Tire Advice Needed - kind of long
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Horndog, Oct 16, 2014.
  1. Oct 16, 2014 at 11:11 AM
    Horndog
    Horndog [OP] Active Member
    A ton of tire threads I know, but I will ask for tire adviceanyway… Have a 2013 TRD. Last winter with about 2” of new, fairly wet snow, Iwas driving down to the main road. Going slow, I turned at a curve, but mytruck decided to only kind of turn. I bounced off the curb on the left side,went through a driveway, and finally stopped in front of a tree 6” from the bumper.It was then I decided the stock BF Goodrich Rugged Trails (only 3,000 miles onthem) had to go, at least during the winter. I could probably get by and justdrive slow, but if it happened to the wife, she would not ever drive again in thesnow.
    My dilemma is this. I go from 2800 ft. elevation – where itrarely snows, to 4500 ft. elevation at my house where it snows quite a bit, in a4 mile drive. County tries to plow, but usually leaves a layer that turns to ice.Our road is last in the plowing order, so sometimes it takes them a day or twoto get here if it snows low.
    Then my driveway…. It’s a mile at 16% which can be slickclay, to snow, to ice at different areas all on the same day
    Usually get snow anywhere from a couple inches to 18” plus. Itcan melt in a couple days, or stay for a couple weeks depending on the weather. (California)Used to just park at top of driveway, but getting to old for that now.
    So…. for tires, I think dedicated winter tires are overkill …althoughI’m sure the wife would love them. She does not do well on ice.
    Guess I’m looking for that all weather tire that probably doesn’texist; good on wet & dry, good in snow and good on ice. I don’t do any off roaddriving. There seem to be a lot of Duratrac fans, but they seem a little pricyfor me. Any other recommendations?
  2. Oct 16, 2014 at 11:42 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  3. Oct 16, 2014 at 11:47 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I like the dedicated snows on their own rims. I worry less about sliding and bending a steel wheel. I also like Blizzaks, great traction on compact snow and ice. the downside is you shouldn't run them all year, but that's another reason for dedicated winter rims.
  4. Oct 16, 2014 at 11:56 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    For a cheaper and fantastic option, look at Cooper tires. I loved them on my last Tacoma. Discoverer AT3's are what they are called. They were decent in the snow, not too loud on the highway... a good mix and if I recall around $160 a tire. That isn't bad.
    I'm a big Michelin fan but if I don't have $1000 when it's time for new tires I will look at Coopers again.
  5. Oct 16, 2014 at 2:27 PM
    Horndog
    Dedicated winter would be ideal, but as I'm only driving about 4 miles max until I'm out of the snow, and down into warmer conditions, I'm a little worried about the wear. I had my mind made up to go that way with the Blizzaks on separate rims, then I started think about wear, cost of tires plus wheels, TPMS..........
  6. Oct 16, 2014 at 5:16 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I just picked up a set of Cooper A/TW tires. I don't have the money or the storage room for a separate set of winter tires. I'm hoping these are a good compromise. Basically a winter all-terrain tire that can be driven all year. We'll see.
  7. Oct 16, 2014 at 6:11 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Michelin MS2's or Hankook Dynapro ATM RF10's
    I had the MS2's on my old chevy, and would regularly go to the local ski resort (mt high) via the back windy mountian road, and i always played lets see how far i can get in 2wd, VERY rarely did i need 4x4. Buddy has the RF10's and LOVES them on his chevy in the snow n ice, and its what im going with on my taco for this winter to get rid of the rugged fails, i like the more aggressive look of them over the MS2's
  8. Oct 16, 2014 at 6:14 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    Michelin LTX/MS2s, do not waste your time with anything else...
    i use them on everything (except full offroad), climb through VT snow at 4000' and at home at sea level. they are quiet, smooth, stick in the rain and snow like you wouldnt believe.
  9. Oct 16, 2014 at 8:28 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    General grabber AT2 is my next tire.
  10. Oct 16, 2014 at 10:34 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    For as steep as your drive is, chains or studs may be in order if you get the freeze / thaw like we do here (about 3k feet). I have a first gen Tundra that is pretty close to the same size as the newer Taco's and have been running the BFG Rugged Terrain Tires for about 2 years now (not to be confused with the Rugged Trail Crap that came on the truck). Have had it in some deep snow and it surprised even me....drove right out. Much better snow tires than the BFG AT's I used to run. For a mainly street driven vehicle they work great and have done well in everything I have tried so far (haven't done much mud, but they aren't mud tires). Mine are 265-70-17's and were about $750 M & B from America's Tires vs the $1200+ they wanted for the AT's. They are P metric not LT rated tires and come with a 50k wear wty. Very happy with them so far.
  11. Oct 16, 2014 at 10:39 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    You like the A/TW's?
    I just got a set of 235's for dedicated winters that I can also use as off-road tires when my Michelins will be a little too highway. I am getting them mounted on Sunday.
  12. Oct 16, 2014 at 11:12 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    DURATRACS
    Its an all terrain tire, that is also snow rated
    I run mine all year long, currently have over 50k on them.
  13. Oct 17, 2014 at 2:46 AM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    X2. I was surprised at how well my Duratracs did in the snow and ice last year. I never even added weight in the back last year.
  14. Oct 17, 2014 at 3:19 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    I use Hankook Dynapro AT/m all year long in VT/NH and never have an issue. No matter what tire you have you will need to adjust your driving when on snow/ice.
  15. Oct 18, 2014 at 4:59 PM
    Horndog
    The Hankook's are sounding good.
    Does anybody have any experience with Firestone Destination AT's?
  16. Oct 18, 2014 at 5:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have Hankook ATm's and I'm not impressed with their performance in the wet coastal snow we get here , my MT's were better
