Tire Cupping??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03tacoma4x4, Sep 13, 2016.
  1. Sep 13, 2016 at 9:46 PM
    03tacoma4x4
    03tacoma4x4 [OP] Well-Known Member
    Western NC
    2002 Silver Tacoma TRD V6 4x4
    2016 Tacoma Wheels
    I have recently noticed on the driver side front of my 02 Ext Cab the tire is starting to show signs of cupping toward the middle inside section of the tire. I have noticed that the tire has been louder than usual but just noticed the cupping the other day. Any idea as to what would be causing this? I am due a tire rotation but for t to just be on one side makes me think that something else is causing this problem. Tires are Nitto Terra Grapplers. I jacked it up and did the wobble test and didn't find anything out of the ordinary. What could be causing this?? Thanks in advance.
    Edit: Should I just go get an alignment and see if they can determine the problem while doing the alignment?
  2. Sep 13, 2016 at 10:00 PM
    97handmedown
    97handmedown Well-Known Member
    Tyson
    1997 Tacoma 4x4 Single Cab
    3", wheels, tires, old man seat covers
    Alignment? If the alignment is off it can cause cupping. A camber setting could only affect one side but wouldn't necessarily cause a noticeable pull.
    Also worn struts/shocks that do not prevent oscillation of the springs after absorbing a bump or drop. Also could just be the one side.
    Also tire pressure could be a culprit.
    Instead of the jacked up "wobble test", do a "dry park test". Leave the vehicle on the ground and have someone turn the steering wheel back and forth (putting a steering load back and forth). While they do this climb underneath and look at/feel your tie rod joints, ball joints, and steering rack bushings.
    Sometimes a worn part won't reveal itself without a load on the suspension. The drooping changes the angles the parts are sitting at and can hold them "without any play" while they are actually worn at the standard angles of operation.
    Note: A dry park won't catch everything but is usually more revealing than shaking the tire with your hands.
    Edit: I would be willing to bet 7 out of 10 1st gen tacomas on the road today have worn steering rack bushings that often go unnoticed by a shake down test.
    mlcc, 03tacoma4x4[OP] and wilcam47 like this.
  3. Sep 14, 2016 at 1:12 PM
    03tacoma4x4
    Western NC
    2016 Tacoma Wheels
    Anyone else? Opinions?
  4. Sep 14, 2016 at 1:16 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    alignment, which could be worn tie rods, ball joints, control arms, sway bar bushings etc...
    03tacoma4x4[OP] likes this.
  5. Sep 14, 2016 at 1:19 PM
    wilcam47
    Will
    Bourbon state
    mine was upper and lower ball joints, they had to fix that before they could do an alignment
  6. Sep 14, 2016 at 1:25 PM
    03tacoma4x4
    Western NC
    2016 Tacoma Wheels
    Sorta what I was thinking because they wont be able to align it if something is shot. Was just one tire cupping like in my case?
  7. Sep 14, 2016 at 1:29 PM
    wilcam47
    Will
    Bourbon state
    If I remember right yes. The drivers side was messed up and causing premature wear. I noticed it when I bought it but thought it might just need tires so I was already getting new tires and had them fix and align it before I got the new tires put on.
  8. Sep 14, 2016 at 1:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Alignment. That's it. Period.
    Frequency needed to retain alignment depends on how the vehicle is used (or 'events' like potholes or off road mishaps) and wear of components that contribute to the alignment process.
    How long since your last one?
  9. Sep 14, 2016 at 1:48 PM
    03tacoma4x4
    Western NC
    2016 Tacoma Wheels
    Ive only had the truck since February so I'm not sure when it was done last. I'm planning to get alignment done soon. So if something else is wrong then Im sure they will find it while doing the alignment
  10. Sep 14, 2016 at 1:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    Correct.
    I do recommend taking it to a shop known in your area to be very good with their work and fair with their practices. Alignments fall in to that mystical voodoo world for a lot of folks, where they don't know if they are getting the best bang for their buck or not.
    Sometimes big box stores are ok, but it's because the tech cares, not the chain. If you don't have a direct referal to a specific tech, I'd stay away.
    In my area I recently stumbled onto (via referral) a great independent shop for this. In fact, the local Jeep and truck mod shops both have alignment capability, but send their hard jobs to him. In other words, if they can't get it within the 'green light spec', they don't know how to figure out what's wrong. He does.
    That's the kinda guy you want.
