Tire and Wheel fitment questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by little bear, Mar 8, 2018.
  1. Mar 8, 2018 at 12:24 PM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    I have a 2017 Silver Tacoma TRD Sport with manual transmission if that matters.... looking at upgrading the wheels and tires and really like the TRD Pro wheels in black or gray but I also saw some Fuel Trophys with matte black and gray bead... no chrome on those wheels and I like them a lot. I like the BFG A/T KO2, Faulken Wildpeaks, Toyo Open Country AT, and Hankook Dynapros ATM .... without lift I would be running either the factory 265/65 r 17 or may jump up to the 265/70 R 17... I like my gas mileage and I really enjoy the ride of my truck but want a beefier looking tire for my hunting and fishing trips (nothing crazy) My question really comes down to the backspacing of the wheels. As it sits now the factory wheels look just inside my fender flares so I wouldn't mind a half inch or so more tire....I dont want them sticking out past the fender flares because I dont want to encourage paint chips from rocks but I also dont want a underbite either :) will the trd pro wheels or the fuel trophy wheels accomplish what I am after? Do yall recommend them? Can you give me all of that for free :)
  2. Mar 8, 2018 at 12:59 PM
    JBone25
    JBone25 Well-Known Member
    Watching this thread. I want to see what you hear.
    little bear[OP] likes this.
  3. Mar 8, 2018 at 1:03 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Check out the thread, 17 TRD Pro rims and BFG AT TKO2's... That will give a good view of those rims, with different size tires.
    Just looked at the Fuel Trophy's the + 6 offset should keep you inside flare, -6 may put them just a bit out side flare. Your factory rims are +30 offset. +6 offset would be around 1" further out than your factory rims Hope that helps.
  4. Mar 8, 2018 at 1:20 PM
    little bear
    Barry Hobson
    Canadian, Texas
    That helps a million. So the +6 fuel or the trd wheel would be an inch further out than my factory wheels now? If so it would be very near the edge of the fender flare ... That is exactly what I am looking for....
  5. Mar 8, 2018 at 2:34 PM
    yarberrymt
    yarberrymt Well-Known Member
    the only two things that matter in your scenario:
    1) Wheel width
    2) wheel offset (backspacing)
    an 8" wide wheel sits perfectly flush with the fender of a 3rd gen Tacoma at a 0mm offset (ET 0). Stock has a higher more positive offset as to not interfere with suspension travel and tires hitting fenders.
    Going BELOW that et0 into negative numbers will begin to protrude past the fenders.
    This becomes a personal preference with your tire sizes, as a 265/75 is not a huge tire. Some people like "tuck", others "flush" and others "poke".
    Your call. Again, all that matters in this equation is #'s 1 and 2 above, # 3 would be tire size, but is negligible in your scenario.
  6. Mar 8, 2018 at 2:48 PM
    na8rboy
    WI
    Yes, if you are looking at 17x8.5 Fuel. Remember your tire sidewall will be out further.
    yarberrymt, hint the nail on the head, with his explanation.
  7. Mar 8, 2018 at 2:58 PM
    little bear
    Barry Hobson
    Canadian, Texas
    I don’t want it too far out.... but close to or just at the edge of the fender flare would be perfect for me.... y’all are much smarter than me so I am still confused if I will get that with the fuel or the trd Pro wheels
  8. Mar 8, 2018 at 2:59 PM
    yarberrymt
    I'll add that the tricky part is that wheel width (primary figure) interferes with fitment calculations by altering where certain offsets (secondary figure) sit at the fender. So, in a 17x8.5 wheel, you have 1/2" (~12.7mm) more width, which technically equates to subtracting 1/2" from your offset used in the example above (8" wheel, 0 offset).
    Calculations are great and necessary before dropping coin on new shoes, but there is no better way than to do a test fit, by mounting the wheel (sans tire is OK) to your hub and look with your eyes to see where it lies within your fender well. You can definitely eyeball if it's "poking" and get a good grasp on whether or not it's flush.
    Be careful with asking people who sell wheels (local tire shop or whatever) the "will it fit" question. Often, they do not take into account all of the details we're talking about.
    The good news is that, unlike sports cars, our trucks have tons of fenderwell clearance and this whole topic isn't really a big concerns because trucks can accommodate such a wide range of wheel sizes.
    na8rboy[QUOTED] likes this.
