Tire help size and brand
Discussion in 'Wheels & Tires' started by Phils514, Jun 15, 2014.
  1. Jun 15, 2014 at 5:55 PM
    Phils514
    Phils514 [OP] Well-Known Member
    Phil
    Dcsb
    Just ordered 5100 and 2" AAL. Can I fit 275 70 17 with stock trd sport rims? And also what tires do you guys recommend for 75% highway/ in town driving and 25% mild off roading mainly to get to hunting and fishing spots? I'm checking out tirerack.com. My friends coworker said he will mount, balance the tires and install front shocks and align for $240. That seems like a good price?
  2. Jun 15, 2014 at 6:10 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Price seems like a good deal. As for tires maybe some all terrains. Hankook dynapro ATM is a good tire. There are lots of options out there but depends if you mind a heavier tire or not. P rated will be best for highway but the C, D, and E ratings will be a thicker sidewall and heavier tire. Kind of a give and take decision. So weigh out your options and go from there. BFG KO AT are also a good tire and they have a new style comming out in a couple months. It's has a more aggressive/ mud type lugs on the outer tread blocks and more aggressive sidewall.
  3. Jun 15, 2014 at 6:27 PM
    Phils514
    Phil
    Dcsb
    I'm assuming the heavier tires will last longer? Mpg does not matter to me because my job pays my gas. I would like to get something that looks aggressive that will look nice with the billies at 2.5 and 2" aal
  4. Jun 16, 2014 at 3:11 AM
    Phils514
    Phil
    Dcsb
  5. Jun 16, 2014 at 3:41 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    How much lift will this set up give you?
  6. Jun 16, 2014 at 4:22 AM
    Phils514
    Phil
    Dcsb
    Planning on setting the 5100 on the front at 2.5 and 2" aal in the back. I have stock trd sport rims
  7. Jun 16, 2014 at 4:37 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    The tires you wanna run will be fine. Should be little to no trimming required. Once you move up to 33's is when you have to do the cab mount chop and a lot of trimming as required. If you feel that this setup puts your tires too close to the UCA's then you can get wheels with less backspacing or wheel spacers. I only say that because on my stock 16" TRD wheels, after the lift, were about an inch away from rubbing on my UCA's so I got some 4.5" bs wheels.
  8. Jun 16, 2014 at 4:43 AM
    Phils514
    Phil
    Dcsb
    Would it be better if I get 265 70 17?
  9. Jun 16, 2014 at 4:47 AM
    Fiend13
    Chad
    You can fit the 32's with the lift. Hell, you can fit 32's stock. It's really up to your preference of tire but both 265 and 275 will fit.
  10. Jun 16, 2014 at 5:40 AM
    Phils514
    Phil
    Dcsb
    No spacers needed on 275 correct?
  11. Jun 16, 2014 at 8:20 AM
    Phils514
    Phil
    Dcsb
    Sweet. From tirerack there's only 3 different kinds for 275 70
  12. Jun 16, 2014 at 8:29 AM
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    If you buy new wheels with tires and get wheels with backspacing you can fit 33's. Mine don't rub at all on the road.
  13. Jun 16, 2014 at 9:03 AM
    Phils514
    Phil
    Dcsb
    The BFg all terrain t/a ko is $227. $838 if you buy 4. I might just go for 265 75, more options
  14. Jun 16, 2014 at 5:42 PM
    Phils514
    Phil
    Dcsb
    Still can decide to 265 or 275. There a good difference in price and options
