Tire Air Pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mavrick, Aug 10, 2015.
  1. Aug 10, 2015 at 4:36 PM
    Mavrick
    Mavrick [OP] Well-Known Member
    2015 DCSBOR
    The sticker in my door says to run the fronts at 29 psi and the rears at 32psi. I just bought my truck new (DCSB OR) and the dealer/factory had them all at 39 psi. I'm not sure why they had them so high but wanted to double check that I should run them at 29/32 psi.
  2. Aug 10, 2015 at 4:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Because the guy putting the air in can't read. Or was hung over. Or texting. Or doesn't care much about his minimum wage job.
    You're lucky they were that low. Some knuckleheads think the max pressure on the sidewall is the go-to number.
    And points to you for being smart enough to check them. Recommend you check everything else too. Including fluid levels. And your spare.
  3. Aug 10, 2015 at 4:47 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Yup, my dealership puts mine at 35 psi....I know it's not a big deal but if a dealership can't get something as SIMPLE as tire pressure correct, what are they doing to my engine?
  4. Aug 10, 2015 at 4:47 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    I keep my stock tires at the manufacture recommendation. 29 front and 32 rear.The truck drives great. I think 39psi is high.
  5. Aug 10, 2015 at 4:51 PM
    TimsTaco
    TimsTaco Well-Known Member
    Tim
    Moncton, NB
    07 DCLB SR5 Sandstone Metallic
    OEM Fog lights, headache rack, work lights, Tailgate Theft Deterrent (hose clamp), Tailgate Reinforcement, Roll'n'Lock tonneau cover, OEM Inverter
    You should be fine at 30 psi for all the tires including the spare.
  6. Aug 10, 2015 at 4:51 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    This
  7. Aug 10, 2015 at 4:54 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Who to blame? Guy in the factory? Dealership for not checking?
    Personal opinion:
    Get your tire rotation person to set your tires 3-5 pounds over what you really want because:
    1. Your tires aren't "cold" when he does service, unless you left the vehicle overnight.
    2. His gauge might not be accurate.
    3. Drive home, and first thing the next morning lower pressure to your preference before sun is on the tires and before you drive.
    4. Keep and use an accurate digital gauge, check at home once a month or if ambient temperature changes drastically.
  8. Aug 10, 2015 at 5:23 PM
    Mavrick
    2015 DCSBOR
    Good to know, I did check everything else as well.
  9. Aug 10, 2015 at 6:08 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    The answer is obvious assuming you have factory stock tires. Later tonight or tomorrow morning when the tires are cold, set them to the correct pressure. Done.
    Edit - not done, sorry. Then chalk test them to verify that the pressures are set to maximize wear. Im guessing that when empty those pressures are reversed. But remember that as you increase weight over stock you will need to add pressure. And if you haul anything heavy you will also need to add pressure to the rears. Good case for having a good 12V pump behind the seat even if you don't plan to air down and up for offroading. The 30 amp MV-50 and MF-1050 pumps do a great job for periodic use and only cost 50 to 70 bucks.
  10. Aug 10, 2015 at 7:32 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I've got aftermarket Michelin LTX M/S 2's on my Tacoma. Toyota dealer that sold them to me set them at 36psi (max is 44 I think?). Anyhow, I fiddled with them and when they did my first oil change and rotation their paperwork specifically said they set them all at 36psi. At least they are consistent?
  11. Aug 10, 2015 at 7:37 PM
    badger
    badger Well-Known Member
    07 SR5
    Most all tire shops and service shops set the pressure high now for liability reasons. Under inflated tires are more susceptible to failure. Remember the Ford / Firestone fiasco?? The higher pressure does prevent catastrophic failure, but it does impact ride quality, handling and tire wear. The best alternative is CORRECT pressure, and that is why no one checks my tires but me.
  12. Aug 11, 2015 at 10:51 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Once upon a time they did that. Some years back they all started going by the sticker inside the door. That's what's been going on in my area for quite some time now. Maybe it's different elsewhere.
  13. Aug 11, 2015 at 10:57 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    chalk test
  14. Aug 11, 2015 at 12:03 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    There's a million opinions on pressure. I've tried several combos, but what works best for me is 33 front/ 32 rear with stock 265/ 70/ 16's.
  15. Aug 11, 2015 at 12:06 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I've recently started running my LT265/75-16 E load tires at 40 psi, mostly for fuel economy reasons. But stock tires I'd run what the door sticker said.
  16. Aug 11, 2015 at 12:16 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I do 29-32 like the sticker says.
  17. Aug 14, 2015 at 2:42 PM
    Ukeboy
    Ukeboy Member
    Wisconsin
    '08 Access Base
    Laser Guns
    The dealer did that to mine as well, 36 all around, door tag says 29/32.
    They also insisted 0w20 wasn't suppose to be in my engine, even when we read the 2008 owners manual that states 0 focking W focking 20....and suggested my fill cap had been replaced, as it reads 0 and 5w20...
  18. Aug 14, 2015 at 5:37 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    I used to run mine at recommend psi, have now bumped up to 35psi all around for improved mpg, I've averaged about 24 mpg the last two tankfuls at almost 100% city driving
  19. Aug 14, 2015 at 5:52 PM
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    yeah...I have a 2014 Limited and the door sticker says 29 psi all the way around, but every time I leave the dealership, they are set at 35 psi on all 4 . WTF..
