Tire fitment for stock height
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yoluck, May 29, 2021.
  1. May 30, 2021 at 3:19 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    There in lies the problem. There are a bunch of different answers, because there are a bunch of variables. What you will find for your particular wheel choice, is that you won't be able to fit a very big tire. That wheel has a large width and a very aggressive offset. I assume you picked up an SCS wheel, based on the specs. You could probably hit up the SCS specific threads, to find a possible answer. BUT! Be aware that no two trucks are built the same. Small differences between trucks, can result in one truck rubbing and another clearing. Alignment numbers are also a huge factor. So much so, that no one will be able to give you a 100% definitive answer.
    Best option is to pick the tire size you want/need and then just follow the steps to remove the rubbing. Which, with that wheel spec, means 1 thing...
    :sawzall:
    Edit: https://www.tacomaworld.com/threads/gauging-interest-new-size-in-scs-ray-10’s-17x9-w-3-5”bs.534302/
  2. May 30, 2021 at 3:36 PM
    yoluck
    yoluck [OP] Member
    Lucky
    Fort Worth, TX
    2021 Tacoma TRD Sport
    Purely for aesthetics. I wanted my tires to poke out for a more aggressive look.
  3. May 30, 2021 at 3:54 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    Yeah I’m with you I wanted my tires to stick out a little so I went with -12 offset. I currently run the stock tires since they were so new and the wider width causes a rounded side wall. I will remedy that with the next set of tires. I just need to mess around and see what will fit and decide if I want a lift or level kit.
    yoluck[QUOTED][OP] likes this.
