Tire advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco11179, May 10, 2022.
  1. May 10, 2022 at 11:06 AM
    Taco11179
    Taco11179 [OP] Well-Known Member
    Jake
    2022 Tacoma SR5 Double Cab 6 foot bed
  2. May 10, 2022 at 11:17 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    These Michelin’s wear like steel, could easily get 70-80k outta them. Probably the best tires for pavement use.
    Or you were asking how long OEM tires last? Not long usually, 30-40k or so.
  3. May 10, 2022 at 11:18 AM
    Taco11179
    Jake
    I don't do any off-roading unless hunting up in the woods. It's mostly road use, hauling, back and forth to work, etc.
    Junkhead likes this.
  4. May 10, 2022 at 11:20 AM
    avn
    avn Well-Known Member
    A
    CA
    2022 TRD OR
    I’d recommend not buying tires until you’re close to buying a new set. The rubber won’t last forever even when stored under ideal conditions. By the time you wear your current tires the “new” tires may not be good anymore.
  5. May 10, 2022 at 11:20 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Those Michelin’s would be a perfect choice for you then.
  6. May 10, 2022 at 11:21 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Good point, didn’t think about that.
  7. May 10, 2022 at 11:23 AM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I second the vote for Michelin tires. I had a set on my 2001 Dodge Cummins diesel truck, they were the LTX M/S tires (same tires you posted link to), OEM from the factory. Most of my driving was pavement, with an annual hunting trip with some off road driving. I replaced the original Michelins at 108K miles and about 8 years on them, because I thought the sidewalls were starting to crack. They still had at least 1/3 tread depth left. I wanted a more aggressive tread pattern for my Tacoma, otherwise I would have replaced my OEM Goodyears with these Michelins without even thinking about it.
  8. May 10, 2022 at 11:24 AM
    avn
    A
    CA
    2022 TRD OR
    If you really want new tires buy them, get them mounted, then sell your OEM tires to recoup some of the cost. They will sell quickly if new on Craigslist or Facebook or any local listing site of your choice.
  9. May 10, 2022 at 11:25 AM
    Taco11179
    Jake
    I was thinking that these (Toyo) tires would only last 20k miles...
  10. May 10, 2022 at 11:25 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Tires have a date stamp and should be replaced somewhere between 6-10 years old even if they've never been used. Rubber deteriorates over time. Tires used in hot sunny climates will be dangerous after about 6 years. If kept garaged in the shade, and especially in colder climates where they see little direct sunlight then closer to 10 years.
    If you think you can use them before the date runs out on them and if the price is right go for it. Otherwise no.
    Big tall dave and Taco11179[OP] like this.
  11. May 10, 2022 at 11:27 AM
    Taco11179
    Jake
    I did not know any of that information, thank you for that. I would probably store them in the basement if I were to buy.
  12. May 10, 2022 at 11:27 AM
    coma toy
    coma toy Off Road Taco
    I sold my OEM tires and upsized to a better tire.
    Sell them while they are new
    zoo truck and Junkhead like this.
  13. May 10, 2022 at 11:42 AM
    Taco11179
    Jake
    Tocamo likes this.
  14. May 10, 2022 at 11:58 AM
    avn
    A
    CA
    2022 TRD OR
    With only 2200 miles put em up for 600 OBO and I personally would accept 350-500, take good pics and post the manufacture date so people know they’re new when they’re looking for used tires
    Tocamo likes this.
  15. May 10, 2022 at 2:07 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Buy your tires when you need them. Tires will age sitting around which is as bad as some dealers selling older stock at bargain prices, then you wonder why tires you just bought are weather cracking after a year or two.
    RustyGreen likes this.
  16. May 10, 2022 at 2:11 PM
    zoo truck
    None
    I did the same as i already bought new tires for my gen1 tundra a month earlier before deciding to sell the truck. I put those tires on my new tacoma, and sold the oem ones.
    coma toy[QUOTED] likes this.
  17. May 10, 2022 at 2:22 PM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Are you wondering about future availability of tires in the stock size of 245/75R16? Or that Michelin will discontinue their best-selling road tire for decades that comes in every size under the sun?
    The answer to both is "nothing to worry about." If either of those things comes to pass it's because society has crumbled amidst catastrophic global nuclear conflict, in which case you don't need new tires because you'll only have the gas left in your tank lol.
    FWIW tires look small when they're on your truck, but once you stack four of them in your basement you'll wish you just waited.
    Tocamo likes this.
  18. May 12, 2022 at 9:31 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    my factory 245 goodyears went almost 40k and i replaced them with Cooper AT3 4S and am on my second set and got almost 50k out of my 1st set.
