Tire carrier with a motorcycle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by heel_touge, May 1, 2016.
  1. May 1, 2016 at 7:54 AM
    heel_touge
    heel_touge [OP] mark@eibach
    Mark
    Corona, CA
    14’ TRD-OR DCSB 4x4
    Eibach Pro-Truck-Lift system Icon RXT Leaf Pack Dirtking UCA’s Magnuson Supercharger Nitto Ridge Grappler Warn 9.5 Hella Rally 4000 ARB goodies everywhere
    I chose my Tacoma for its utility first, but it's hard not to want to mod the hell out of this thing.
    I ride / fix / break motorcycles and need the bed to be functional, but I want to add a rear bumper and tire carrier. Are there any existing solutions, or people out there running a setup that works with the tailgate down / open?
    I was thinking an offset wheel and a riser for the pivot point on the gate. You could open the tailgate and close the tire carrier over top of it. The offset wheel would allow space for the rear wheel of the bike to fit.
    Thoughts?
  2. May 1, 2016 at 8:34 AM
    Pigpen
    Dan
    Northwest Montana
    The problem keeping you from closing the tailgate may continue to be a problem.
  3. May 1, 2016 at 8:43 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Might be worth just leaving the spare at home. Many cars don't even come with them now.
    Get load E tires, a plug kit (and mini DC air compressor), a membership to AAA and leave the spare at home until you are gonna hit the trail. E load tires will reduce your chance of getting a flat, the plug kit will fit simple punctures, and AAA will bail you out when all else fails.
    Sorry, that's the best solution I have.
  4. May 1, 2016 at 10:09 AM
    heel_touge
    Mark
    Corona, CA
    14’ TRD-OR DCSB 4x4
    Ok picture this. A dual swing out carrier that triangulates / latches over the tailgate when down. This would give me the space I need for a tire, keep carrier doors from hanging out in the street and be a solid solution!
  5. May 1, 2016 at 12:08 PM
    dunecruiserTRD
    dunecruiserTRD Member
    Long Island
    '10 DCSB TRD Sport White
    ICON Adjustable Coilovers, Remote Reservoirs, All Pro 3" Leaf Packs, N-Fab Tube Bumper, Toyo Open Country MT 285/75/R16's, American Racing Mojave Teflon Coated 16x8's, Flowmaster Dual Exhaust Side exits, K&N Short Ram Intake, Poneer touch screen deck and pioneer speakers front and back, Wet Okole Heated Seat Covers Gray with red piping, bakflip tonneau cover
    Get a roof rack and put the tire on the roof. Then get a bumper without a tire carrier.
  6. May 1, 2016 at 1:34 PM
    heel_touge
    Mark
    Corona, CA
    14’ TRD-OR DCSB 4x4
    Not a bad thought. I was wanting the keep the weight as lost as possible, but that's Definately the easiest solution thus far.
    Any recommendations on roof baskets that fit OE holes?
  7. May 1, 2016 at 5:15 PM
    Slainte
    Slainte Active Member
    Bob
    Red Deer,Alberta,Canada
    Double cab long box
    Some
    Prinsu and front runner
  8. May 2, 2016 at 3:51 AM
    dunecruiserTRD
    Long Island
    I just got the bajarack. Fits the oem roof rack mounting holes. Took practically no time to install and looks good too.
  9. May 2, 2016 at 6:37 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    What is the bike? As a motorcyclist it gives me the willies to hang a motorcycle off my trailer hitch.
  10. May 2, 2016 at 7:33 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    A trailer is an option for hauling bikes.
  11. May 3, 2016 at 6:30 AM
    heel_touge
    Mark
    Corona, CA
    14’ TRD-OR DCSB 4x4
    the baja rack looks perfect but I didn't see an Access cab option. I'll have to reach out.
    @Slainte the Pinsu and Front runners look good but are flat. I'm thinking something with a bit more of a basket
    @jethro it's an 03' Sportster right now, but I'll be picking up a dirt or dual sport anytime soon. The reason I picked up my first Tacoma was to go grab craigslist finds, get them running and flip them. Those trailer hitch carriers are no Bueno. Scares the heck out of me. On a standard bed, the center of the tire falls right in between the tailgate and bed.
    @PackCon, true, but the reason I chose this was so I didn't have to go with a trailer.
  12. May 3, 2016 at 6:36 AM
    Pigpen
    Dan
    Northwest Montana
    I still envision the bike being in the way, as posted above. The tailgate isn't really the problem, as I see it. You'll go to close the carrier and there's that pesky motorcycle in the way...
    I say put the spare in the stock location - anything up to 33' fits. If that's not an option, put it on the roof or leave it at home.
