Tire Fitting Question
Discussion in 'Wheels & Tires' started by tocoma, Mar 25, 2009.
  1. Mar 25, 2009 at 5:46 PM
    tocoma
    tocoma [OP] Member
    rugged trail
    Hello i am looking at a set of pacer juice 6 20 inch rims with 305/50 nitto terra grapplers for my 2008 rugged trail dc.What is the least amount of lift/ trimming needed to clear them without much rubbing. Also what kind of gas mileage would be expected with this wheel/tire combo.
    Thanks
  2. Mar 25, 2009 at 10:38 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I'm not sure exactly... your tire will basically have a 32" diameter, and I've heard that the largest tire size you can run without lift and on stock wheels is about a 31.6" (265/75-16) tire; so it might be a bit close as far as tire height but I think the the deciding factor on how much you have to trim will be the offset/tire-width combination. Lots of folks on here are running those Nittos TGs, try doing a few searches in the "search for thread".
    Good luck.
  3. Mar 25, 2009 at 10:51 PM
    SMG26
    SMG26 Well-Known Member
    Woodstock,GA
    06 Prerunner TRD Offroad
    Injen CAI, JBA exhaust pipes 2.5" w/magnaflow muffler, Doug Thorley Long tube headers, URD MAF CAL and O2 sim,Access roll up cover, AVS Wind deflectors, coverking seatcovers, grillcraft upper/lower grille, Halo projectors w/6000k HID and pop lock on tailgate.
    I recently put a 3" kit on my truck. I was wondering what would be the biggest tire I could run on stock wheels 16" without rubbing. And would I benefit from spidertrax wheel spcaers too run a bigger tire on stock wheels 285 possibly.
  4. Mar 25, 2009 at 11:32 PM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    eventhough he gets tc ucas?
  5. Mar 26, 2009 at 4:44 AM
    BaseballFan
    BaseballFan Active Member
  6. Mar 26, 2009 at 4:08 PM
    tocoma
    tocoma [OP] Member
    rugged trail
    Exactly wat width are 305 and is anyone running them
  7. Mar 30, 2009 at 7:15 AM
    Matt519
    Matt519 New Member
    SW Georgia
    06Tacoma TRD Sport DC LB
    I'm running 305 40/22 Cooper Zeon ATZ's on my '06 with the Bilstein 5100's set one down from the top setting. I only have minor scrubbing at full steering turn. I believe 305 is the measurement in millimeters of the tires width.IMG00045-20090330-0951.jpg
