Tire Cables (not chains)
Discussion in 'Wheels & Tires' started by randyg123, Dec 21, 2010.
  1. Dec 21, 2010 at 6:08 PM
    randyg123
    randyg123 [OP] Well-Known Member
    Randy
    2024 Bronze LTD
    I just read where Toyota says no chains up front. And I read a thread where it is brought up that a clearance issue is involved behind the tire at about 12:00 o'clock. I need to confirm this. But my question is: I bought some cables (SSC Super Z's) and I got those before reading the manual (Dooooh!) is the clearance still relevant with such cables? I just need them a few times a year with ice being a bigger issue than snow. So front steering is rather critical under these conditions. thanks!
  2. Dec 21, 2010 at 6:10 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I believe the clearance issue would be the uca(upper control arm). I guess since you already have them try them on and see how close they are.
  3. Dec 21, 2010 at 6:21 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    I see that you bought cables instead of chains. I do run the Les Schwab cam chains and the only clearance issue with them is the UCA and when the suspension is all the way suspended in the down position. So normal running of chains on the highway is Ok.
    So to answer your question I would say that the cables would be just fine since they are thinner than chains and your just running them on the highway.
    I wheel with mine on the front and the rear and I run the stock tire size. 265-70R16.
  4. Dec 22, 2010 at 10:11 AM
    randyg123
    Randy
    2024 Bronze LTD
    Thanks for the replies. I'll check them out today and see how they fit. I didn't even think of clearance issues behind the tire:eek: Silly for a 4WD to be a concern. But as stated, we're just looking at running down the icy roads a few days a year. I've never used chains before so I am curious if there will be a difference. And yes I am running the stock tires but they are going to need replacing soon. thanks again, Randy
  5. Dec 22, 2010 at 10:47 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The clearance between the front tires and the upper control arm's on a stock truck is very small...about the thickness of a finger. With the thickness of the cable added your down to around maybe a 1/4" of clearance...not enough in my opinion.
  6. Dec 22, 2010 at 11:17 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I keep seeing websites that recommend putting tire chains on all four wheels.
    That makes sense for off-road-trailing into the snow.
    But I've never seen a 4x4 chained on all 4 on the pavement.
    If you need to chain up for the highway, put chains on the back (EDIT: AND DRIVE SLOWLY!) and you're done.
  7. Dec 22, 2010 at 2:09 PM
    randyg123
    Randy
    2024 Bronze LTD
    Thanks for all the advice. I ran out to my truck and ran my hands behind the tire and sure enough, the Upper Control Arm is only 5/8-3/4" from the tire but there is a knuckle that sticks out from the UPC pointing towards the tire that narrows the gap to about 1/2" or maybe a bit less. Just so happens that the fattest part of my cables (where the joints are) line up just perfectly with the knuckle. Not worth the obvious high chance of tearing them up.
    Mostly interested in the front to be turning on ice on hilly roads. Snow and packed snow not really much of a concern. So far I've done okay without chains but they would come in handy once or twice a year when staying off the road is not possible.
    No worries, I'll just send one un-opened box back. thanks again for everyone's comments. Randy:)
  8. Dec 23, 2010 at 11:55 PM
    TimsToy2011
    TimsToy2011 Member
    Tim
    Murrieta, CA
    Long bed, 4x4, Sport X-Val Pkg
    Are chains OK on the rear tires? Manual says "cables..." but the set of chains I bought seem pretty low-profile. Should I look for the receipt and take them back and keep looking for cables for the rear?
  9. Dec 25, 2010 at 8:13 AM
    treeserv
    treeserv New Member
    Dave
    Palo Cedro, CA
    silver
    Well, Toyota didn't think this through, chains will not work on the front and cables are not recommended because of clearance issues. Better stick to chaining or cabling the rear. If you need a real snow rig, git a Jeep. Chain up all four without issue and go around winching Taco's out of the ditches.
  10. Dec 25, 2010 at 8:39 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    studded snow tires on a set of steelies for the winter.problem solved
  11. Dec 25, 2010 at 12:41 PM
    taco084gb
    Galen
    NorCal
    Well thats not entirely true I have been running chains on the front of my 08 4x4 truck for 2 yrs now and no problems with hitting. I run them on all 4 tires when wheeling hard. I run 245 75 16 M/T TOYO's and also ran the chains with 265 70 16. No Rubbing on the UCA.
    My chains are from Les Schwab and they are the Cam Lock chains and they are recommended for our trucks and have been since 05. Might want to check them out.
  12. Dec 26, 2010 at 7:20 AM
    treeserv
    treeserv New Member
    Dave
    Palo Cedro, CA
    silver
    I have 265R70x16 on the Toy and wouldn't consider running anything but spiders on them. I run 33x9.50 on my CJ, great tire for snow, lots of pressure. With two Jeeps, both were studded and one was chained all four during heavy snow (lived at South Lake Tahoe, worked at Echo summit). The Toyota has been a highway flyer, maybe we'll have some snow this winter...
