Tire decision???? need a lil help !!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devman80, Nov 8, 2012.
what would you choose?
  1. dick cepek Radial F-C II
    8.7%
  2. stock tires
    1.3%
  3. bfg t/a ko 10 ply white letter
    38.7%
  4. bfg t/a ko 8 ply black wall
    52.7%
  1. Nov 8, 2012 at 8:11 AM
    devman80
    devman80 [OP] Well-Known Member
    Dev
    newfoundland
    toyota tacoma long bed trd(leather)
    otto-navi head unit, 3 inch level/lift, constant power to cig lighter and 12v outlet, toyota accessories bug deflecter , steps , vent visors, and fabtech street bar with 4 hella black magics upgraded to 100w each .. and 1.25 spidertrax all around.
    I really want the bf goodrich all terrain t/a ko and my dealer is trying to get me to buy dick cepek Radial F-C II.
    any advice out there? also for the bfg's should i go 10ply or 8 ply... 10 got the white letters which id rather?
  2. Nov 8, 2012 at 8:14 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    What size are you looking for? BFG is CLEARLY a better tire...
    The BFG A/T should have the white lettering on one side and not the other regardless...
    I would shy away from the load range E tires...
  3. Nov 8, 2012 at 8:16 AM
    devman80
    Dev
    newfoundland
    @ 285/70/r17 the white letter only comes 10 ply.... id rather a lighter tire but .. also want the whites
  4. Nov 8, 2012 at 8:16 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Drop both. The Grabber AT2, by General is on paper a better all around performer. And very quiet on the road.
    Frank
  5. Nov 8, 2012 at 8:17 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    ^x2. Load E is overkill for the little Tacoma (so is load D in my opinion). I don't know much about the Dick Cepek tires but I'm not a fan of the BFG A/Ts. I think there are much better options when it comes to A/T tires.
  6. Nov 8, 2012 at 8:18 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I'll let someone else chime in here, but my 8ply on my last truck had the lettering...
  7. Nov 8, 2012 at 8:20 AM
    devman80
    Dev
    newfoundland
    ive rid the bfgs on my ol ford i use to have.... not too noisy ... lasted a while... great performance .... im not to clear on ranges and specs?? any help?
  8. Nov 8, 2012 at 8:22 AM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    I've got black wall BFG A/Ts and LOVE them. I had the white wall ones before and I personally think the black looks way better/cleaner. Also these tires perform well on and off road. Last upwards of 50,000 miles!
  9. Nov 8, 2012 at 8:24 AM
    devman80
    Dev
    newfoundland
    id rather 8 ply ... but still like the look of white walls/letter.... bakertaco do you find the 8ply alot harder on gas?? and is the taco pinning them with any issue?
  10. Nov 8, 2012 at 8:25 AM
    aidenhardcore
    aidenhardcore Well-Known Member
    miguel
    boston,ma
    2010 4 door black
    None yet but soon all black.
    Hey op, I would stay away from load e!!!!! I had the grabbers and the bfg ats and both were load e and yes It's an overkill. These trucks dont need a load e tire to preform great. It killed my gas millage. I lost about 2 to 3 mpg:eek:. Its so not worth it. I wouldn't go higher then a load c. Its a great load range, still not to heavy and great offroad.
  11. Nov 8, 2012 at 8:34 AM
    HighTideTaco
    HighTideTaco The Way Life Should Be
    Jon
    Maine
    2010 TRD Sport
    Swapped Hoods (!!!), DTRL Toggle Switch, Disabled seatbelt/ignition chime, Disabled lock/unlock beeps, Installed D-Rings in bed, Debadged "Toyota" on transom (now just one line straight across), Removed mud flaps, Removed TRD Stickers, Custom aluminum "ladder rack" with CB mount (Wilson 2000 Trucker; Uniden 520), WeatherTech; Just getting started!
  12. Nov 8, 2012 at 8:36 AM
    devman80
    Dev
    newfoundland
    i really like the aggressiveness of the bfg ta ko... they only come in Lts tho
  13. Nov 8, 2012 at 8:37 AM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Obviously moving to an over-sized tire is gonna drop the MPGs a little. As for me, I haven't been able to get a spot on number because the odometer is programed for the 265 stock tires. With my 265s I got about 17-17.5 Now with the 285s I get about 16-16.5 You've just gotta drive conservatively. Also, the tires require more power from the engine. It pushes at about 100RPMs more that stock. Overall, this is a very small setback: 1 MPG lost. The BFG A/Ts are very good on gas for how well they perform on and off road.
  14. Nov 8, 2012 at 8:44 AM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Got 75000 on the Cooper ST with at least 1/4 inch thread remaining. I only run Cooper on my trucks.
  15. Nov 8, 2012 at 8:44 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    hey man,
    i just got some BFG AT's. I love em and they are the 10 ply range E tires. I havent noticed much drop in mpg. I do some heavy hauling and crush the range c tires. plus i like the white letters too. not sure about whether or not they come in other range's. I dont hear them on the road at all. Off road traction is very capable for what i do in the desert.
  16. Nov 8, 2012 at 8:45 AM
    devman80
    Dev
    newfoundland
    i really like the agressiveness of the bfg t/a kos.... they only come in lts for 285/70/r17s ... 10 or 8 ply.... local dealer says 10 ply only for white letter... but just called bfg themselves.... guy said white letter on all.... but he didn't sound to sure of himself to me!! any body out there running 285/70/17 bfg t/a ko 8ply white letter????
  17. Nov 8, 2012 at 8:47 AM
    devman80
    Dev
    newfoundland
    any pics??
  18. Nov 8, 2012 at 8:49 AM
    ntilehman
    Seth
    Charlotte, NC
    sure can bud. here ya go
  19. Nov 8, 2012 at 8:50 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    FWIW, I have never seen a BFG A/T that hasn't had the lettering...it may be facing inward, but its still there...
  20. Nov 8, 2012 at 8:52 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    I Just replaced my Generals with MT baja ATZ's loving them, the have nice on road manners, not too noisy, and so far work well offroad including sand. I purchased them from 4wheelonline, no sales tax and free shipping.
