Tire and TPMS question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gettin Lost, Jan 30, 2016.
  1. Jan 30, 2016 at 11:55 AM
    Gettin Lost
    Gettin Lost [OP] Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    if i was to order a set of wheels and tires, do i need to have them come with a tpms sensors installed? Or can the ones on my truck be used on the new tires?
    Another question... I havent driven in 8 years before buying this truck, never had tires with tpms... So if you get a flat and have to change the tire do you have to remove some sensor to put the spare on?
    I should probably take a tire off and put it back on just for the hell of it (learning experience)
    I want this set.... http://www.ebay.com/itm/17x9-Black-...ash=item5429527011:g:TvoAAOSwKtlWm5tL&vxp=mtr
    Just need to look into a way to black out the logo on it. Like the style... Not much a fan of big company logos though.
    Will this set work on my stock suspension SR truck?
    Thanks for the help!
  2. Jan 30, 2016 at 12:03 PM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    You can use the same sensors. And no you don't have to remove the sensor on to the spare if you get a flat. I have not checked but the spare might come with its own sensor. Nice looking wheels.
    Gettin Lost[OP] likes this.
  3. Jan 30, 2016 at 12:57 PM
    Gettin Lost
    Florida
    2021 TRDOR
    Thanks man, that's good news as they wanted like 40 each sensor!
    Will that tire and wheel setup fit okay?
  4. Jan 30, 2016 at 1:16 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    1. They should fit. The tires are no an issue, but verify with them on the backspace/offset.
    2. There is no TPMS sensor in the spare. You however don't have the correct sensors for alloy wheels if your SR has steel wheels. The correct process would be procuring PMV-C015 alloy wheel sensors so they fit/install properly instead of having to install the TPMS sensors where they can be damaged during the install/removal of the tires themselves.
    3. There is no difference in changing a TPMS vs. non-TPMS wheel. The sensor is installed internally as part of the valve stem assembly.
    4. if you want to black out the logo - find some touchup paint which closely matches the finish on the wheels and carefully paint over it.
  5. Jan 30, 2016 at 1:29 PM
    Gettin Lost
    Florida
    2021 TRDOR
    Not sure about the backspacing or offset, what do I need to ask?
    I do have the steel wheels.
    I guess that means I'm back to needing to get them with sensors installed. I want it done right. If the ones I have now might cause issues I'd rather avoid that.
    Thanks for the info fellas.
  6. Feb 1, 2016 at 1:39 AM
    tjmiller25
    tjmiller25 Member
    TJ
    2016 SR5 DCSB 4X4
    BFG AT KO2’s 285/75/17 Metal Moto 17” rims dipped black (rough texture) Rear Bumper dipped black (satin) Grill / Bezel dipped black (satin) Tailgate Reflective vinyl letters Roof rack 3” Leveling kit Pro Comp Removed air dam Dipped badges (satin) (but may shave soon) Glovebox Tacoma logo dipped Burnt Orange Steering wheel wrapped in Burnt Orange 550 Cord O shit handle wrapped in Burnt Orange 550 Cord Gear shift knob wrapped in Burnt Orange 550 Cord Glove box organizer Mounted Maglight next to driver door Center consoled Neoprene cover / embroidered Interior lights & license plate bulbs switched to LED (Is greasing all the empty driveline Zerks a MOD)? 
    FYI.. regarding TPMS sesnsors....i have had a mess with my new wheels and TPMS sensors. 16" Moto Metals from Big O Tires installed. The stock sensors absolutely did not convert to after market wheels. New sensors had to be purchased and Big O said they did not have updated computer
    to reactivate the sensors for 2016's yet so just take it to Toyota and they can in a few minutes download the new codes to the truck. Toyota wanted $200 to do the activation but after 2 hours could not get new sensors to download to Truck. Still not fixed. Still have light on dash for air pressure!! Just my situation ya know but???
  7. Feb 1, 2016 at 2:07 AM
    Rising Eagle
    Rising Eagle Well-Known Member
    Berkshires MA
    2020 DCSB OR
  8. Feb 12, 2016 at 6:55 AM
    PERITaco
    PERITaco Member
    Jeff
    Utah
    '14 DCSB Off Road
    SCS F-5 Wheels
    If I move the wheels and tires from my '14 DCSB OR to a '16 DCSB OR will the sensors work? From the thread Rising Eagle posted up, it looks like I will at least need it reprogrammed to recognize the sensors in my current wheels.
