Tire Balance Issue
Discussion in 'Hawaii' started by BWS, Apr 30, 2015.
  1. Apr 30, 2015 at 7:03 PM
    BWS
    BWS [OP] Well-Known Member
    Kapolei HI
    2014 DCSB TRD OFFROAD 4X4 6SPEED
    Kings All Around, LR UCA, Allpro leafs, BHLM
    Have any of you guys had issues with the balance of the tires being thrown off? I've gotten it rebalanced like 4 times already and every time at around 45-55 mph the steering wheel starts to shake a little. Shake goes away at 60mph. I got 16in TRD FJ wheels and 33" Baja ATZ P3 tires. Every time its been rebalanced it was off like a ounce. Any help is appreciated. Thanks
  2. Apr 30, 2015 at 7:31 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Should try dyna beads then no need weights:D
  3. Apr 30, 2015 at 7:45 PM
    BWS
    Kapolei HI
    Have you tried them before?
  4. Apr 30, 2015 at 7:56 PM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
  5. Apr 30, 2015 at 8:10 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    No but luka did and it works
    k7Skedar likes this.
  6. Apr 30, 2015 at 8:13 PM
    BWS
    Kapolei HI
    Yeah after the second rebalance with the clamp on weights they used the adhesive and even that went out of balance twice. Went back again and they used the clamp on ones again. Still shaking the steering wheel. But ill look into who uses the haweka adapter to balance wheels. Thanks
  7. Apr 30, 2015 at 8:15 PM
    Wile
    Tim
    New Mexico
    Sears does
  8. Apr 30, 2015 at 8:16 PM
    BWS
    Kapolei HI
    Ill try looking into that too if all else fails.
  9. Apr 30, 2015 at 10:14 PM
    HiFire
    HiFire Well-Known Member
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    Weathertech mats, BAMF sliders, US Offroad front winch bumper, RCI Alum. Skid plates, ICON suspension, Pelfreybilt rear bumper, JBA uca's, Allpro u-bolt flip,
    I used dyna beads on a set of 35 bfgs. Worked great. The tires rode very smooth.
  10. May 1, 2015 at 12:58 AM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    x2 on dynabeads. talked to luka about them and I think that's the route I'm gonna take real soon. I had my TPMS sensors transferred over to my countersteers, and when they rebalanced, I ended up with a fuckton of adhesive weights in my rim. now it's ugly as shit, and bothering me :frusty: just google dynabead... and from the sound of it, it's best to drop them in before the tire is fully mounted (vs. installing through the valve stem).
  11. May 1, 2015 at 10:28 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Where have you been taking it to get balanced?
    How much weight total on the wheel? And have you tried rotating the rears to the front to see if it stops? I'm wondering if they weren't balanced in the first place, or if something else like alignment or tire pressure are the culprit.
    My friend let me use his balancing machine and it tells you where to put the weights, towards the face, center, or the rear. His compressor wasn't strong enough, so I couldn't do the road force balance. I'll check with him to see if he has it working now.
  12. May 1, 2015 at 3:21 PM
    BWS
    Kapolei HI
    Been taking it back to 4wheelparts since i got it lifted there. I got 2oz clip on on the drivers wheel and 2.75oz clip on on the pass. I was thinking about rotating them to the back but figure i would feel it in the back after. Is it possible to feel a unbalanced wheel in the rear?
    My alignment is
    Left. Right
    camber .7 .6
    Caster 2.1 2.6
    Toe. .06 .06
    I got LR upper control arms. And gonna get alignment from island brake sometime in the future to get the camber at zero.
    And my tire pressure is 40psi. Brought it down from 45 which they had it set at. Came a little better.
  13. May 1, 2015 at 5:37 PM
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    I had balancing issues. I finally took them to my friend at Rons and he road forced it for me. After that it was all good.
  14. May 1, 2015 at 10:13 PM
    HiFire
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    The plus with the beads is that the balancing makes up for tread wear. Using weights only compensates for the tire while it is on the machine. Once you start to drive around the tire becomes out of balance due to tread wear.
  15. May 1, 2015 at 10:54 PM
    BWS
    Kapolei HI
    Is there a shop that carries those beads or gotta buy online and bring them in with you? Who install the beads for you? Im afraid the shops gonna put too much lube and get it inside the tire.
  16. May 1, 2015 at 10:56 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    i ordered mine direct off the website and installed them myself.
  17. May 1, 2015 at 11:41 PM
    HiFire
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    Same here. Ordered online than installed them myself. The beads are small enough to fit through a valve stem without a sensor. Otherwise break the bead at home or take them to a shop.
  18. May 1, 2015 at 11:51 PM
    BWS
    Kapolei HI
    Can it be installed thru the TPMS valve stem? The web site says it cant if its a integral part of the valve stem
  19. May 1, 2015 at 11:56 PM
    BWS
    Kapolei HI
    Guess I gotta do either or. Thanks
  20. May 2, 2015 at 12:11 AM
    luka
    Kailua, HI
    yeah, they fit in the stock TPMS valves, it just takes a long time...it'd work better with a pressurized feeder...I was actually considering making one because of how much of a headache I had.
    I also ordered the longer filtered cores, they fit just fine.
