Tire balance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08BlackenedTaco, Apr 8, 2012.
  1. Apr 8, 2012 at 8:03 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    which would be a 4 ply...:notsure:
  2. Apr 8, 2012 at 8:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    80 PSI max in that size is usually E rated , no ?
    If I'm mistaken let me know .
  3. Apr 8, 2012 at 8:10 PM
    Superx2
    Joey
    Iowa
    you would be talking about 12 ply i believe. that sounds better.
    my stock tires would be a 4 ply. can only have like 35 pounds of pressure.
    an 8 or 10 ply would be like a 60 pound pressure.
  4. Apr 8, 2012 at 8:17 PM
    08BlackenedTaco
    08BlackenedTaco [OP] Well-Known Member
    High Point, NC
    Prerunner Murdered....
    14" magnaflow maxflow muffler, intake mod, black headlight mod. VHT Nightshades tail lights, painted stock rims.
    yes
    Is my tire E rated? lol
    Sounds like a good plan if i have to talk to the same people im gonna flip my shit worse.
  5. Apr 8, 2012 at 8:21 PM
    08BlackenedTaco
    High Point, NC
    shit its 65 my bad man.
  6. Apr 8, 2012 at 8:22 PM
    Superx2
    Joey
    Iowa
    if your max tire pressure is 80, try putting 77-78 in. i dont know why they would only put 45 in. shit, maybe they put a higher grade tire on? bonus for you if they did!!
  7. Apr 8, 2012 at 8:27 PM
    08BlackenedTaco
    High Point, NC
    Our trucks are very light compared to what that 33" tire should be on.
  8. Apr 8, 2012 at 8:32 PM
    Superx2
    Joey
    Iowa
    i see your point... sorry:eek:
  9. Apr 8, 2012 at 8:35 PM
    08BlackenedTaco
    High Point, NC
    dude i just found that out 20 mins ago while searching. lol no worries
  10. Apr 8, 2012 at 8:39 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    Go to discount tire. If it's a balance issue, that should fix it. You can always stand behind the balancer and make sure it's zero'd out :p And don't go to jail. Not a good idea.
  11. Apr 8, 2012 at 9:14 PM
    OZ-T
    Peter North
    British Columbia
    That's WAY too much
  12. Apr 8, 2012 at 9:16 PM
    OZ-T
    Peter North
    British Columbia
    OP ,
    Get alignment
    Get tires road force balanced
    Do chalk test ( prob around 34PSI )
    Don't go to Walmart
  13. Apr 8, 2012 at 9:16 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Yeah, I'd run max 45-50 on those. All you would get from that would be reduced tire life and a shitty ride.
    Also, CHALK TEST FTW :D
  14. Apr 8, 2012 at 9:23 PM
    OZ-T
    Peter North
    British Columbia
    I run 36 in my E rated Hankook ATm's that have a max PSI of 80 .
    45-50 is still WAY too much .
  15. Apr 8, 2012 at 9:27 PM
    #35
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^^same here. I run 36 in my e rated bfg at's that have a max psi of 80.
  16. Apr 8, 2012 at 11:50 PM
    #36
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If the truck feels like it's floating or requires a lot of steering input to keep it straight you need an alignment.
  17. Apr 9, 2012 at 8:42 AM
    #37
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Like I said, if you're into over-inflating your tires, I would run MAX 45-50 psi. I personally run anywhere around 32-38.
  18. Apr 9, 2012 at 8:51 AM
    #38
    OZ-T
    Peter North
    British Columbia
    Why would anyone want to overinflate their tires unless you are hauling some thing heavy , and having said that , the Tacoma is capable if hauling it's maximum payload on the crappy P metric tires it is sold with , 45-50 psi in E rated tires is just dumb
  19. Apr 9, 2012 at 9:03 AM
    #39
    oldstick
    oldstick Medicare Member
    GA
    How come almost every suspension or wheel problem post I read on the net, starts with "I recently modified..." ??
    :D
  20. Apr 9, 2012 at 9:15 AM
    #40
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    The ice feeling is just a bit of your tire contacting the road. REDUCE the PSI to 31-32 and use the chalk test and it will fell much better bud.
