Tire help
Discussion in 'Wheels & Tires' started by Backwoodz, Sep 28, 2012.
  1. Sep 28, 2012 at 9:21 AM
    Backwoodz
    Backwoodz [OP] Well-Known Member
    South Carolina
    2016 Quicksand TRD Sport
    Toytec ultimate lift, 285/65/18 nitto terra grapplers on xd revolvers, n fab step bars.
    I'm running 305/60r18 and they rub like crazy and its time for a new set of tires will 285/65r18 take care of my rubbing issues? Any help would be appreciated!
  2. Sep 28, 2012 at 9:45 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    How much lift are you running? What wheels, and what are the specs?
    It's hard to say what the outcome would be, because while the 285's are obviously narrower, they're also slightly bigger than the 305's. The added height may negate what rubbing you eliminate in width reduction. 305's are pretty wide though, so dropping to 285's just may do it.
  3. Sep 28, 2012 at 10:27 AM
    Backwoodz
    South Carolina
    3in Camburg and total chaos uca not sure of wheel specs tho :/
  4. Sep 28, 2012 at 10:31 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have a 3" lift with TC UCA's and I am also running 285/65-18"s and the rubbing is minimum with some minor trimming.
  5. Sep 28, 2012 at 10:46 AM
    Backwoodz
    South Carolina
    I've trimmed but am still rubbing pretty bad
  6. Sep 28, 2012 at 10:48 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah its the 305 that is killing you. I think you will be much happier with the 285.
  7. Sep 28, 2012 at 10:53 AM
    Backwoodz
    South Carolina
    Good to hear thanks man
