Tire Air Chuck recommendations
Discussion in 'Off-Roading & Trails' started by BKinzey, Jun 24, 2020.
  1. Jun 24, 2020 at 7:16 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
  2. Jun 24, 2020 at 7:27 PM
    Shellshock
    Iowa
  3. Jun 25, 2020 at 10:50 AM
    BKinzey
    Beauford
    Hollywierd, CA
    Thanks for the link, lots of good info there.
    I see a potential problem. I picked up a used Viair 400c and I am changing it to be portable instead of mounted. I won't be using a tank and instead of a pressure gauge mounted on the pump I thought I could get away with a gauge mounted on the chuck, like the ARB. The ones I'm looking at have a trigger on them that needs to be held for air to pass through the chuck.
    This means I have a closed system with a volume limited to the hose when it's hooked up and I turn the pump on I will have a limited time to move to the chuck and hold the valve on. Every time I release the trigger to check the pressure or to shut the pump off I will be creating a closed system again. I don't think that's a good idea. How should I address this?
  4. Jun 26, 2020 at 8:04 PM
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    Use open flow clip on chucks like these and then get a separate air gauge. Then you won’t have to sit there and hold the trigger. Just clip it on and relax.
    AstroAI Air Chuck, Heavy Duty Open Flow Lock On Tire Chuck with Clip for Inflator Gauge Compressor Accessories, Yellow https://www.amazon.com/dp/B078WVQTN6/ref=cm_sw_r_cp_api_i_jCR9Eb7K1S0RE
