TIRE and rim fitment questions..? HELP!?
Discussion in 'Wheels & Tires' started by Eesh, Jul 4, 2010.
  1. Jul 4, 2010 at 10:27 PM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    OK so I want to go with 265/70/17 Duratracs... They fit 7"-8.5" rims, my question is would they be ok on 17x9 inch rims?
  2. Jul 4, 2010 at 10:28 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Not sure. But if the specs on the tires say they fit 7"-8.5" wheel, then I'm going to say that they wouldn't fit right on a 9" wheel.
  3. Jul 5, 2010 at 5:14 PM
    Eesh
    Canada
    2025 Tacoma Limited
    Bump.... I just got a reply from Mr. Wheel Deal ... and he said they would fit perfectly??????
  4. Jul 5, 2010 at 5:18 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    They will fit, they will just be a little stretch out.
  5. Jul 5, 2010 at 5:20 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    It would be better if you could find the wheel you want in a 17x8. Also, if you plan on any off roading you might want to be careful of messing up the wheel and the bead coming loose which isn't very likely with light wheeling. Just something to keep in mind.
  6. Jul 5, 2010 at 7:16 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I have 265's on a 9 inch rim and they fit fine. They don't look stretched at all.
