with the 65.
    I'd love to read more actual driver imput on this.:)
