Tire and MPG question
Discussion in 'Wheels & Tires' started by SickNaban, Apr 8, 2013.
  1. Apr 8, 2013 at 9:08 AM
    SickNaban
    SickNaban [OP] Well-Known Member
    Huntsville, AL
    10 PreRunner SR5 Double
    For the guys who upgraded from stock 245/75/16 to 265/75/16, how much of a hit did your mpg take?
    I know that tire weight is a big factor, but how much mpg can i expect to lose going from 245 to 265s (32lbs/tire to 45lbs/tire)?
  2. Apr 8, 2013 at 9:13 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Sounds like you are going to a load range e tire. What brand tire are you going to?
  3. Apr 8, 2013 at 9:21 AM
    SickNaban
    Huntsville, AL
    i'm looking at the toyo open country at 2......i commute 30 miles a day and want to know how much mpg i can expect to lose, so it's a big part of my decision on what tire i want to get...i want a more aggressive AT tire but not take to big of a hit in MPG
  4. Apr 8, 2013 at 9:27 AM
    BORNWILDGUY
    Rich
    Florida
    This tire in the p rating is only 41 lbs so you will be fine
    http://www.treaddepot.com/tire/352290.html
    Of course if you go with an lt or load range e it will be heavier
    If your worried about weight you can also look at the cooper at3 which also comes w a treadwear warranty and is only 38lbs
    http://www.treaddepot.com/tire/90000002692.html
    I run this tire went with this due to the weight and treadwear warranty.
    Both are great tires
    I would go with the p rated version and you shouldn't loose much at all
  5. Apr 8, 2013 at 9:33 AM
    SickNaban
    Huntsville, AL
    yeah i'm torn between the toyo at 2 P and LT....P is 41 lbs and LT is 45 lbs...apparently the P's don't look as aggressive as the LT's
  6. Apr 8, 2013 at 9:50 AM
    BORNWILDGUY
    Rich
    Florida
    sounds like you do almost all highway driving anyways.
  7. Apr 8, 2013 at 9:55 AM
    SickNaban
    Huntsville, AL
    all highway during the week, but need some at tires for my land that i go to all the time
  8. Apr 8, 2013 at 10:28 AM
    murgy88
    murgy88 Member
    Vancouver B.C.
    2011 TRD offroad
    Just picked up a set of A/T 2 a few weeks ago so far I'm very happy with them. they are quiet on the hwy and only noticed a small decrease in Mpg but I went from 265/75 to a 285/75R16 LT.
  9. Apr 8, 2013 at 11:36 AM
    SickNaban
    Huntsville, AL
    what was the weight increase from the 265s to 285s?
  10. Apr 8, 2013 at 12:04 PM
    BORNWILDGUY
    Rich
    Florida
    just go to treaddepot.com and they list the tire weights
  11. Apr 8, 2013 at 2:32 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    245 to 265 will cost you 1 or 2 mpg. My 265x75R16 are 11 lbs heavier than my 245x75R16 and I lost 2 mpg. I just switched back to the lighter tires since I do mostly highway.
  12. Apr 8, 2013 at 4:45 PM
    SickNaban
    Huntsville, AL
    Thanks for the info. What tires were you running (245s and 265s)?
  13. Apr 9, 2013 at 9:18 AM
    Lex Mountain
    Lex Mountain Member
    SoCal
    '13 Tacoma 4X
    I went from stock 265/75/16 Dunlops on steel wheels, to 265/70/17 Hankook Dynapros (P) onto Toyota alloys on my 2013 4 cly. MT 4X4. So far (haven't been through a full tank yet) it seems like a good 3-4 mpg hit. Truck is quite sluggish up hills and on mountain roads... but, again, it's a 4 cyl and was a bit sluggish to begin with. If it were my daily driver, I would certainly return it to a 245 tire size (not the Dunlops).
  14. Apr 9, 2013 at 9:52 AM
    BORNWILDGUY
    Rich
    Florida
    I didn't even take a hit like that going to 285/65r18
  15. Apr 9, 2013 at 9:54 AM
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    I lost 2 mpg.
  16. Apr 9, 2013 at 10:03 AM
    Lex Mountain
    Lex Mountain Member
    SoCal
    '13 Tacoma 4X
    Yeah, probably has more to do with my 4 cyl. and the drive up to my mountain cabin... doubt it would be as bad with a regular commute.
