Tire advice
Discussion in 'Wheels & Tires' started by Bkicks333, Nov 3, 2022.
  1. Nov 3, 2022 at 3:03 PM
    Bkicks333
    Bkicks333 [OP] Well-Known Member
    James
    Trd offroad 4x4
    Went to DT to try on some 285/75/16 to see if I needed to do a cmc before getting new tires. The ones they had available to try on were the ko2. Not really any rub just in full lock against mud flaps. I was pretty set on the geolander M/T but driving an hour everyday to and from work the manager said they wouldn't be a good fit. So next was the nitto ridge the weights were way above the others I was looking at.
    Mickey Thomoson is up next with baja boss at $307 right under 33" and I think at about 67lbs.
    My dilemma lies im yes I'll be driving an hour (highway) to and from work everyday but will be offloading my days off 2 a week or taking trips up to Ruidoso, cloud croft, etc. Am I missing any potention winners here? For $305 a tire and at3s being like 266 that quite a difference for 5 tires.
  2. Nov 3, 2022 at 6:54 PM
    Bkicks333
    James
    Trd offroad 4x4
    Well I may have figured this dilemma out. I was about to pass on the nittos because discount tire said 73 lbs yikes. After looking in nittos site they're only 61.66
  3. Nov 3, 2022 at 7:01 PM
    Bishop84
    Bishop84 Well-Known Member
    73#!!!! HOLY MOLY I never knew they weighed that much.
    Don't do M/T's for that much driving every day.
    KO2's would probably be fine and give more of an aggressive sidewall look.
    Toyo AT3's are a solid choice, but like Falken AT3W's they look a little "tame" if that matters.
    Bkicks333[OP] likes this.
  4. Nov 3, 2022 at 7:08 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Do yourself a favour and get a second set of wheels and some p rated 245's for commuting. Someone is probably selling some on stock alloys for $2-300. Not sure how much gas is where you are, but they'l pay for themselves in a year. Why waste good rubber, lose acceleration, mileage, create more noise and wear on suspension commuting on A/T's or M/T's? Takes under 20 minutes to swap wheels.
  5. Nov 3, 2022 at 7:08 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    I would take the Nittos over BFG anyway. IMO nitro makes a better tire that lasts longer and performs just as well on highway as it does off road. Just my experiences. I also live in Arizona and have seen the ko2s wear down quick. The terra grapplers are a solid choice for what you’re talking about. Not the most aggressive sidewall, but available in your size, affordable, great on road (I have the same tires and a similar commute) and handle well off road seeing as it’s an E rated tire. I’ve aired mine down to 18psi on my stock wheels with no issue
  6. Nov 3, 2022 at 7:11 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    screen shot from a video of me climbing a granite hill with nitto terra grapplers at 18psi.
  7. Nov 3, 2022 at 7:28 PM
    Bkicks333
    James
    Trd offroad 4x4
    Edited with pics* I think discount tires weights are off
    MulletTaco likes this.
  8. Nov 3, 2022 at 7:30 PM
    Bkicks333
    James
    Trd offroad 4x4
    We have similar terrain so I'm on board with you. Not a fan of the ko2 but for the test fit it was either that or a cooper. The guy was trying to out me on some nitto recons but they don't have the size I needed available yet :mad:
    MulletTaco[QUOTED] likes this.
  9. Nov 3, 2022 at 7:34 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    The Terra’s are a great, affordable, abusable tire.
  10. Nov 3, 2022 at 8:02 PM
    Bkicks333
    James
    Trd offroad 4x4
    Going to read u a hit more in those
    Right now I'm between ridge grappler, baja boss or legend exp or grabber atx. Hopefully the list can get smaller and not larger :rofl::rofl: so I can order some Damm tires
  11. Nov 3, 2022 at 8:05 PM
    Bkicks333
    James
    Trd offroad 4x4
    235 a tire??? Got any side pics what size are you running?
  12. Nov 3, 2022 at 9:23 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    Just the 265/70r17s currently
    best side wall pic I’ve got. Like I said, not the most aggressive but still a good tire. I love them
    edit: when I go to 35s I’ll be getting the same tire
  13. Nov 6, 2022 at 11:25 AM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    I had Ridge Grapplers for about 15k miles and they cupped or feathered, what ever the proper term. They got pretty noisy and I balanced them often and aligned the truck far too many times in that year. Just my experience. I had the E rated too. Not sure why they wore bad like that but It made them super loud. A friend put on the Toyo AT3’s and said for daily driving they were fantastic. C rated I believe.
  14. Nov 6, 2022 at 1:39 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    Put 70.8 off road miles on my TGs yesterday handled great in the mud and snow.
