Tire chains or other alternatives for 2WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steves55, Nov 2, 2018.
  1. Nov 3, 2018 at 7:27 PM
    #41
    96carboard
    96carboard Well-Known Member
    You cannot run any kind of traction aids on the front except *maybe* cables. There just isn't enough clearance.
    Alexely999 likes this.
  2. Nov 3, 2018 at 7:31 PM
    #42
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    +1 on upgrading to 4WD. Just did so myself.
    phatso and PackCon[QUOTED] like this.
  3. Nov 3, 2018 at 8:37 PM
    #43
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Agree 1000%
  4. Nov 3, 2018 at 10:09 PM
    #44
    MustDrive
    MustDrive Well-Known Member
    Dave
    Minnesota
    '14 White Off Road, 6-Speed, Double Cab
    Nothing major planned, this is my daily driver. - replaced stock tires with Cooper AT3s - added Husky WeatherBeater floor mats - installed Access Original bed cover - installed Gentex 453 mirror and the included external temp sensor, also has Homelink and auto-dim - installed ImMrYo mirror bracket - hose clamp mod and washer mod to secure tailgate, with a GateKeeper lock installed over the hose clamp - replaced stock reverse lights with Philips Halogen 30w from Home Depot GY6.35 base
    I live in Minnesota, lots of ice driving experience. 4WD does help on ice, in one specific way.
    With 2WD, if you hit the gas too hard on ice, the back end swings out because the rear wheels are spinning and the the front ones have (a little more) traction. You are now pointing at a new spot - you are spinning.
    With 4WD, that does not happen. Both ends of the truck break traction at the same time if you give it too much gas, and at least you are still pointing in the same direction as you were.
    SilverBulletII, b_r_o and Alexely999 like this.
  5. Nov 4, 2018 at 5:45 AM
    #45
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Misread that part. So,do you really need a truck? If yes,trade it for a 4wd. You've stated that you physically can't install chains yourself,and no one can help you. If you don't need a truck,trade yours for an Outback.
    b_r_o likes this.
  6. Nov 4, 2018 at 1:24 PM
    #46
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    He said they would allow chains.
  7. Nov 4, 2018 at 1:33 PM
    #47
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I watched the videos on there website, those look pretty easy to put on. did you use the ones that you have to install the plate on the hubs or the other ones? Do they install as easy as it looks?
  8. Nov 4, 2018 at 7:24 PM
    #48
    Steves55
    Steves55 [OP] Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Chains are allowed on 2WD, that will get you in the gate.
    A truck is a must here, need it for hauling shit.
    I can install chains if they are the easy self adjust type. That’s why I’m posting here- real world experience.
    I have neighbors who could help but don’t want to be bothering them every time it snows. They all work, I don’t.
    I drive plenty- Home Depot is 40 minutes each way. We go through the gate almost daily, sometimes multiple times.
    I’d love to buy a 4WD but will wait for now. Unless someone wants to trade yours for mine.............
    This thread was about chains & to get real world experience from fellow Tacoma owners who are 2wd. It’s not about 4wd.
    It’s not about snow tires, studded tires or anything else tire related.
    So again- do you run chains & if you do, are you familiar with the ones that are easier to install?
    BassAckwards likes this.
  9. Nov 4, 2018 at 7:40 PM
    #49
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Who told you studs arent allowed in Kern County? They are legal state wide, so it must be a HOA rule? If so thats hilarious.
    27454. No tire on any vehicle upon any highway shall have on its periphery any block, stud, flange, cleat, ridge, bead, or any other protuberance of metal or wood which projects beyond the tread of the traction surface of the tire.
    This section does not apply to the following:
    (a) Tire traction devices of reasonable size used to prevent skidding when upon wet surfaces or when upon snow or ice.
    (b) Pneumatic tires which have embedded therein wire not to exceed 0.075 of an inch in diameter and which are so constructed that under no conditions will the percentage of metal in contact with the roadway exceed 5 percent of the total tire area in contact with the roadway, except that during the first 1,000 miles of use or operation of any such tire, the metal in contact with the roadway may exceed 5 percent of the tire area in contact with the roadway, but shall in no event exceed 20 percent of such area.
    (c) Vehicles operated upon unimproved roadways when necessary in the construction or repair of highways.
    (d) Traction engines or tractors when operated under the conditions of a permit first obtained from the Department of Transportation.
    (e) Pneumatic tires containing metal-type studs of tungsten carbide or other suitable material and which are so inserted or constructed that under no conditions will the number of studs or the percentage of metal in contact with the roadway exceed 3 percent of the total tire area in contact with the roadway, between the first day of November and April 30. The commissioner, after consultation with the Department of Transportation, may extend the period during which studded pneumatic tires may be used in any area of the state for the protection of the public because of adverse weather conditions.
