Tire Choice Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, Aug 26, 2010.
  1. Aug 26, 2010 at 8:08 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    I have a double cab trd truck and am about to change tires for the first time.. i am right over 40,000 miles...... I had the TSB done in the rear for the springs so i added the 5100's in the front and had matching spring put in the back... it has lifted my truck some.... just wondering if there is an option to got alittle bigger tire? What will it do gas mileage wise with a bigger tire? Will it throw my speedometer off?
  2. Aug 26, 2010 at 8:13 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    265/75/16 will correct your speedometer and make it accurate (so I've heard).
  3. Aug 26, 2010 at 8:16 PM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    I think a lot of the gas mileage loss is due to the larger rotating mass of the bigger tires in addition to their increased profile. If you are seriously concerned with your MPG then be honest with yourself about your driving style/conditions and try to balance looks, performance and value.
    The tire size guide is a great tool to start with. You can compare both size differences and speedometer impacts. Good Luck.
  4. Aug 26, 2010 at 8:18 PM
    S.B.
    Sean
    I forgot ad. My 255/85/16 (actual 33s) Did not change my mpgs at all. They are Cooper Discover S/T (not STT).
  5. Aug 26, 2010 at 8:20 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    i got 265/70/17 BFG AT
    they look so hot
  6. Aug 28, 2010 at 7:38 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Confirmed, at least for the 17" size.
    When my stock tires were ready for replacement, I put on 265/70/17's and this put my speedo right on the button.
  7. Aug 28, 2010 at 7:53 PM
    Archangel
    Archangel Discount Tire Company
    Charlotte, NC
    13 Malibu LT
    x2 My 265/70/17 BFG AT's look sick nasty on my TRD wheels
  8. Aug 28, 2010 at 7:58 PM
    nomad
    nomad Well-Known Member
    DC LWB 4x4 V6
    LT265/75-16 REVO's
    last fill up: 18.1 mpg (mostly around town w/a little bit of interstate driving)
  9. Aug 28, 2010 at 8:00 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I just put some Grabber AT2's on, they look great.
  10. Aug 28, 2010 at 8:17 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    265/70/17 Duratrac, speedo is now correct, fuel milage is around 17.5-18 mpg just a few tanks so far. remember right now you speedo is telling you went further than you actually did so you mileage is inflated ( 4% IIRC )
    Uploaded with ImageShack.us
  11. Aug 29, 2010 at 10:31 AM
    Rocketball
    Scott
    Westminster, MD
    Actually the math will show you are getting less MPG with a larger tire. That's why so many people claim they get lower MPG with larger size tires......
    The larger tire has a longer rolling circumference, and over a full tank of gas, you will travel a longer distance than what the odmeter is actually reading.
    I did the math about a year ago calculating the actual number of rotations of the stock tire size (265/65/17 vs 265/70/17), and from what I remember there was about a 5-7% difference between the mileage shown on the odmeter, and the actual calculated mileage using the rolling circumference of the tire. After doing the math to figure my MPG, and then adding the % differental, my acutal MPG was exactly what it was with the stock size tires.
    A lot of people say going to a larger tire will lower your mileage, and I guess if the size difference is large enough it will, but going from a 265/65/17 to a 265/70/17 made no difference in MPG for me.
  12. Aug 29, 2010 at 11:13 AM
    senna
    San Jose CA.
    You are correct, I worded it wrong. I see the same thing, mileage now is the same as the corrected mileage when the odometer was incorrect.
  13. Aug 29, 2010 at 12:17 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Pay attention to tire diameter and weight. If you don't go too large on the diameter or too heavy on the tire weight you should be ok.
    The stock tires are around 30.5 diameter and weight is around 36 lbs depending on tire. Going 1.0-1.5 inches larger in diameter will usually correct the speedo. I think Toyota probably figured a large percentage of drivers would put a larger than stock tire on so they put a gear in to account for that.
    Lastly, unless you plan on doing some heavy hauling or serious mudding stay away from load range E or 10 ply rated tires. You start looking at some serious weight differences which will ultimately drag down the fuel mileage and power. Just because the tires look scary/awesome on your rig doesn't mean you should actually have them.
    Just my thoughts. Ken:cool:
  14. Aug 29, 2010 at 12:21 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    :woot: 255/85/16 Cooper ST :woot:
  15. Aug 29, 2010 at 5:21 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    DURATRAC'S
  16. Aug 29, 2010 at 11:26 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    General Grabbers (photo on an FJ Cruiser)...
