Tire clearance help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnwhitehead4, Dec 7, 2016.
  1. Dec 7, 2016 at 4:19 AM
    johnwhitehead4
    johnwhitehead4 [OP] Active Member
    South Carolina
    2008 DCSB TRD OR Rugged trail edition
    So I have 2008 dbl cab TRD OR. I am leveling the truck with the 2in leveling kit from rough country it says u can tuck a 32 in tire but I want to go to a 285/75r16 which is a 32.8. How much should I space my wheels so I can fit the 32.8 if I'm on factory 16in rims?
    ChadsPride likes this.
  2. Dec 7, 2016 at 11:04 AM
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    Search on TW. This has been talked about in great detail. I think the wheel spacers are called spidertrax or something close to that. 285s will hit the upper control arm and you have to push the out. You will have to cut fenders and take off mud flaps to get it to fit on the street. You will have to really cut and possibly cab mount chop if you plan to off road. 285s will hurt your effective hp to the ground. I'm assuming that is a spacer lift and that will be a weak spot in your suspension. It all depends on what you plan to do with it. There is tons of information on here about this.
  3. Dec 7, 2016 at 11:07 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Tire clearance help is perfectly fine.
    "HELP EMERGENCY URGENT" and then asking about tire clearance is not fine.
  4. Dec 7, 2016 at 11:09 AM
    T4RFTMFW
    You'll need wheel spacers to run the OEM wheels with 285s, and likely do some trimming to the fender wells. You may have issues with the cab mount as well which requires cutting the frame and welding, so be prepared mentally to modify things permanently to fit those tires.
  5. Dec 7, 2016 at 11:47 AM
    MO Tacoma
    Castle Rock, CO
    I agree with you but there are too many people that will jump on you for the littlest things. Or simply not respond to their questions. I was not trying to mislead or be a dick myself. It was a tip. I have found it to be the case and see it all the time. That's why I try to help despite the question being asked a thousand times before.
  6. Dec 7, 2016 at 11:49 AM
    T4RFTMFW
    Agreed..
    His title was fine then, and is now.
  7. Dec 7, 2016 at 12:04 PM
    MO Tacoma
    Castle Rock, CO
    :facepalm:I agree with you
  8. Dec 7, 2016 at 12:12 PM
    T4RFTMFW
  9. Dec 7, 2016 at 7:10 PM
    wolmar72
    wolmar72 Well-Known Member
    Jon
    Newport Beach CA
    12 dual cab 4x4
    check your OEM
