Tire change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Billybong, May 20, 2017.
  1. May 20, 2017 at 8:37 PM
    Billybong
    Billybong [OP] Member
    2015 4x4 tacoma double cab
    New to this stuff. I have a 2015 4 door Tacoma 4x4. I would like to upgrade to 17 in wheels as there is no travel/clearance with 16 inch wheels (bent my skid plate and trailer connection having fun). Wondering if I can go to 17 or 18 inch wheels and what suspension/drive train mods would be needed. Need to keep a decent road ride for the wife.
  2. May 20, 2017 at 8:39 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Huh?.....
    BassAckwards likes this.
  3. May 20, 2017 at 8:49 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    1" bigger wheels arent going to give you more clearance. Bigger tires will give you better clearance. You're talking about approach and departure angles.
  4. May 20, 2017 at 8:57 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    If gaining ground clearance is the only reason you want to go up to a 17", then save your money and put it into the lift. Wheel size doesn't play that big of a difference in ground clearance. As far as the lift goes, there are a few questions. How often are you off road? How difficult (is it logging roads or the Rubicon Trail) is the terrain? Whats you budget? Sorry if I came across as an ass (didn't mean to ), just some things to think about.
    P.S. Welcome to the club. :cheers:
  5. May 20, 2017 at 9:01 PM
    Lost In The Woods
    Eric
    Buckley, WA
    Forgot to mention it, but @moondeath is right. With the lift your going to need bigger tiers. And if you don't like plan A, there's always plan B::sawzall:
    Benzdriver81 likes this.
  6. May 21, 2017 at 1:47 PM
    Billybong
    I'm not really a hardcore off roader but I recently moved to Bullhead City, Arizona and sometimes when driving around I run into terrain that is difficult for my little stock truck. I was thinking larger wheels and tires would raise the frame but I would then need some type of lift to raise the body accordingly. I don't really like the look of extra large tires on small wheels. Don't know if larger tires would require steering box upgrade.
  7. May 21, 2017 at 1:48 PM
    Billybong
    I'm changing from boating to dirting?
  8. May 22, 2017 at 12:30 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    look at the OME 885 front springs and a 1.5" AAL in the back, that'll give you around 2.5" in the front and 1.5" in the back via suspension. Then you'll have no problem fitting a larger tire (just going to 265/75/16 or 265/70/17 will give you another .5" of ground clearance). There are taller/skinnier and/or taller AND fatter tire options, but then you start really having to pay attention to backspacing and considering other modifications to the wheel wheels to fit.
  9. May 23, 2017 at 10:24 AM
    Billybong
    Thanks, excuse my ignorance but what are OME 885 front springs and 1.5" AAL. I like the clearance numbers.
  10. May 23, 2017 at 10:28 AM
    PreRunnerMan
    PreRunnerMan Well-Known Member
    Alex
    SoCal, Whittier
    White 2010 PreRunner SR5
    ADS Coilovers LR UCAs Bilstein shocks in the rear Dakar Leaf Pack CMC 287/70/17 BFG K02s
    I have the OME 885 coil springs paired with bilstein 5100s up front. They are a new coil spring to allow you to lift the truck. It is on the cheaper end of lift options, but not the super cheap and terrible options which would be spacer lifts. The 1.5" AAL is just an extra leaf that you would add to your stock leaf pack in the rear to gain extra lift.
    Billybong[OP] likes this.
  11. May 23, 2017 at 10:34 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Tire diameter is what you need to pay attention to. A 265/75/16 is the same diameter as a 265/70/17. I prefer more rubber and less metal so I like 16" rims. Not a fan of the trend to larger wheels especially on 4x4
  12. May 23, 2017 at 11:28 AM
    Billybong
    Thanks for all of the information. My truck has 28,000 miles and since I need to head to the dealer I am going to look into all the information provided. I like the idea of upgrading coil springs and shocks. The factory shocks bounce to much for my liking. I will try to take a before and after photo. I will need my daughter to help since I kinda understand how all this new technology works but don't know how to use it. Oh well, just talking.
  13. May 23, 2017 at 2:05 PM
    Billybong
    My truck comes stock with 265/75/16, is there a larger tire size.
  14. May 23, 2017 at 2:07 PM
    boulderbean
    boulderbean Active Member
  15. May 23, 2017 at 2:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Umm..
  16. May 23, 2017 at 2:19 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    5100s with 885s, rear AAL or leaf pack, stock wheels wrapped on Cooper ST Maxx 255/85/16 with Spidertrax on all 4 corners or aftermarket wheels of your choice and no spacers.
    b_r_o likes this.
  17. May 23, 2017 at 2:25 PM
    Billybong
    My mistake 265/70/16
  18. May 23, 2017 at 3:01 PM
    PreRunnerMan
    Alex
    SoCal, Whittier
    The options for tires are limitless it just depends if you want to do any cutting:sawzall: in the fender
  19. May 23, 2017 at 6:30 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Going to a 265/75/16 will give you a 1" taller tire and is as big as you can go without lifting. 265/70/17 tires will be almost identical in width and height, but going to 17" wheels just costs more and won't lift your vehicle at all. In fact I think you'd be better off having the same diameter tire mounted on a 16" rim than a 17" rim. You have more rubber between the ground and rim with 16's. Also, remember for each 1" taller tire you only gain 1/2" ground clearance and tire manufacturers round up on sizes
    The tires you have are 30.5" tall (advertised as 31"), 265/75/16's will be 31.5" (advertised as a 32" tire) and is a very capable size. There are darn few places you can't go with a 32" tire. Years ago people went everywhere with 31" tires and 33's were huge. Most guys never go bigger than 33" tires (actual size would be 32.5") and it requires close to $1000 in modifications to get 1" more ground clearance over what you have. Only 1/2" more than 265/75/16's which can be mounted with no modifications and no loss of performance. If you get into tires larger than 33" you really need major vehicle modifications including re-gearing the axles.
    Anything is possible if you have the time and money. I've never felt at a disadvantage with a 32" tire on a stock vehicle. But if you want to throw money at it is your money.
  20. May 23, 2017 at 7:36 PM
    Billybong
    Thanks for the information. Don't want to spend money needlessly just want to have fun and return home with no repairs needed. What are your thoughts about 2" lift with OME front springs 5100 Bilsteins and 1.5" AAL in the rear? Price seems reasonable without any further modifications.
