Tire fitment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by m4uim0n, Oct 6, 2015.
  1. Oct 6, 2015 at 5:23 PM
    m4uim0n
    m4uim0n [OP] Active Member
    clyde4l
    2014 trd 4x4
    Been trying to do research from multiple threads but still can't figure out if my setup will work... Got the icon stage 4 with tubulars and been trying to figure out if I mount my 69 procomp wheels with 285's will they rub the uca's? Or if the 69's will clear my brakes I'm pretty sure they won't..specs for the wheel is -24 offset 4.5" bs 16x8...I jacked the coilovers to its full 3" of lift. Any setups exact or similar?
  2. Oct 6, 2015 at 5:25 PM
    m4uim0n
    clyde4l
    2014 trd 4x4
    I mean I'm pretty sure the wheels will clear my brakes and fit just fine...still don't understand the whole offset shit all to well even after reading the whole thread about it
  3. Oct 6, 2015 at 5:33 PM
    Pigpen
    Dan
    Northwest Montana
    What is the offset on those particular wheels? It doesn't take much to clear 285s. The more offset, the more you'll have to trim.
  4. Oct 6, 2015 at 5:39 PM
    m4uim0n
    clyde4l
    2014 trd 4x4
    Offset is -24
  5. Oct 6, 2015 at 5:40 PM
    m4uim0n
    clyde4l
    2014 trd 4x4
    I'm looking for that stance nawimsayin
  6. Oct 6, 2015 at 5:48 PM
    Pigpen
    Dan
    Northwest Montana
    Should be plenty. Put em on and start cutting those wheel wells!
  7. Oct 6, 2015 at 6:07 PM
    m4uim0n
    clyde4l
    2014 trd 4x4
    Even with the new wheel being a 16x8 an inch larger than the stock trd offroad? I'm just trying not to be dissapointed and run into a hickup with it having uca rubbing issues don't really want to get spacers atm
  8. Oct 7, 2015 at 11:35 AM
    bimar21
    bimar21 Member
    Edwin
    PR
    07 TRD 4WD leveled
    Bilstein 5100 @ 2.5" 2.5" Magnaflow KC ligth bar / 30" LED Bar Pirelli Scorpio MTR 285/17R16 on Helo Max 16x8 wheels
    I have the Bilstein 5100 set at 2.5" at the front with Helo Maxx wheels in 16X8 (4.5 backspace) and installed Pirelli MTR 285 75/16 and no issues with UCA. I did had to remove the front mudflaps and trim some plastic behind the front mudflaps but no issues so far with UCAs or front body mounts even doing some light off road trails.
