Tire air pressure...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by harryk, Apr 8, 2016.
  1. Apr 14, 2016 at 3:49 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    I wounder it the dealer added that tire pressure? I that would be something that they would have in the dealer's PDI.
  2. Apr 14, 2016 at 3:57 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I'm sure just another example of toyota trying to meet CAFE requirements. You know just like the crappy 3.5L/6spd tranny option
    James_Bond[QUOTED] likes this.
  3. Apr 14, 2016 at 4:16 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I know this may be the wrong thread to make a rant.
    But I'm starting to get fed up with all these emission standards.
    Don't get me wrong, I'm all for a clean air and a clean environment. But what does it even matter if we have countries like Egypt and China that have more than double the pollution than the US?
    If anyone cares...
    http://www.numbeo.com/pollution/rankings_by_country.jsp?title=2016
    smitty99[QUOTED] likes this.
  4. Apr 14, 2016 at 6:32 PM
    jlaurence32
    jlaurence32 Well-Known Member
    Colorado
    2016 MGM TRD Sport 4x4 DCSB
    Mine were 38/40 psi when I drove home from the dealer. On the freeway the truck would start vibrating at certain times enough to shake my love handles! Thought something was wrong. Got home, checked the pressure, put them down to 29psi and everything was fine on the next freeway trip. Alot smoother over bumps now too. Amazing what too much air pressure does... BTW got the 17" Toyo's on the Sport.
  5. Apr 14, 2016 at 10:22 PM
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    I know this is a stupid question but WTF is a "chalk test?"
  6. Apr 14, 2016 at 11:27 PM
    Tdog23
    Tdog23 Well-Known Member
    Tom
    2017 TRD Off Road 4 Door Inferno
    What is a chalk test & how do you do it? I have never heard of it & would like to try it. Been running 29 cold but seems like the tires are wearing to fast.
  7. Apr 15, 2016 at 1:06 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Take a tire crayon and draw a line on the tread surface from inner sidewall to outer sidewall . Make (2) markings at 180* apart from ea other
    Do this on both front/rear axles then drive your Truck around the block a couple times until tire press is warm . Now examine your markings , if your markings is completely clean your tire press is correct . If the center is wiped clean this means over inflation . If the edge of the markings nearest the sidewalls is wiped clean then you're under inflated
    Keep adjusting air press until the tire crayon marking is wiped clean . This will be your tire press you will use . Remember do this with the tires at operating temp not cold
    Just for an example on my old jeep rock crawler which was a 1968 M38A1 and running 33/12.50 -15 TSL Super swampers . The tire mfg recommended 45 psi but after doing the tire crayon trick my corrected tire press was 25 psi
    I even did this on my 72 Camaro when I was running M/T N50-15 tires . The tire mfg recommended 35 psi but after doing the chalk line trick my corrected tire press was 18psi . I'm even doing this on my new 275/60-15 M/T Drag Radials
    James_Bond likes this.
  8. Apr 15, 2016 at 7:16 AM
    Tdog23
    Tom
    Thanks
  9. Apr 15, 2016 at 8:21 AM
    docsg
    South Alabama
    Thanks again from the "WTF" questioner:thumbsup:
  10. Apr 15, 2016 at 11:09 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
