Tire fitment question
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacotopher, Jan 24, 2010.
  1. Jan 24, 2010 at 7:46 AM
    tacotopher
    tacotopher [OP] Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    I drive a 04 TRDOR DBL Cab and I just rencently installed this lift
    http://www.toyteclifts.com/index.ph...ategory_id=63&option=com_virtuemart&Itemid=72
    I am now looking into replacing all four shocks and getting larger tires. I wasnt sure which shocks to get as I dont offroad too much, but when I do I'd like the extra sense of security being slightly higher off of the ground and some more capable tires than the rugged fails. What do yall think?
  2. Jan 25, 2010 at 3:47 PM
    tacotopher
    Memphis
    Zombie TRD OR
    Anyone?
  3. Jan 25, 2010 at 5:50 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    on a 1st gen n coil spacers, swap out the TRD coils for nonTRD coils n go with the bilstein HD replacements for the front n some 5125s in 8.5 travel out back...
    as for tires stick to 265-75-16...
  4. Feb 3, 2010 at 2:30 PM
    tacotopher
    Memphis
    Zombie TRD OR
    The stockers right now look like donuts. Theyre just so small since I put the 3 inch lift on it
  5. Feb 3, 2010 at 2:43 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I'd go with 285/75/16's
  6. Feb 3, 2010 at 3:14 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    dcab sits lower than xcab or reg cab...
    would need 4" backspace to run that size, which means more money on either wheel spacers or new wheels if running on stock rims... plus, MPG is going to suck your wallet dry going that big a tire...
    try out 265-75s first and see how that suits you before you go dropping money deeper into the pit...
  7. Feb 3, 2010 at 6:04 PM
    tacoman101
    scott
    vermont
    good call, i didn't know that the double cabs sat a little lower
  8. Feb 3, 2010 at 6:16 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    how do guys find your gas mileage with the 285/75/16 ?, is it worth it. im undecided whether to go 285/75/16 or 265/75/16 instead.
  9. Feb 3, 2010 at 6:25 PM
    tacotopher
    Memphis
    Zombie TRD OR
    How did the 285's affect your gas mileage?
    I am planning on using wheel spacers along with the new tires
  10. Feb 3, 2010 at 6:25 PM
    tacotopher
    Memphis
    Zombie TRD OR
    Thanks for the good info.
    How much lower does the dbl cab sit than a xtra or reg cab?
  11. Feb 5, 2010 at 3:37 PM
    tacoman101
    scott
    vermont
    My gas mileage only dropped 1, mabye 2 MPG when I made the switch from 265's to 285's. Not much at all lost
    Like said above, my gas only dropped about 1 to 2 mpg
  12. Feb 6, 2010 at 6:09 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i love the look of the 285's on urs and on evertaco's i think ill go with them whenever these 265/70/16's wear out. I travel about 120 kms to work and back everyday so hopefully it wont affect it to much. 1-2 mpg aint bad.
  13. Feb 10, 2010 at 11:43 PM
    Silvatacoma
    Silvatacoma Well-Known Member
    Hawaii
    Do you have to use wheel spacer to run those 285/75's on those stock wheels?
  14. Feb 11, 2010 at 1:48 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    I don't know about the DoubleCabs sitting lower. Seems like BS to me. I have a DoubleCab with ToyTech 3" and am running 285/75 BFG ATs. No problem with rubbing on the stock rims (I do have aftermarkets now). The only thing I had a problem with rubbing was on the frame right behind the front tire on a full lock turn (no fender rub). My aftermarket rims fixed that (as would a wheel spacer); but like I said, it wasn't a major issue. The only times it really rubbed the frame was when I was parallel parking or something like that where I would turn the steering wheel as far as it would go under extremely low speeds. Nothing during normal driving.
    (After new rims 285/75-16s)
    (Before new rims 285/75-16s)
  15. Feb 11, 2010 at 1:59 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Get the cab mounts chopped ^ ^ ^
  16. Feb 11, 2010 at 2:03 AM
    dustinuhls
    Manhattan, KS
    What do you mean? I've never heard of that....
  17. Feb 11, 2010 at 11:13 AM
    Silvatacoma
    Hawaii
    I'm surprised it didn't rub on the UCA's with the stocks wheels (that's what everyone has been telling me would happen). Maybe I'll give 285's a try.
  18. Feb 11, 2010 at 12:09 PM
    tacoman101
    scott
    vermont
    I bought the spacers just to be safe, i think you might get away with running that size without spacers. The spacers were only 10 bucks so i think there worth it
  19. Feb 11, 2010 at 1:29 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    how big of a spacer did ya need? 1'',1.25'' ?
  20. Feb 11, 2010 at 4:12 PM
    Silvatacoma
    Hawaii
    ^^ x2
    .25" spacers?