  11. Sep 14, 2016 at 2:01 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    In my experience, once a tire starts cupping, it will never come back. Put it on the back would be your only hope to wear it back evenly. But usually being out of alignment is the cause. Various worn front end parts will cause this (resulting is poor alignment)
    Clearwater Bill likes this.
  12. Sep 14, 2016 at 2:48 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    that's my experience
  13. Oct 3, 2016 at 2:42 PM
    03tacoma4x4
    Western NC
    2016 Tacoma Wheels
    UPDATE: I rotated my tires about 1000 miles ago probably even less than that. Went to alignment shop last week to get it aligned and they checked all my tie rod ends, ball joints, etc etc. and said everything was rock solid and nothing was out of place. Put it on the alignment machine and everything was already lined up perfect. Gen even brought me out to the shop and showed me the numbers on the machine/screen. So today, being the curious person that I am check at my left front. Low and behold it has already started cupping just like before. What the heck could this be?? These tires only have maybe 25,000 miles on them and the tread has been wearing perfect up until this point. I'm completely stumped as to what the problem is. Any help would be greatly appreciated.
  14. Oct 3, 2016 at 2:46 PM
    ColoradoPacific
    ColoradoPacific Custom Title
    Centennial State
    Silver TuRD
    ***COMPLETED MODS*** SUSPENSION -Total Chaos UCAs -King 2.0" RR Coilovers w/650# springs -OME Dakar leaf pack -King 2.0" RR shocks -Archive Garage Shackle Flip -Front Range Off Road U-Bolt Flip Kit DRIVETRAIN -URD Short Shifter ARMOR -Pelfreybilt Front Bumper, Steel -Pelfreybilt Full Skid Set, Aluminum -Adventure Off Road High Clearance Rear Bumper -Front Range Off Road E-Locker Skid LIGHTING -Rigid Dually Fog Lights -Rigid 40" SR-2 -Rigid SRQ Backup Lights -AntiDark Underhood LED Strip ACCESSORIES -Safari snorkel -SLEE dual battery tray w/ 2x Interstate MT7-75DT -BajaRack -Custom Bed Rack (Adventure Off Road) -Rubber bed mat (Toyota) -Fender flare delete -Center console 120V outlet -Center Console Vault (TruckVault) -CB Radio -Ham Radio -YETI Bottle Opener -WaterPort shower system -MaxTrax -Hi Lift ***FUTURE MODS*** Re-gear to 4.56 Nitto Ridge Grappler 35s Magnusson Supercharger VIAIR onboard air system 20 gal aux fuel tank
    I had some pretty bad cupping cupping early this summer. Took it in for an alignment & had a really nasty toe-in situation. If you've already had them check alignment and bushings, and it came back that fast I would say that you've probably got a bad shock. It's ONLY the front driver side? Not both sides?
  15. Oct 3, 2016 at 4:05 PM
    03tacoma4x4
    Western NC
    2016 Tacoma Wheels
    Yep only front driver side. Thought it might have been a bad tire. Rotated them and now it's doin it again. Shock is the only thing I can thing of at this point. Think it's shock or coil?
  16. Oct 3, 2016 at 4:41 PM
    zenn1102
    zenn1102 Well-Known Member
    Iowa
    97 taco 4x4
  17. Oct 3, 2016 at 7:40 PM
    03tacoma4x4
    Western NC
    2016 Tacoma Wheels
    So right now I'm going with bad shock. Any one else have ideas?
  18. Oct 4, 2016 at 7:07 AM
    97handmedown
    Tyson
    I used to work in a shop that did alignments and have seen experienced guys miss worn parts. If it's just the one side, I would guess it's the strut. Can you see any visual leaking? Is the front end "bouncy" after hitting a rise or drop in the road? Can you push up and down on the bumper on that corner and does the truck keep oscillating up and down or does it quickly rest back at standard height?
    I still think the steering rack bushings should be checked. Commonly overlooked and can be missed on an alignment machine if they only allow for slop under a steering input load.
    03tacoma4x4[OP], Wulf and wilcam47 like this.
  19. Oct 4, 2016 at 8:11 AM
    03tacoma4x4
    Western NC
    2016 Tacoma Wheels
    No leaking is visual what-so-ever. And there is also no more bounce than there should be while driving or pushing up and down on bumper. I'm probably just going to replace the whole suspension with Bilstein 5100 and see if that solves the issue. Appreciate all the advice!
  20. Oct 4, 2016 at 2:27 PM
    wilcam47
    Will
    Bourbon state
    maybe try a different front end alignment place...
