Tire fitment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tscurtis, Aug 3, 2016.
  1. Aug 3, 2016 at 8:45 PM
    Tscurtis
    Tscurtis [OP] Member
    Tyler
    2010 Toyota Tacoma
    So I want to get 20x12 on 33's and I have a 3in lift. How much rubbing should I expect?
  2. Aug 3, 2016 at 8:56 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  3. Aug 3, 2016 at 9:03 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    some
    DustStorm4x4 likes this.
  4. Aug 3, 2016 at 9:06 PM
    Pigpen
    Dan
    Northwest Montana
    Just do it and find out. Cut off anything that rubs, like your cab mount.
    PSU Taco85 likes this.
