Tire Clearance Question
Discussion in 'Wheels & Tires' started by qckslvr2234, Feb 20, 2012.
  1. Feb 20, 2012 at 10:10 PM
    qckslvr2234
    qckslvr2234 [OP] Well-Known Member
    Maryland
    06 Double Cab
    5100's at 2.5, taco lean spacer, Wheelers 3 leaf aal, sway bar relocate, Nitto terra grapplers 285/70/17, spidertrax, custom fishing rod holder, afe drop in filter, 15% tint on front 35% on back, access original roll up cover, BHLM, LED's in cupholder, Plasti-dip badges
    So I just got my lift in and hope to install soon. I will be doing Billy's with stock coils at 2.5 and a 3 leaf aal. For now I am keeping the stock sport 17" wheels and stock UCA and no wheel spacers.
    I am looking at either 275/70/17 or 285/70/17.
    Really want to do the 285's but I am not sure if they will clear with some stock components. A LITTLE trimming is not an issue.
    Any help will be appreciated.
  2. Feb 21, 2012 at 7:19 AM
    rossivey
    rossivey Well-Known Member
    North Texas
    06 Black DCLB 4x4
    The 285s will more than likely rub but there's only a 1/2" difference between the two so there's a good chance they'll both rub. I would advise against the Billies at 2.5" unless you are ok with a pretty firm ride. Have you looked at toyteclifts.com? What's your budget on the lift?
  3. Feb 21, 2012 at 8:49 AM
    OZ-T
    OZ-T Thats what it is to be a slave ...
    Peter North
    British Columbia
    285's will rub the UCA on stock wheels without spacers
    275/7017 is what I have on my stock Sport wheels , so does TW member Teamfast .
    His rub his stock UCA at full lock , mine do not rub my LR UCA's at all .
  4. Feb 21, 2012 at 1:04 PM
    qckslvr2234
    Maryland
    06 Double Cab
    I wanted a decent lift without spending a ton of money and I refused to get spacers. I did alot of research and most people seem to be ok with the billies at 2.5. I am lucky enough the wife is letting me spend this much on a lift since she opposses it all together. Which lift are you referring?
    I could deal with full lock as this is mainly a daily driver so I dont go to full lock that often. I wish I could get UCA's but money is tight. What tires do you have? Any pics?
  5. Feb 21, 2012 at 1:08 PM
    OZ-T
    Peter North
    British Columbia
    LT 275/70/17 Hankook ATm
  6. Feb 21, 2012 at 1:20 PM
    qckslvr2234
    Maryland
    06 Double Cab
    Looks good. How do you like the Hankook's never owned any.
  7. Feb 21, 2012 at 1:26 PM
    OZ-T
    Peter North
    British Columbia
    Thanks
    I like them , I just got these ATm's about 2 months ago , before that I had Hankook MT's for a couple years .
    FYI , this size of Hankook ATm only comes in a 10 ply , E rated
  8. Feb 21, 2012 at 1:37 PM
    qckslvr2234
    Maryland
    06 Double Cab
    Yeah I am leaning to 275's just wish they had more choices for that size.
  9. Feb 23, 2012 at 12:11 PM
    the drake
    the drake Member
    Brian
    Castle Rock, CO.
    2011 TX TRD
    Toytec 3" ultimate lift custom leather interior cat back flowmaster exhaust AFE Cold air intake window tint weathertech floor mats
    I went with the 285/70/17 and had very little rubbing, doesn't rub the UCA at all.
  10. Feb 23, 2012 at 12:13 PM
    OZ-T
    Peter North
    British Columbia
    Stock wheels ?
  11. Feb 23, 2012 at 12:21 PM
    qckslvr2234
    Maryland
    06 Double Cab
    I wonder if the 265/70/17 duratracs will fill the well better or look beffier the an a/t in the same size?
  12. Feb 23, 2012 at 12:23 PM
    OZ-T
    Peter North
    British Columbia
    Just checked your specs , you don't have stock wheels , not the same as what the OP is asking
  13. Feb 27, 2012 at 12:10 PM
    First Tacoma 2011
    First Tacoma 2011 Well-Known Member
    Bruce
    Maryland
    2011 TRD Sport Tacoma
    Toytec 3'' Lift 2'' AAL Bed Light Mod Westin Step Sides
    I have a lift and I am currently running 285/70/17 on my stock rims. I am currently rubbing on the UCA. I am still calling around trying to find someone that makes a UCA that will solve this issue. I am not a fan of the wheel spacers but if I have to get them I will.
  14. Feb 27, 2012 at 12:25 PM
    qckslvr2234
    Maryland
    06 Double Cab
    yeah, i cant afford new uca's right now. looks like you will be buying some soon.
  15. Feb 27, 2012 at 1:04 PM
    First Tacoma 2011
    Bruce
    Maryland
    Yep.... the sooner the better.
  16. Feb 27, 2012 at 4:54 PM
    Large
    Large Red
    BFG at KO, & Goodyear mt/r also come in 275/70/17