  9. Mar 8, 2018 at 3:10 PM
    na8rboy
    WI
    Ok, like yarberrymt mentioned. at 0 offset 8" wide wheel will be flush. Now if you go +6 offset it will move in 1/4"+ in. Now add 1/2" because Fuel is 8.5. so that would end up 1/4" out side your flare, at the most. If you go with 265/70/17 tread will be in wheel well, but sidewall may bulge out a bit. It going to be damn close to flush.
    Did I get that right Yarberrymt?
  10. Mar 8, 2018 at 3:22 PM
    little bear
    Barry Hobson
    Canadian, Texas
    With a slightly bigger tire and wheel would I also need a alignment?
  11. Mar 8, 2018 at 3:27 PM
    na8rboy
    WI
    Always good to get an alignment with new tires, with the money your sending on them. Not requirement, won't change your alignment with new wheels and tires. But I would.
  12. Mar 8, 2018 at 3:38 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Your stock rim is 17x7.5 +30mm offset 5" backspace.
    Here's a calculator to help you look at different wheels. Scroll down to fender clearance to see how much poke new wheels get.
    Tire poke and wheel poke will differ more, when you mount the same width tire on a wheel that is wider than stock or don't use the measuring rim width for a particular size tire. The rim on a 17x8.5 +6mm will poke 1-1/2" further than stock. A 265 tire on a 17x8.5 +6mm will poke 1". If you mounted a 285(closer to a 8.5" measuring rim width than a 265) it would be closer to close to 1-1/2" of tire poke.
    You need rims with 5" or less of backspace. The calculator is off by 1/2" when it calculates backspace. It's calculating backspace using rim width(inside-to-inside) and not wheel width(outside-to-outside). Just add 1/2" to whatever it calculates.
  13. Mar 8, 2018 at 3:54 PM
    na8rboy
    WI
    So, he should be flush. I just took a 4' level plumb, from flare. My stock sport wheel lip was 1.5" in from plumb line of flare. That was Front and back.
  14. Mar 8, 2018 at 3:58 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    16x8
    4.5” backspacing
    Did the math myself to minimize the tire rub in any situation including performing a flex test and full compression at full turn and after cab mount chop, no rubbing at all.
    I’m running 33s though (285/75R16 Toyo Open Country AT2) w/ 2” suspension lift
  15. Mar 8, 2018 at 4:11 PM
    little bear
    Barry Hobson
    Canadian, Texas
    That’s my numbers also with the -6 fuel trophy wheels and 265 70 r17 tires.... am I correct- I am pretty confused with all this discount tire quoted me 2,038 for BFG At K02 and the fuels plus install—- decent?
  16. Mar 8, 2018 at 4:17 PM
    na8rboy
    WI
    I can understand the confusion... You want +6 Fuel That will give you the 1.5" poke over stock wheel, like splitbolt mentioned. -6 would give you more poke.
  17. Mar 8, 2018 at 4:19 PM
    little bear
    Barry Hobson
    Canadian, Texas
    +6 sticks out just a little further than my current setup and would be nearly flush with where my fender flare is? If That’s the case then I think that’s the direction I would head. Sounds like no problems running 265 70 r17’s with stock suspension either.
  18. Mar 8, 2018 at 4:24 PM
    na8rboy
    WI
    I saw wheels 4 at $232 = $928 BFG's $225 = $900 total $1828 $ 410 install is a lot, unless alignment is included
  19. Mar 8, 2018 at 4:28 PM
    little bear
    Barry Hobson
    Canadian, Texas
    Ouch.... nope.... not even hazard insurance.... looks like I need to look around. Waaaayyyy tooo high- any chance y’all have the links so I could try and get them to price match
  20. Mar 8, 2018 at 4:29 PM
    Dave Mullins
    Dave Mullins Well-Known Member
    Dave
    Salt rock W.V.
    2017 Tacoma SR Silver
    Tinted windows 15%
    2018-02-24 16.35.55.jpgthis is mine.... 265 70 17 falken wheels are level8 mk6. 17x9 -12 offset with 4.5 backspacing2018-02-24 16.37.02.jpg
    thestachee and little bear[OP] like this.
