Tire Help with 3" lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Jun 27, 2010.
  1. Jun 27, 2010 at 10:34 PM
    kyle39
    kyle39 [OP] Reppin' BC
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Deck plate mod, rhino lined, A.r.e. flush glass shell, 265/75/16 Duratrac's, MB72 rims, Full OME lift, Dakars in the rear, Tint allround
    Im going to pick up the 3" ultimate lift for my 04 taco, was hoping to put 275/ 70/17 tires on her, with the 17" 2nd Gen. sport rims. Does any one know if theses tires will rub??:confused: I want to avoid trimming if all possible, also if anyone has pics similar to this, that would be sick:cool:. Any other input would be greatly appreciated. Thanks
    -Kyle
  2. Jun 27, 2010 at 10:46 PM
    BajaTaco96
    BajaTaco96 Well-Known Member
    Silver Springs, FL
    1996 Toyota Tacoma 4wd, 3" suspension lift
    K&N, ToyTec 3" front spacers, 3" Fabtech AAL's, Flowmaster exhuast, no cat, Exedy Stage 2 clutch
    It might rub the frame depending on the offset of the rim. I don't know how those sport rims are, so I'm no help there.
    Do you wheel it? I know 31x10.5s fit perfectly in my rear wheel wells when I'm wheeling, 32x11.5s and 33x12.5s hit my fender when I'm wheeling. I know 3" of lift is perfect for when I borrowed a set of 34" LTB's if I didn't flex AT ALL. I could turn without them trying to eat the frame too bad, so as long as you don't wheel it hard I don't see why they wouldn't work. I can run 33's all day long with my 3" and have no rubbing problems, my front fenders are cut just a tad. (To make up for an accident, but either way.) No problems. :D
  3. Jun 27, 2010 at 10:50 PM
    pittim
    pittim mittip backwards
    Pink slider.
    More than likely they will. First gen TRD wheels have 4.5" backspace, 2nd gen wheels have either 5" or 5.25" bs, which means the wheel sits .5"/.75" closer towards the suspension.
  4. Jun 28, 2010 at 3:33 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I have a 33 which is almost an inch taller and it barely rubs on full compression when turning. Just driving around town is fine.
    If it were me I would go with a larger tire than what you are considering...It will look much better. Those tires will look small with a 3" lift.
    Read this
    http://www.expeditionswest.com/equipment/tacoma/bfg_mt_km.html
    Anyone can do the pinchweld mod - If you can use a hammer and knife it can be done. It is simple and not much work.
    I wish I had 16" rims so I could fit the 255/85/16 because it is bigger than a 33. I have a 15x8 Rim with 1/4 or 1/2" different backspacing than stock. It sticks out slightly wider. If you have some rubbing you can also put 1/4" wheel spacers.
    Here are some pics . The mudflaps stick out quite a bit...
  5. Jun 28, 2010 at 3:51 PM
    kyle39
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Thanks,
    Does anyone know know if i have to change the UCA's or should the stock ones be fine?
  6. Jun 28, 2010 at 4:14 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    It is not necessary but it may not align correctly. On lifted vehicles it looses caster. At highway speeds it may wander.
    I replaced my with Light Racing UCAs which have caster built in plus adjustment for caster. It drives perfect - I would recommend it.
    You can also go with Uni-Ball UCAs which usually have caster built in but no adjustment. They are designed for more flex. Perfect for offroading!
  7. Jun 28, 2010 at 6:35 PM
    kyle39
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Yea im not planning to do too much wheeling, just the camping/ hunting trip seasonally, more just for the looks
  8. Jun 28, 2010 at 8:26 PM
    pittim
    Pink slider.
    if you run spidertrax spacers they should rub less.
  9. Jun 28, 2010 at 8:43 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah, you will have to run spacers, so you dont rub the frame. But I personally like the wide stance look. :)
  10. Jun 29, 2010 at 4:36 PM
    kyle39
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Thanks for the help ill be sure to post some pics when shes runnin:cool:
