Tire fit question
Discussion in 'Wheels & Tires' started by JonnyB76, Dec 27, 2021.
  1. Dec 27, 2021 at 7:12 AM
    JonnyB76
    JonnyB76 [OP] Mr. Chaos Theory
    Jon
    NH
    2011 Super White SR5 Tacoma Access Cab V6 AT
    Tool Box, Tonneau Cover, Fisher HS 7'2" Plow, 3" leveling kit, Compustar Remote Start with Drone Mobile, Kenwood radio, JBL amp, 2 12" Subs.
    Ok here's the details,
    2011 Sr5 V6 4x4 ac with 3in spacer lift front 1in block in the rear, running Black Toyota Baja Alloys r16 x 7" 30mm offset
    Can I put 285/75/16 BFG AT K02's on without any modifications?
  2. Dec 28, 2021 at 6:31 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
  3. Dec 28, 2021 at 6:32 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
  4. Dec 28, 2021 at 9:03 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I'm not a second gen guy but I'm gonna guess you will hit the upper control arm with that offset.
  5. Dec 30, 2021 at 5:32 PM
    JonnyB76
    Jon
    NH
    That's clear as mud, a no, a yes, and a probably no.
    Good thing I'm not in a position to pull the trigger on up sizing my K02's :frusty:
  6. Dec 30, 2021 at 5:34 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    For street driving yes. Offroading no.
  7. Dec 30, 2021 at 7:04 PM
    gotoman1969
    My apologies. Yes you can mount them w/o any mods. More than likely they’ll rub the uca with that offset. They will hit the cab mount when you turn. Off road as the suspension cycles they definitely are rubbing. But the simple answer is yes since you didn’t ask “ will I have any issues?” My bad for not being clear.
  8. Jan 1, 2022 at 4:30 PM
    JonnyB76
    Jon
    NH
    No apologies, this is the level of detail I greatly appreciate (I'm a Civil Engineer who's prepping for my Professional Engineer Exam currently)
    What options are available to get this combo functional without issues, I'm guessing wheel spacers, but how much and what negative effects do they cause would be my next questions.
  9. Jan 1, 2022 at 4:59 PM
    Vegasstunts
    16 TRD sport
    All of them.
    Wheel spacer help you clear control arms but add scrub radius and start rubbing the cab mount.
    gotoman1969 likes this.
  10. Jan 1, 2022 at 5:06 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Get your PE. Go work for Bechtel. Remove the spacers. Get extended coilovers with 2.5” lift, UCA, and a CMC. The KO2’s will fit fine.
  11. Jan 1, 2022 at 5:18 PM
    JonnyB76
    Jon
    NH
    Had to look up cmc, the spacer kit was the previous owner to level the truck for the plow, I'd love a coil over in front and new spring pack in the back, my CFO will most likely veto any serious suspension upgrade, my truck most likely will never see serious off-roading sadly, my Foes Mutz mountain bike takes most of my time and money currently.
  12. Jan 10, 2022 at 7:37 AM
    JonnyB76
    Jon
    NH
    Shifting gears, what has to be done to run 265x75x16 on these rims, same as above? 2.5 coilovers, uca, and cmc? or will these eliminate some rub spots?
  13. Jan 10, 2022 at 9:05 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Can you confirm which wheels you have? I assume you're talking about the "faux beadlock" wheels? If so, then those specs are incorrect. The TRD faux beadlock wheels are 16x7.5 +10mm.
    Assuming we're talking about the TRD wheels mentioned above... 265/75R16 will fit no problem with no mods needed. 285/75R16 is tough to say for sure. Everyone's truck and everyone's situation is a little different. Fit isn't about lift amount, it's about wheel offset, tire diameter and tire width. Higher offset wheels are better (so long as they're low enough to clear the UCA).
  14. Jan 10, 2022 at 9:32 AM
    JonnyB76
    Jon
    NH
    This is the rim I'm running on my
  15. Jan 10, 2022 at 9:59 AM
    clenkeit
    Colin
    Lakewood, CA
    Gotcha! Never mind then. The wheels I was talking about came on newer year Baja and Pro Tacomas.
  16. Jan 10, 2022 at 10:22 AM
    JonnyB76
    Jon
    NH
    No worries, I know the rims you were referring to.