    (f) Pneumatic tires used on an authorized emergency vehicle, as defined in Section 165, containing metal-type studs of tungsten carbide or other suitable material, if the studs are so inserted or constructed that under no conditions will the number of studs or the percentage of metal in contact with the roadway exceed 3 percent of the total tire area in contact with the roadway. Notwithstanding subdivision (e), authorized emergency vehicles are permitted the unrestricted use of studded pneumatic tires throughout the year.
    jboudreaux1965 and Muddinfun like this.
  10. Nov 4, 2018 at 8:14 PM
    #50
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Pickledpigsfeet, I love your approach, but I've fought battles with local government before over speed bumps on roads that the state deemed illegal on highways. The key word is highways. Local streets do not apply only roads that are designated as state (or federal) highways apply.
    Like if you look at a map and it shows bobs rd. Doesn't apply. Now, when highways run through towns, map may state bobs rd/ hwy 555. Then state and fed regulations apply. Sorry OP, I don't mean to get off topic, just wanted to explain.
    OP, is budget a big issue, or do you just love your truck and want to keep it?
    It sounds like your only option is chains. Like someone previously mentioned there are some that are easy to install. How easy, I don't know, never used spider.
    But man I think your low on options. Maybe check with local inspection folks, see if emergency chains will pass... Or, contact your local city council representative, show them that although you drive a '2WD' it is equipped with a locker, and will perform fine under conditions with proper tires. Have him submit an amendment to the council.
    If it was me, personally and my truck, which I will never sell and had no other options, I'd just pay the security guard everytime I go through to put the chains on.
    Sorry bro that's all I can offer, good luck.
  11. Nov 4, 2018 at 8:19 PM
    #51
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    I used the kind that had a plate mounted with the lug nuts. Once the mounting plate is there it only takes a minute to put them on.
  12. Nov 4, 2018 at 10:02 PM
    #52
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Best bet is some regular old chains and some good bungee cords to keep them snug. Put them on at the beginning of the storm cycle and leave em on. And some sandbags
    Or, if you're planning on removing/installing a quick style (spider) multiple times per day I'd seriously think about a cheap Subaru on Blizzaks. Or a 4wd tacoma.
    Anything quick release/plastic is probably going to break after repeated use
  13. Nov 5, 2018 at 5:39 AM
    #53
    96carboard
    Don't know about there, but *here* in terms of LAW, the term "highway" actually refers to ANY government maintained roads. So does not have to be a 6 lane interstate. It can be a slow road in front of a school.
  14. Nov 5, 2018 at 12:50 PM
    #54
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    To clarify my statement on studded tires-
    I said studded tires are not legal here. Some cities also don’t allow while others are Nov 1 to Apr 30 only.
    However- this is a quote from Caltrans & the police department here.
    So- 4wd, Awd or chains are what will get you through the gate.
    No need to respond, no one here has real world experience with the high-end chains.
  15. Nov 5, 2018 at 12:56 PM
    #55
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    That's a bold statement. I'm sure someone will prove you wrong.
  16. Nov 6, 2018 at 4:44 AM
    #56
    96carboard
    I wouldn't take that too personally. He's just getting a little frustrated (understandably).
  17. Nov 10, 2018 at 3:37 PM
    #57
    ljma90
    ljma90 Well-Known Member
    Jordan
    2007 Toyota Tacoma v6 4x4
    2.5 inch suspension lift front with rancho 9000 quick lift struts, rear rancho shock absorbers with 2.5 inch sky jackers add a leaf springs in rear. extra 2 inch long braided front brake lines with radiator flush, transmission flush, brand new front brake rotors, calipers, and shoes all done myself. more to come
    buy a 4x4
    wilcam47 likes this.
  18. Nov 10, 2018 at 3:40 PM
    #58
    ljma90
    Jordan
  19. Nov 10, 2018 at 4:23 PM
    #59
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Get this no matter what else you do and you will be surprised with its traction along with a few hundred pounds of sand in the bed. Never got stuck in my 2wd Datsun unless snow was over the frame.
  20. Nov 10, 2018 at 4:41 PM
    #60
    Wulf
    Wulf no brain just damage
    rock raisin
    Lock up that rear diff and you will be surprised how far you can make it with studded tires or chains.
    My grandpa lived in the woods in WA and had a 2wd s10 with a posi and never had issues with studded tires and some weight in the bed
