tire and rim size?
Discussion in 'Toyota Trucks & SUVs' started by snoball2361, Nov 13, 2012.
  1. Nov 13, 2012 at 7:07 AM
    snoball2361
    snoball2361 [OP] Member
    Rockie
    Michigan
    2011 tacoma trd
    Bull bar w/kc lights, flowmaster exhuast, tuff country 4" suspension lift.
    I have a 2011 trd double cab with a 4" tuff country suspension lift. I would like to know what are the biggest tires i can go with? I also need to know what rim size i should go with,i was thinking about staying with the stock rim size just buying a set of mickey thompsons. Please advise and thank you.
  2. Nov 13, 2012 at 8:59 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    You could run the skinny 33"s (255/85/16 BFG KM2s) like I do with no problems on a stock rim.
    The fat 33"s (285/75/16) would rub your UCAs on stock rims (you want 4.5" BS with that size) & you may or may not have to trim plastic in wheel wells and/or pound pinch weld and/or cab mount chop.
  3. Nov 13, 2012 at 2:03 PM
    snoball2361
    Rockie
    Michigan
    2011 tacoma trd
    would a 285/70R17 fit? What would you recommend if I were to buy wheels.
  4. Nov 13, 2012 at 2:23 PM
    hillbilly taco
    hillbilly taco Well-Known Member
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    3 INCH LIFT 285/75/16 TIRES CUSTOM GRAPHICS ROLL BAR
    Yes they would fit if you buy wheels with 4 1/2 backspacing.Tires are same as 285/75/16 thats what I run on a Pro Comp 3 inch suspension lift.I had to trim a little plastic on inside fender wells about 2 inches.If you got a 4inch lift you may not have to trim at all.
  5. Nov 14, 2012 at 4:01 AM
    snoball2361
    Rockie
    Michigan
    2011 tacoma trd
    Thanks man for your help i am just getting into the truck world. Just to double check i need a 6 lug on 5.5/139.7 with a 41/2 backspacing.
  6. Nov 14, 2012 at 2:08 PM
    hillbilly taco
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    Yea that would be it.Get some pictures posted.
  7. Nov 14, 2012 at 4:40 PM
    mitchellayes
    mitchellayes Active Member
    Mitchell
    Bremerton, WA
    1997 Toyota Tacoma SR5
    stock
    I just put 20's on my 1997. They are toyota rims[​IMG] though, fit nice.
  8. Nov 15, 2012 at 9:00 AM
    snoball2361
    Rockie
    Michigan
    2011 tacoma trd
    I will put some pictures on here
  9. Nov 15, 2012 at 5:42 PM
    snoball2361
    Rockie
    Michigan
    2011 tacoma trd
    another ? I found some wheels I like and they have a 5" backspacing, will this be ok? it will just make my tires stick out a little more right? thanks again for all the help.
  10. Nov 16, 2012 at 1:28 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    The lower the backspace measurment the farther they will "stick out"
  11. Dec 3, 2012 at 12:19 PM
    snoball2361
    Rockie
    Michigan
    2011 tacoma trd
    I found a wheel with a 5 backspacing will i rub with this
