Tire help 31'' or 32"???
Discussion in '4 Cylinder' started by T-Sali12, Dec 7, 2009.
  1. Dec 7, 2009 at 10:40 PM
    T-Sali12
    T-Sali12 [OP] Member
    98 2.4L Standard Cab
    Fabtech 3.5" performance lift, 3" body lift, full magnaflow exhaust, K&N cold air intake, cobra PA, pioneer head unit ans speakers, 2 bazooka 10'' subs with 400w amp
    I have a 2.4L 1998 manual tacoma i bought the lift for it... i have rims... i think a 32" tire might be a little too much with out regearing but im not sure, i would love to go to the 32" but the 31's seem a little safer. It is my dd so i still have to have enough power to be on the freeway and get around town.(the 32's will fit) I want to put on the Cooper Tires DISCOVERER STT 31X10.50R15LT... any input would be appreciated. Thanks.
  2. Dec 7, 2009 at 10:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    why do you think the 31's are safer than the 32's? for the inch difference and what 5 pound difference per tire, id say just go with the 32's
  3. Dec 7, 2009 at 11:01 PM
    T-Sali12
    Im just goin off what i hear the 32's are an inch taller and an inch wider. I dont have the money to regear right now, and people have told me that 32's are to much with the stock gears.
  4. Dec 7, 2009 at 11:08 PM
    08pretaco
    Oliver
    az
    so are you between 245 and 265? 245 is 9.6" wide and 265 is 10.4 so just about 3/4" difference. the diameter difference is under 1 1/4" therefore your only getting the benefit of .625" inch of ground clearance. it doesnt seem like you would need to regear after looking at the tire calculator..but i dont own a 1st gen so thats just an observation
  5. Dec 8, 2009 at 1:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What's your current gearing? Current tire size?
    You have a 2.4L mini (5 lugger) right?
    That's a different ballgame than the 6lugger thing. What transmission do you have?
  6. Dec 8, 2009 at 6:17 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    If it's a DD and you don't offroad a lot, the 31s would do fine.I'm assuming now , but arent stock on yours 235/75/r15? Not sure if you are ok with some power loss.
    I'm assuming its not lifted, therefore I hope someone here can tell you if 32's will fit and still articulate and turn w/o rubbing, also consider chain clearance if it applies to you and your region.
  7. Dec 8, 2009 at 6:20 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Those Cooper STTs are some SWEET tires. The bigger the tires, the worse the mpg and lose of torque. If you like the 31s go with those.
  8. Dec 8, 2009 at 6:23 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    IMO, you should go with the 31" tires. Great tire selection!:thumbsup:
  9. Dec 8, 2009 at 6:55 PM
    T-Sali12
    Right now i have the bfg 235/75/15 AT's, im not sure exactly what gears i have whatever comes stock... i have a 3" body lift along with the fabtech 3.5" performance lift... the tires should fit fine... its just the base 2.4L 5 lug, manual trans... the only thing else i have done is a new exhaust.
  10. Dec 10, 2009 at 10:55 AM
    Tdup
    Tdup Well-Known Member
    Trey
    Columbia, SC
    2.5 in. Ready Lift, 265/75/16 Cooper STTs, 18% tint, USA Spec iPod interface, Wet Okole seat covers, Husky mats, Rear Suspension TSB, Black Cam-Locker toolbox, Secondary air filter removed-AFE prodryS, 55w 5000K HID Headlights, 35w 4500K HID Foglights, Int. Wiper Mod.
    Honestly if you go up to 31s or 32s your power loss will be about the same. I have the STTs on my 08 with a 4cyl and it runs and pulls my 16ft. xpress just fine. So IMO go with the 32s it'll look so much better and anyway most trucks out there come stock with 31s.
    With all that lift why not go with the tried and true 33x12.50's that would look awesome with your lift
  11. Dec 10, 2009 at 8:21 PM
    T-Sali12
    Really? Well, i guess if its not that big of a difference i should just go with the 32's... as far as the 33's go i dont know that seems like alot for how small my engine is i dont want to lose all my power haha...but if anyone else has run these tires on a 4cyl let me know how it is please... Im getting the tires some time next week so any input would be appreciated
  12. Dec 11, 2009 at 12:53 AM
    T-Sali12
    i think ill eventually go with some 4.56 gears. Do i need to swap carriers or can the stock handle that ratio? i have the 7.5" high pinion i believe in the rear and the ISF 7.5 in the front. thanks!
  13. Dec 18, 2009 at 7:03 PM
    VLANDER005
    VLANDER005 Well-Known Member
    96 YODA, 2.7 I4, 31" MTR's
    31" Goodyear MTR's
    I would rock the 31's. They are probably cheaper and plus, you would only be gaining .5 inches of ground clearance on a 32. Hardly seems worth it. A 31x10.50 will take you more places than a 32 or even a 33 for that matter if you know what your doing.
  14. Dec 19, 2009 at 2:24 PM
    Tdup
    Trey
    Columbia, SC
    just trying to clear things up. you have a 1998 2.4L with a 3.5in suspension lift and a 3in. body lift?? is it a 4x4??
  15. Dec 19, 2009 at 2:30 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    2.4l only came in the 5 lugs
  16. Dec 19, 2009 at 8:58 PM
    Tdup
    Trey
    Columbia, SC
    man...i read and wrote 2.4 but for some reason i was thinking 2.7...anyway imo go w/ 32's...you can't go wrong
  17. Dec 19, 2009 at 9:14 PM
    mbtech208
    mbtech208 Well-Known Member
    Peoria, Illinois
    1997 Base 4WD regular cab
    I have a 2.7 4WD 5-speed with 32s, and if I had to do it over again, I'd have gone with 31s. The truck is a dog with 32s, I'm constantly cracking the whip just to keep up with traffic. I had a 3.4 V6 that handled the 32s, but they're just too much for the 4-cyl.
  18. Dec 20, 2009 at 8:12 AM
    frobuster
    frobuster Well-Known Member
    Anacortes WA
    '07 access cab SR5 4x4
    juniper scratches, rock dents.
    Hey man, imo i'd go with de 32's to change a. Realize though that you may go through an extra clutch.
  19. Dec 22, 2009 at 10:18 PM
    T-Sali12
    i went with the 32's and i couldn't be any happier, pics will be up soon thanks for all the input.
