Tire Carrier T-Knob Lock Pin
Discussion in 'Relentless Fabrication' started by MadMedic35, Jan 2, 2021.
  1. Jan 2, 2021 at 2:11 PM
    MadMedic35
    MadMedic35 [OP] Well-Known Member
    Sandhills, NC
    09 TRD SPORT DCSB
    Fox 2.5 coilover, TC UCA, FOX 2.5 res rear shock, OME leaf pack, SCS Ray-10 gold, Nitto Ridge Grappler, SoftTopper. On order: Relentless Fab Summit Bumper, HC rear bumper with tire carrier, sPOD, Powertray,
    Trying to replace a broken T-Knob Lock Pin. Is the shroud welded in or is mine just rusted in?
    Wulf likes this.
  2. Jan 2, 2021 at 2:12 PM
    Wulf
    rock raisin
  3. Jan 2, 2021 at 4:35 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  4. Jan 2, 2021 at 8:38 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    The 'barrel' of the lock pin is welded in to the tabs on the pivot spindle sleeve.
    The pin itself just unthreads out with the knurled part just above the welded barrel/tabs. Throw some channel locks on there and it should unthread. If it's rusted in then you may need heat to help persuade it out. On reassembly with the new pin put a little bit of marine grease or anti-seize on the threads.
  5. Jan 3, 2021 at 9:38 AM
    MadMedic35
    Sandhills, NC
    09 TRD SPORT DCSB
    Thanks for the response. Wouldn't be an issue if I had not forgotten to latch the carrier and driven down the road.
