Tire Advice
Discussion in 'Wheels & Tires' started by PEPCATCH11, Oct 13, 2011.
  1. Oct 13, 2011 at 8:56 AM
    PEPCATCH11
    PEPCATCH11 [OP] Well-Known Member
    Dan
    Tulsa, OK
    2011 Regular Cab
    TRD skid plate, Bilstein 5100 struts @ 2.5", Bilstein 5100 shocks, Wheeler's 1.5" AAL, Spidertrax 1.25" wheel spacers, BFG KM2 285/75/16
    2011 Regular Cab 4x4...I have 5100's @ 2.5" installed on the front using the stock springs and a 1.5" AAL with 5100's on the rear, everything else is stock. I would like to run a 285/75/16 BFG KM2 on the stock steel wheels...I have a set of the spidertrax 1.25" wheel spacers on order. Will this be possible??? If so, what other modifications will I have to do? Thanks everyone! Dan
  2. Oct 13, 2011 at 3:39 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    re-gear or motor swap.those things will really make that 4cyl work.
  3. Oct 13, 2011 at 3:41 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    youll have to trim a bit and possibly do a cab mount but itll work. might want to consider re-gearing to get power/mpg back as well
